Problems with new multiboot distro: You must first load the kernel"
    [SOLVED] Problems with new multiboot distro: You must first load the kernel"
    I just installed another distro (Debian 13), alongside KDE neon and Feren OS (also KDE). During installation, I checked the "bootable" box. I probably shouldn't have done that, because Debian ended up creating its own bootloader with Grub. I have now partially corrected this, and the previous Grub of my default OS is displayed again. Debian is also listed.
    However, when I select Debian, the following error message appears:
    Error: File "/boot/vmlinuz-xxx-amd64 not found.
    Error: You must first load the kernel
    How can I fix that?
    The grub stanza is wrong for some reason. The first thing to run "sudo update-grub" then look through /boot/grub/grub.cfg and see if it fixed it.
    Otherwise, if you want help you'll need to provide more details like where Debian is installed, the list of files in it's /boot/ folder, and the grub stanza relating to Debian, for starters.
      Yes sure.
      lsblk
      NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
      loop0 7:0 0 572K 1 loop /snap/color-picker/26
      loop1 7:1 0 4K 1 loop /snap/bare/5
      loop2 7:2 0 63,8M 1 loop /snap/core20/2669
      loop3 7:3 0 63,8M 1 loop /snap/core20/2682
      loop4 7:4 0 73,9M 1 loop /snap/core22/2139
      loop5 7:5 0 91,7M 1 loop /snap/gtk-common-themes/1535
      loop6 7:6 0 373,4M 1 loop /snap/qt5-core20/24
      loop7 7:7 0 63,1M 1 loop /snap/hplip-printer-app/925
      loop8 7:8 0 50,9M 1 loop /snap/snapd/25577
      sda 8:0 0 238,5G 0 disk
      ├─sda1 8:1 0 140,6G 0 part /mnt/b73f5c2a-b805-4d7c-ba15-36c09afc1e7
      7
      └─sda2 8:2 0 97,8G 0 part /
      sr0 11:0 1 1024M 0 rom
      nvme0n1 259:0 0 476,9G 0 disk
      ├─nvme0n1p1 259:1 0 2,2G 0 part /boot/efi
      ├─nvme0n1p2 259:2 0 58,7G 0 part /mnt/67a34737-e209-490c-964d-3c594734b07
      0
      ├─nvme0n1p3 259:3 0 175,8G 0 part /mnt/f3c080b7-fb15-4300-a52e-623047433cf
      f
      ├─nvme0n1p4 259:4 0 117,6G 0 part /mnt/Backup
      └─nvme0n1p5 259:5 0 122,6G 0 part /mnt/Musik
      sda1 = Debian
      sda2 = KDE neon
      nvme0n1p2 = Feren OS (mit Grub)
      List of /boot folder of Debian:
      Addition:
      The /efi folder is empty. Same is with /efi folder of second os (KDE neon). Grub bootloader is on MBR (/dev/nvme0n1).
      sudo update-grub
      [sudo] Passwort für rainer:
      Sourcing file `/etc/default/grub'
      Sourcing file `/etc/default/grub.d/60_feren-theme.cfg'
      Sourcing file `/etc/default/grub.d/90_ferenos.cfg'
      Sourcing file `/etc/default/grub.d/init-select.cfg'
      Generating grub configuration file ...
      Found theme: /boot/grub/themes/feren/theme.txt
      Found linux image: /boot/vmlinuz-6.8.0-87-generic
      Found initrd image: /boot/initrd.img-6.8.0-87-generic
      Memtest86+ needs a 16-bit boot, that is not available on EFI, exiting
      Warning: os-prober will be executed to detect other bootable partitions.
      Its output will be used to detect bootable binaries on them and create new boot entries.
      /usr/sbin/grub-probe: Fehler: Unbekanntes Dateisystem.
      Found Debian GNU/Linux 13 (trixie) on /dev/sda1
      Found KDE neon User Edition (24.04) on /dev/sda2
      Adding boot menu entry for UEFI Firmware Settings ...
      done​
      /usr/sbin/grub-probe: Fehler: Unbekanntes Dateisystem. >engl: Error: Unknown file system
        Ok, so grub "sees" it. Now open /boot/grub/grub.cfg with Kate and look for a section that begins with "### BEGIN /etc/grub.d/30_os-prober" or something similar or any section that contains "Debian". Copy and paste that section here.
        Then navigate to /mnt/b73f5c2a-b805-4d7c-ba15-36c09afc1e7/boot/ with Dolphin and press F4. This will open a console in that folder. Type this command: ls > ~/files This will place a file named "files" in your home folder. Navigate to your home, open this file with Kate, and paste the contents here.
          ### BEGIN /etc/grub.d/30_os-prober ###
          menuentry 'Debian GNU/Linux 13 (trixie) (on /dev/sda1)' --class debian --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-/dev/sda1' {
          insmod part_gpt
          linux /boot/vmlinuz-6.12.57+deb13-amd64 root=UUID=b73f5c2a-b805-4d7c-ba15-36c09afc1e77 ro quiet
          initrd /boot/initrd.img-6.12.57+deb13-amd64
          submenu 'Advanced options for Debian GNU/Linux 13 (trixie) (on /dev/sda1)' $menuentry_id_option 'osprober-gnulinux-advanced-/dev/sda1' {
          menuentry 'Debian GNU/Linux (on /dev/sda1)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.57+deb13-amd64--/dev/sda1' {
          insmod part_gpt
          menuentry 'Debian GNU/Linux, with Linux 6.12.57+deb13-amd64 (on /dev/sda1)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.57+deb13-amd64--/dev/sda1' {
          insmod part_gpt
          menuentry 'Debian GNU/Linux, with Linux 6.12.57+deb13-amd64 (recovery mode) (on /dev/sda1)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-6.12.57+deb13-amd64-root=UUID=b73f5c2a-b805-4d7c-ba15-36c09afc1e77 ro single dis_ucode_ldr-/dev/sda1' {
          insmod part_gpt
          linux /boot/vmlinuz-6.12.57+deb13-amd64 root=UUID=b73f5c2a-b805-4d7c-ba15-36c09afc1e77 ro single dis_ucode_ldr
          The content of ~/files:
          config-6.12.57+deb13-amd64
          efi
          grub
          System.map-6.12.57+deb13-amd64
          BTW: If I set "debian" instead of "ubuntu" at the top of the UEFI settings, I get Grub from Debian and can start it. The other operating systems are also listed in this Grub.
            Well, that all looks normal. It must be an error in the EFI file for Debian, maybe caused by the install-then-reinstall-grub operation. You said your efi folder is empty but it is there on the debian install? Or is there another efi folder somewhere else?
            You can either keep trying to fix this, or set Debian to boot and select "ubuntu" to boot to Kubuntu, or make an entry in etc/grub.d/40_custom on Kubuntu for Debian and select it. Something like:
            menuentry 'Debian Trixie' --class debian {
            insomd part_gpt
            insmod btrfs
            insmod gzio
            search --no-floppy --fs-uuid --set=root b73f5c2a-b805-4d7c-ba15-36c09afc1e77
            initrd /boot/initrd.img-6.12.57+deb13-amd64​
            To do this, you would have to edit 40_custom every time Debian updated the kernel version.
            Most distros will auto-create a set of generic symlinks "vmlinuz" and "initrd.img" that you can use to boot so you won't have to edit 40_custom over and over, but I don't know how to set this in debian. They are normally created automatically when you update the kernel.
            Alternately, you can just load the Debian grub menu from Kubuntu with an entry like:
            insomd part_gpt
            insmod btrfs
            insmod gzio
            configfile /boot/grub/grub.cfg
              Thanks for your engagement.
              I could solve the issue now after I stumbled upon a thread about outdated bootmanager of Feren OS. I decided to move Grub/efi to KDE neon (without moving efi partition of course).
              And voilà: update-grub output is without errors and includes both other systems.
              Now I have - as desired - triple boot with modyfied grub menu.
              Issue SOLVED.
              Thanks for the very good support here. It was only luck to get the culprit of the issue.​
