People have reported that installing the package libqt6wlshellintegration6 fixes the broken panel issues. If that is the case, we will be looking at why Plasma builds did not automatically generate a depend on that.
Review of Resolute Raccoon Kubuntu 26.04 LTS
Sound issues with snap browsers may be? https://bugs.launchpad.net/ubuntu/+s...e/+bug/2142428On #kubuntu-devel & #kubuntu on libera.chat - IRC Nick: RikMills - Launchpad ID: click
sounds like it's going to be a solid LTS release with a well stabilized plasma 6
good work to the kubuntu teamsome stuff i did: https://github.com/droidgoo
Originally posted by acheron View PostSound issues with snap browsers may be? https://bugs.launchpad.net/ubuntu/+s...e/+bug/2142428
Caused by Firefox & Youtube. VLC plays fine.
...does restore sound.Code:systemctl --user restart pipewire pipewire-pulse wireplumber
I have the sound bug too...l. Everything else works surprisingly well. I was interested in the rust based core utilities and the Wayland only session in Plasma. Both seem fine so far. I upgraded from 25.10 to 26.04 because the installer was broken at the time I grabbed a daily build. Not only was the upgrade successful, my NVIDIA drivers did not break in the process! This is really looking amazing and it's not even beta yet.
iv'e said it before , it seems snaps & browsers don't mix well ,always seems like there's one thing or anotherOriginally posted by tenplus1 View PostOut of curiosity I ran the .deb version of Firefox for a few hours and the sound issue never appeared, seems to only affect the snap release.ʟɨռʊӼ ʄօʀ ʟɨʄɛ
- Likes 1
systmed with a fix for this should be installable as an update soon.Originally posted by acheron View PostSound issues with snap browsers may be? https://bugs.launchpad.net/ubuntu/+s...e/+bug/2142428On #kubuntu-devel & #kubuntu on libera.chat - IRC Nick: RikMills - Launchpad ID: click
Latest update broke my install. It boots to login but them goes black. If I shift to terminal mode before attempting graphical log in, I can log in there. A fairly large amount of errors in syslog:Somewhere like 40 or so, each for a different application.Code:2026-03-12T14:03:31.957018-04:00 kubuntu2604 ksplashqml[2325]: qt.qpa.services: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for ''")
The sddm log is zero bytes.
The exact same install in VM works no problem and has a couple errors in syslog, but not many, and has a normal sddm.log.
Not really sure if it's worth trouble shooting or just wait it out. On 20 Feb. I copied the installation root subvolume from my VM onto bare metal and that original version works fine and still does. It does not have the above errors in syslog.
I just did a large update today and everything is working like a charm.I have various sound devices and all of them recognized by the SO. No problems using firefox ( snap version )
Congratulations for Kubuntu team. It promises to be one of the most beautiful and functional versions.
Plasma 6.6.2 is wonderfull. Really nice.
'fastfetch' doesn't list correctly, but 'sudo fastfetch' does.
BTW: I don't have a screen attached to the laptop as the laptop was dropped and the screen was shattered and so was surgically removed. I have a Dell monitor connected via HDMI.
PS: Don't know how to copy/paste the text output correctly so I screengrabbed.
I just tried to install snapshot 4 and hit a brick wall. I thought I'd try on a virtual machine before installing to bare metal. I got as far as attempting to create a password, and every attempt was thwarted by some sort of code that specifies what can and cannot be used. I gave up after 10 attempts. This is something that needs to be addressed, I like a simple one digit password at the install stage and later when I am comfortable with the install I create a new one. I cannot be the only one who has come across this restriction. If I cannot install a system what are the chances of meeting other restrictive practices later on?
I have been using Linux since 1996 so I am not a newbie. What sort of introduction to Linux would this sort of unnecessary hurdle pose to a new user?Asus Z270i7 16gb rm 8tb GT1660 Haupp Quad tuner Kubuntu Jammy/Win 11 Be/FE mythtv 0.34Homerun dual netwk tuner 55¨ Smsng QN95B55" Lap Smsng NP R580 i5 nvidia linux Ultimate/Win 10
kubuntu (and i thing all of ubuntu) has required at least 2 digits for a password for years now, afaik
i think you can also just leave it blank, but do not recommend thatsome stuff i did: https://github.com/droidgoo
