Can I create my own titlebar buttons?
    I have looked everywhere and I can't seem to find any documentation on the window titlebar buttons a.k.a. window decorations.
    What I would like to be able to do is create my own button and add it to my system. I don't just mean the image, but the function. I would settle for editing a current button but the real goal would be whole new button.
    What I'm looking to do is create a "switch screens" button for KDE when using multiple screens. I have this functionality in windows using a program called UltraMon. Basically, I want a window decoration that will switch the window to the other monitor when clicked. I can do this with a keystroke but it would be cool to bind the command to a button.
    Anyone have any ideas?
    Since themes don't come with a switch screen button that doesn't seem to be possible. Maybe you can create a custom launcher that would run a script to do it(if you know how) and place it to a panel instead of window decoration.
    Ok, got it: Ashes come from burning.
      As I never tried a multi-screen environment, I'd like to ask: when you click window menu of an app is there a "move window to screen/monitor" option similar to "move window to desktop"?
        No, there is command in xorg to move to the next monitor but it's not in the titlebar menu.. I have it bound to "Shift ~" at the moment.
        I can't even find where the coding for the window decorations are at this point. It would be a neat thing to be able to do, though.
          I think what you are looking for is kwin-related for it is managing window buttons and their functionality but I was unable to find any example scripts that show how to put custom buttons to windows.
            This is for KDE 3 but some of the principles must still apply (some of the details will definitely be different, though!) - HOWTO: KWin Window Manager Decorations
            You should probably have a good look at Development/Tutorials - KDE TechBase as well ... in particular Development/Tutorials/KWin/Scripting - KDE TechBase
              I still think it is a lot easier to just put a custom launcher on a panel that would activate a script(though less elegant for sure). As for the script, something useful here.
