Marking threads Solved or whatever?
    I seems to be missing the ability to mark threads [SOLVED]
    Is this a forum problem or is it just me
    If you are refering to Forum Ideas, you are correct; it is not enabled in this sub-forum.
    Added:
    Oh, I see you are referring to the new KDE neon forum. I'll fix that shortly.
    Slava Ukraini! πŸ‡ΊπŸ‡¦
      It's not showing in any forum post for me that I can find...
        Fixed. I'll check the most recently added forums, but it should be enabled in all but a very select few (a few non-OS specific forums).
        Added:
        Yup, as far as I can tell, all the OS related forums have this feature enabled. IF you run across a forum that doesn't have it, and you think it should, just let me know and I'll review it.
        Thank you.
          Thanks, Paul.
          I'd marked this thread as solved but...
            Are you editing the first thread entry? Sorry, just have to ask as that is where I had to go to see that. I was also in advanced edit mode too.
