ISO with 5.21
    ISO with 5.21
    Hi, I wanted to try KDE Plasma 5.21 and downloaded the ISO from Neon website ( neon-user-20210211-0944.iso ) . But it does not have Plasma 5.21. Kindly direct me to a link with 5.21 version of Neon ( or an appropriate flavour ). Thanks.
    Neon User has had 5.21.0 for a few days now (Unstable is on 5.21.80).
    Probably a simple matter of applying updates - and rebooting ;-)
    [EDIT] Ah, I see. You want to try it "live". I guess it'll be a few days then :-/
    Or you could just do a quick install on a small partition (6 or 7 gigs should be enough)...
      Thanks. It would be nice to have a Live session for now. I will wait until 5.21 makes it into the ISO.
        The latest ISO should have it:
        https://files.kde.org/neon/images/us...10218-0944.iso
          Thanks. I will try.
            Confirmed via VM
              The Neon ISOs are built approx once a week I think, so the most current image won't always be fully up to date with that is installable.
                I got the ISO from the post above. It is working and I was able to use 5.21. Many thanks to you all. Loving it :+1
