Fixed a long standing issue
Kinda hard when you're battling this:
Even after I discovered the flatpak store and snap store (and synaptic), I still like the Plasma-Discover way of going about updating everything. I'm lazy, I want a gui.Code:pat@Pats-Main:~$ sudo apt-get upgrade On KDE neon you should use `pkcon update` to install updates. If you absolutely must use apt you do have to use dist-upgrade or full-upgrade in place of the upgrade command. https://neon.kde.org/faq#command-to-update Abort
Originally posted by Buddlespit View PostKinda hard when you're battling this:
That should be getting changed as well, but it isn't something quick and simple like submitting an MR with edits to a website
This does remind me to double check that the MR for the original apt patching was submitted by someone. It might be something I can figure out, if it hasn't yet.
Ditto here, though I personally find *managing* system/distro packages easier in the terminal usually. Tab-completion and aliases make that fast. Updating with Discover is my usual morning ruotine. But mainly discover/pkcon hide too much of the messaging, quite often the important parts when there is a problem.Originally posted by Buddlespit View PostI'm lazy, I want a gui.Last edited by claydoh; Oct 19, 2025, 03:49 PM.Self-built: Asus PRIME B550M-K/Ryzen 5600GT/32Gb/Intel ARC B580 12Gb/KDE neon
Well, it WAS quick and easy lol, at least to get the ball rollling.Originally posted by claydoh View Postbut it isn't something quick and simple like submitting an MR with edits to a websiteSelf-built: Asus PRIME B550M-K/Ryzen 5600GT/32Gb/Intel ARC B580 12Gb/KDE neon
