View Post
I haven't looked at what the equivalent commands to do so if SDDM is running via kwin-wayland. Probably a kscreen-doctor command. I just haven't dug in to find this yet.
But to make sure SDDM is running on xorg I believe you can add DisplayServer=x11 to the /etc/sddm.conf file or to a dedicated file in /etc/sddm.conf.d
Then, the xrandr commands should work.
I have not tested this, I simply got used to having my login on both screens again some months back when I was testing SDDM using a Wayland session, and never switched back. If I had more monitors, I'd probably would have switched my SDDM config back, or kept plugging away until I found the correct command string to use, and where to put it.
