This post is a follow up from a previous post describing the issue (i.e. after updating my server from Jammy Jellyfish to Noble Numbat (Ubuntu 24.04.1 LTS), the visual display is extremely enlarged). I realize the original post is old, but I'm now at the system being described and trying to fix it.
Below I've listed the things I've tried to address the problem.
Thanks very much for any tips.
- System settings: per a recommendation from AskUbuntu, I've gone into KDE System settings and checked the "Force Font DPI 96" checkbox (no change).
- kscreen
- kscreen-doctor -o
Output: 63 None-1 enabled connected priority 1 Unknown Modes:
65:640x480@60*! Geometry: 0,0 640x480 Scale: 1 Rotation: 1 O
verscan: 0 Vrr: incapable RgbRange: unknown - Attempting fractional scaling: kscreen-doctor output.None-1.scale.2
kscreen.doctor: setop exec returned KScreen::Config(
KScreen::Output(63, "None-1", connected enabled priority 1, p
os: QPoint(0,0), res: QSize(640, 480), modeId: "65", scale: 2
, clone: no, rotation: KScreen::Output::None, followPreferred
Mode: false) )
- kscreen-doctor -o
- kwriteconfig
- Calling kwriteconfig5 --file ~/.config/kcmfonts --group "General" --key "forceFontDPI" "96" did nothing (and calling the same command using kwriteconfig resulted in the message "Command not found").
- Finally, manually creating the ~/.config/kcmfonts file and including the recommended text did nothing.
