Kubuntu takes a long time to start after update
    I updated on August 3rd, 2024, and ever since when I restart it ALWAYS takes several times longer to start from when the word KUBUNTU appears on the splash screen to when the desktop appears. Where are the logs so I can post them to my Pastebin account or somewhere else so you can see them?
    Open Konsole and run the command systemd-analyze, and/or systemd-analyze blame, and systemd-analyze critical-chain to see some interesting boot info.​
    Copy/paste each ones output in your reply (put the output between CODE tags (the # icon)
      It will be on here in the morning.
        vince@steven-tobefilledbyoem:~$ systemd-analyze
        Startup finished in 10.085s (firmware) + 30.462s (loader) + 1.907s (kernel) + 1min 33.031s (userspace) = 2min
        15.488s
        graphical.target reached after 1min 33.018s in userspace.
        vince@steven-tobefilledbyoem:~$ systemd-analyze blame
        2min 43.518s fstrim.service
        1min 25.682s systemd-udev-settle.service
        8.200s apt-daily.service
        5.437s NetworkManager-wait-online.service
        2.512s fwupd.service
        2.496s apt-daily-upgrade.service
        2.191s thermald.service
        1.118s NetworkManager.service
        1.004s home-vince-Mount-Steam1.mount
        824ms dev-sdc2.device
        647ms man-db.service
        586ms apport.service
        555ms snapd.seeded.service
        479ms snapd.service
        435ms apparmor.service
        424ms dev-loop1.device
        405ms dev-loop2.device
        363ms e2scrub_reap.service
        359ms systemd-journal-flush.service
        341ms accounts-daemon.service
        336ms logrotate.service
        335ms systemd-tmpfiles-setup.service
        335ms systemd-binfmt.service
        325ms plymouth-read-write.service
        321ms udisks2.service
        319ms console-setup.service
        310ms ufw.service
        303ms dev-loop5.device
        299ms dev-loop6.device
        298ms dev-loop4.device
        286ms rsyslog.service
        281ms power-profiles-daemon.service
        278ms apport-autoreport.service
        275ms smartmontools.service
        272ms polkit.service
        262ms dev-loop3.device
        234ms avahi-daemon.service
        233ms user@1000.service
        231ms gpu-manager.service
        211ms grub-common.service
        200ms dbus.service
        190ms dev-loop7.device
        183ms systemd-udev-trigger.service
        177ms dev-loop10.device
        175ms switcheroo-control.service
        169ms systemd-logind.service
        168ms systemd-modules-load.service
        157ms update-notifier-download.service
        152ms dev-loop0.device
        142ms plymouth-quit.service
        133ms ModemManager.service
        128ms sysstat.service
        127ms dev-loop8.device
        120ms upower.service
        111ms systemd-resolved.service
        109ms sysstat-summary.service
        107ms keyboard-setup.service
        104ms fwupd-refresh.service
        102ms dev-loop9.device
        94ms systemd-journald.service
        88ms systemd-udevd.service
        83ms wpa_supplicant.service
        71ms snapd.apparmor.service
        61ms lvm2-monitor.service
        61ms dpkg-db-backup.service
        57ms nvidia-persistenced.service
        57ms systemd-timesyncd.service
        56ms grub-initrd-fallback.service
        52ms systemd-random-seed.service
        48ms snap-bare-5.mount
        47ms snap-core22-1380.mount
        44ms snap-firefox-4630.mount
        43ms systemd-fsck@dev-disk-by\x2duuid-1ECC\x2d72A0.service
        41ms plymouth-start.service
        40ms snap-firefox-4650.mount
        39ms snap-firmware\x2dupdater-127.mount
        38ms dev-hugepages.mount
        37ms dev-mqueue.mount
        37ms snap-gnome\x2d42\x2d2204-176.mount
        37ms sys-kernel-debug.mount
        36ms systemd-tmpfiles-clean.service
        36ms systemd-tmpfiles-setup-dev.service
        35ms snap-gtk\x2dcommon\x2dthemes-1535.mount
        34ms sys-kernel-tracing.mount
        33ms systemd-remount-fs.service
        29ms kerneloops.service
        28ms snap-snapd-21465.mount
        28ms modprobe@drm.service
        28ms kmod-static-nodes.service
        27ms cups.service
        26ms modprobe@fuse.service
        25ms snap-snapd-21759.mount
        25ms systemd-tmpfiles-setup-dev-early.service
        25ms modprobe@configfs.service
        24ms snap-thunderbird-490.mount
        23ms home.mount
        21ms snap-thunderbird-497.mount
        20ms alsa-restore.service
        19ms boot-efi.mount
        18ms var-snap-firefox-common-host\x2dhunspell.mount
        17ms rtkit-daemon.service
        17ms update-notifier-motd.service
        16ms proc-sys-fs-binfmt_misc.mount
        16ms tmp.mount
        14ms sys-fs-fuse-connections.mount
        14ms user-runtime-dir@1000.service
        14ms swap-swapfile.swap
        11ms systemd-update-utmp.service
        11ms systemd-update-utmp-runlevel.service
        11ms swap.mount
        9ms systemd-sysctl.service
        9ms sys-kernel-config.mount
        8ms setvtrgb.service
        7ms modprobe@efi_pstore.service
        7ms systemd-user-sessions.service
        7ms snapd.socket
        6ms modprobe@loop.service
        5ms sysstat-collect.service
        4ms motd-news.service
        3ms modprobe@dm_mod.service
        3ms sddm.service
        22us blk-availability.service
        vince@steven-tobefilledbyoem:~$ ^[[200~systemd-analyze critical-chain~
        systemd-analyze: command not found
          Big typo in that third command. You copied and pasted it from the browser rather than typing it.
          This will never run: ^[[200~systemd-analyze critical-chain~
          This will: systemd-analyze critical-chain
          The "fstrim" service is taking a very long time. Usually, it settles downs after completing a full run on the device.
          If not, you could turn off the service if it does this every boot. Then manually run trim using a cron job or adding "discard" option to fstab.
            The time when unit became active or started is printed after the "@" character.
            The time the unit took to start is printed after the "+" character.
            graphical.target @1min 32.239s
            └─multi-user.target @1min 32.239s
            └─kerneloops.service @1min 32.213s +24ms
            └─network-online.target @1min 32.202s
            └─NetworkManager-wait-online.service @1min 27.523s +4.679s
            └─NetworkManager.service @1min 26.351s +1.164s
            └─dbus.service @1min 26.199s +108ms
            └─basic.target @1min 26.186s
            └─sockets.target @1min 26.186s
            └─snapd.socket @1min 26.178s +7ms
            └─sysinit.target @1min 26.168s
            └─systemd-udev-settle.service @508ms +1min 25.658s
            └─systemd-udev-trigger.service @330ms +174ms
            └─systemd-udevd-kernel.socket @294ms
            └─system.slice @269ms
            └─-.slice @269ms
            Why is so much stuff taking so ling?
              A Google search has me thinking a user service is set up as a system service. I haven't changed anything lately so possibly a bad update. Could it have something to do with the Linux firmware?
                A Google search
                No link or evidence that support this? We can't give hints related to this without info. Sigh.
                What does it being a user vs system service have to do with it?
                The only thing that is taking time is the running of fstrim
                All the other things that add significant time (the red + numbers) are related to this (systemd-udev-settle.service is waiting for the trim to finish iirc)
                Is this running with every boot?
                If so, it may be worth disabling the fstrim service as oshunluvr mentions.
                Or maybe look at why it needs to trim very often. Lot and lots of large file deletes, etc?
                Lots of snapshot rollbacks to points where a trim is scheduled/necessary?
                Just random guesses.
                The issue is not *buntu specific, and I wonder if it could be a drive issue.
                  Yes it happens with every boot. 100% of the time also with every re-log.
                    How do I turn off a service at boot time?
                      I did a Google search. Is the following command correct for Kubuntu 24.04? systemctl disable service​
                      Source _= https://superuser.com/questions/2038...-auto-starting
                        But also
                        systemctl mask service.
                          But also
                          What is the difference?
                            You need to use both to prevent other services from running or calling the disabled service as a dependency.
                            Disabling just prevents it from running automatically on its own during boot.
                            Here's a better description
                            https://askubuntu.com/questions/8162...temctl-disable
                              Yesterday's update seems to have fixed this. I am guessing since I use BTRFS then one or more of the BTRFS fixes must have fixed this issue.
