I have a Lan Problem
    hi all, for some reason my lan driver is not working but here is where it gets a little strange my wifi is working, ill give you as much information as i can.
    network UNCLAIMED
    description: Ethernet controller
    product: RTL8125 2.5GbE Controller
    vendor: Realtek Semiconductor Co., Ltd.
    physical id: 0
    bus info: pci@0000:09:00.0
    version: 05
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi pciexpress msix vpd bus_master cap_list
    configuration: latency=0
    resources: ioport:e000(size=256) memory:fc900000-fc90ffff memory:fc910000-fc913fff
    Operating System: Kubuntu 22.04
    KDE Plasma Version: 5.24.7
    KDE Frameworks Version: 5.92.0
    Qt Version: 5.15.3
    Kernel Version: 6.5.0-41-generic (64-bit)
    Graphics Platform: X11
    Processors: 12 × AMD Ryzen 5 5600G with Radeon Graphics
    Memory: 31.1 GiB of RAM
    Graphics Processor: AMD Radeon RX 6650 XT​
    i cant for love or money seem to get the lan connection to work but the wifi is wokring, and yes i have tried diabling wifi and i am left with no network connection.
    ive tried the following
    clean installing kububtu 24
    clean installing kubuntu 23..10
    clean installing kubuntu 22.04
    dowloding from the realtek website it gives me the following error.
    yoda@Yodas-PC:~/Downloads/r8168-master$ sudo ./autorun.sh
    [sudo] password for yoda:
    Check old driver and unload it.
    Build the module and install
    warning: the compiler differs from the one used to build the kernel
    The kernel was built by: x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
    You are using: gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
    Skipping BTF generation for /home/yoda/Downloads/r8168-master/src/r8168.ko due to unavailability of vmlinux
    Warning: modules_install: missing 'System.map' file. Skipping depmod.
    DEPMOD 6.5.0-41-generic
    load module r8168
    Updating initramfs. Please wait.
    update-initramfs: Generating /boot/initrd.img-6.5.0-41-generic
    W: Possible missing firmware /lib/firmware/amdgpu/ip_discovery.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/vega10_cap.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_cap.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/navi12_cap.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_6_ta.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_6_sos.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_cap.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_sjt_mec2.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_sjt_mec.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/gc_9_4_3_rlc.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/gc_9_4_3_mec.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_0_toc.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/sdma_4_4_2.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_mes1.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_mes.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/navi10_mes.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_mes.bin for module amdgpu
    W: Possible missing firmware /lib/firmware/amdgpu/vcn_4_0_3.bin for module amdgpu
    Completed.
    has any one any idea what is going wrong with the LAN driver
    Tutorials:
    Yoda's ownCloud Installation on Kubuntu 20.04
    I have the exact same ethernet and no issues here. Enter this: lspci -vv and look at the Ethernet part;
    27:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 04)
    Subsystem: Micro-Star International Co., Ltd. [MSI] RTL8125 2.5GbE Controller
    Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0, Cache Line Size: 64 bytes
    Interrupt: pin A routed to IRQ 39
    IOMMU group: 27
    Region 0: I/O ports at f000 [size=256]
    Region 2: Memory at fc800000 (64-bit, non-prefetchable) [size=64K]
    Region 4: Memory at fc810000 (64-bit, non-prefetchable) [size=16K]
    Capabilities: <access denied>
    Kernel driver in use: r8169
    Kernel modules: r8169​
      RTL8125 been supported by the kernel since 5.4
        IOMMU group: 27
        here is the ethernet portion of the output
        09:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 05)
        Subsystem: ASUSTeK Computer Inc. RTL8125 2.5GbE Controller
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Interrupt: pin A routed to IRQ 255
        IOMMU group: 13
        Region 0: I/O ports at e000 [size=256]
        Region 2: Memory at fc900000 (64-bit, non-prefetchable) [size=64K]
        Region 4: Memory at fc910000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [40] Power Management version 3
        Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
        Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
        Address: 0000000000000000 Data: 0000
        Masking: 00000000 Pending: 00000000
        Capabilities: [70] Express (v2) Endpoint, MSI 01
        DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 26.000W
        DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
        MaxPayload 128 bytes, MaxReadReq 512 bytes
        DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
        LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 <64us
        ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
        LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
        LnkSta: Speed 5GT/s (ok), Width x1 (ok)
        TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
        DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR+
        10BitTagComp- 10BitTagReq- OBFF Via message/WAKE#, ExtFmt- EETLPPrefix-
        EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
        FRS- TPHComp+ ExtTPHComp-
        AtomicOpsCap: 32bit- 64bit- 128bitCAS-
        DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- OBFF Disabled,
        AtomicOpsCtl: ReqEn-
        LnkCap2: Supported Link Speeds: 2.5-5GT/s, Crosslink- Retimer- 2Retimers- DRS-
        LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
        Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
        Compliance De-emphasis: -6dB
        LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
        EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
        Retimer- 2Retimers- CrosslinkRes: unsupported
        Capabilities: [b0] MSI-X: Enable- Count=32 Masked-
        Vector table: BAR=4 offset=00000000
        PBA: BAR=4 offset=00000800
        Capabilities: [d0] Vital Product Data
        pcilib: sysfs_read_vpd: read failed: No such device
        Not readable
        Capabilities: [100 v2] Advanced Error Reporting
        UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
        UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
        UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
        CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
        CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
        AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
        MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
        HeaderLog: 00000000 00000000 00000000 00000000
        Capabilities: [148 v1] Virtual Channel
        Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
        Arb: Fixed- WRR32- WRR64- WRR128-
        Ctrl: ArbSelect=Fixed
        Status: InProgress-
        VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
        Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
        Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=01
        Status: NegoPending- InProgress-
        Capabilities: [168 v1] Device Serial Number 01-00-00-00-68-4c-e0-00
        Capabilities: [178 v1] Transaction Processing Hints
        No steering table available
        Capabilities: [204 v1] Latency Tolerance Reporting
        Max snoop latency: 0ns
        Max no snoop latency: 0ns
        Capabilities: [20c v1] L1 PM Substates
        L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
        PortCommonModeRestoreTime=150us PortTPowerOnTime=150us
        L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
        T_CommonMode=0us LTR1.2_Threshold=0ns
        L1SubCtl2: T_PwrOn=10us
        Capabilities: [21c v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
        Tutorials:
          and the portion of the output relating to my Onboard Wireless
          08:00.0 Network controller: MEDIATEK Corp. MT7921 802.11ax PCI Express Wireless Network Adapter
          Subsystem: AzureWave Device 4680
          Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
          Interrupt: pin A routed to IRQ 102
          IOMMU group: 13
          Region 0: Memory at e0300000 (64-bit, prefetchable) [size=1M]
          Region 2: Memory at e0400000 (64-bit, prefetchable) [size=16K]
          Region 4: Memory at e0404000 (64-bit, prefetchable) [size=4K]
          Capabilities: [80] Express (v2) Endpoint, MSI 00
          DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
          ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 26.000W
          RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
          DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
          LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <8us
          ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
          10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt+ EETLPPrefix-
          FRS- TPHComp- ExtTPHComp-
          Capabilities: [e0] MSI: Enable+ Count=1/32 Maskable+ 64bit+
          Address: 00000000fee00000 Data: 0000
          Masking: fffffffe Pending: 00000000
          Capabilities: [f8] Power Management version 3
          Flags: PMEClk- DSI+ D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
          Capabilities: [100 v1] Vendor Specific Information: ID=1556 Rev=1 Len=008 <?>
          Capabilities: [108 v1] Latency Tolerance Reporting
          Capabilities: [110 v1] L1 PM Substates
          PortCommonModeRestoreTime=3us PortTPowerOnTime=28us
          Capabilities: [200 v2] Advanced Error Reporting
          UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP+ ECRC- UnsupReq- ACSViol-
          AERCap: First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap- ECRCChkEn-
          Kernel driver in use: mt7921e
          Kernel modules: mt7921e
          Tutorials:
            What's this?
            Did you add that? The correct driver is:
              load module r8168​
              I'm unclear as to why your installing the wrong driver when the correct one is built into the kernel.
                What's this?
                the mt7921e is the wireless module that is built into my motherbord
                the lan driver was working before the update to 6.0.5.35-generic and now it does not so i have been searching for the correct driver for this lan port which is bunled into my motherboard the ASUS TUF GAMING B550-PLUS WiFi II AMD B550 WiFi 6 ATX Motherboard
                Tutorials:
                  Oh, I see. I didn't realize you included info from the wifi card. It's really not relevant at all to why your Ethernet port isn't working.
                  Well, based on what you posted, IMO the kernel is NOT assigning the any driver to your Ethernet port.
                  If it just started with the -35 kernel, then boot to an earlier one. No need to "search" for anything, just boot to a working kernel.
                  I would uninstall the r8168 driver and undo whatever you did with it as I don't believe that's the right one to attempt to use and will probably cause problems later.
                  It's odd that my, same Ethernet port works fine with -35. Are you sure you installed all the kernel add-ons?
                  stuart@office:~$ dpkg -l |grep 6.5.0-35 |awk '{print $2}'
                  linux-headers-6.5.0-35-generic
                  linux-hwe-6.5-headers-6.5.0-35
                  linux-image-6.5.0-35-generic
                  linux-modules-6.5.0-35-generic
                  linux-modules-extra-6.5.0-35-generic​
                    Originally posted by hightokeinyoda View Post
                    . hi all, for some reason my lan driver is not working but here is where it gets a little strange my wifi is working, ill give you as much information as i can.
                    Has it ever worked?
                    Wifi is completely unrelated to Ethernet in both hardware and drivers.
                    Have you looked at your BIOS settings for anything related to the hardware? Is your BIOS up to date? It not working on three Ubuntu releases using two different kernel versions points at a hardware problem, so a BIOS setting might be the first thing to investigate.
                    . here is the ethernet portion of the output
                    Note that your output shows no driver in use, compared to what it shows for the WiFi card. Compiling and installing the likely outdated driver code may have caused that. I'm not sure if this driver installs to the same location as the built in driver or not, so I can't say if it replaced that original driver or not. Uninstalling the new may not restore the original.
                      Has it ever worked?
                      the lan port works flawlesly under windows 10 & 11 and i can confirm that its works using the Kubuntu Live CD's
                      then a system update seems to make the lan disapear.
                      now it is quite posible that in my attempt to fix what apeard to be a missing driver that i may have removed the one that came with the system which had stopped working and the ones i have tried to install are for a lower kenrel.
                      with these points in mind ive been thinking.
                      would a purge of the 6.5.0-35-generic kernel followed by a reinstalation of said kernel help
                      it seems odd that apt would remove a vital driver if no others was to be installed in its place or am i missing somthing here.
                      i maye be better of doing a clean install or do you guys think this is salvageable
                      Tutorials:
                        First, as oshunluvr said/asked, boot to a prior kernel to ensure/verify that all works as expected. Assuming that it does, you could then purge the suspected kernel (while still in the booted 'prior' kernel) and then reinstall it and then reboot into it and test.
                          sorry i was ment to do that but i totaly forgot, my advanced options for Kubunutu menu in grub is only showing kernel 6.5.0.35-generic abd 6.5.0.41-generic along with thier respective recovery modes.
                          alas i tried both kernels to be sure and still no lan driver been picked up
                          Kernel 6.50.0.41-generic is giving this output for sudo lshw -c network
                          *-network UNCLAIMED
                          physical id: 0
                          version: 05
                          width: 64 bits
                          clock: 33MHz
                          yoda@Yodas-PC:~$
                          i suspect that in my misguided attempts to fix this problem i may have made a whoper of a mess i apreciate all the help i am reciving this is one of the qualitys that make Kubuntu a user friendly distro.
                          is there any other routes of investigation as to how to fix this?
                          Kind Regarda
                          Yoda
                          Last edited by hightokeinyoda; Jun 20, 2024, 04:58 PM. Reason: i forgot to include wiche kernel i was showing the lshw output
                          Tutorials:
                            well this is strange i downloaded the driver from the realtek website and ran the installer script on the 6.5.0-41-generic kernel and now the ethernet is working.
                            Thanks again for all your help
                            Tutorials:
                              This question/answer is just under two years old, but does involve a non-working RTL8125 ethernet controller in Ubuntu: https://askubuntu.com/questions/1423...th-kernel-5-15 The answer may be worth pursuing.
