Monitor is going to sleep after splash screen
This topic has been answered.
    [Post-Install] Monitor is going to sleep after splash screen
    Hi everyone,
    I have an issue with KDE + Wayland (X11 works normally). I can’t run any recent KDE + Wayland distribution (KDE + Wayland + Debian 12 is ok (kernel 6.1)).
    ISSUE: After the splash screen, the monitor goes to sleep. The system itself is still running — for example, I can access it through TTY (and the monitor wakes up again after switching to a TTY). In KDE, there is no active display in "echo $DISPLAY" (it returns blank).
    GNOME works normally, and I’m currently using Ubuntu 26.04 LTS (even though I love Kubuntu!).​
    My setup:
    System:
    Host: luciano-X99-B9 Kernel: 7.0.0-15-generic arch: x86_64 bits: 64
    Desktop: GNOME v: 50.1 Distro: Ubuntu 26.04 (Resolute Raccoon)
    Machine:
    Type: Desktop Mobo: MACHINIST model: X99 B9 serial: <superuser required>
    Firmware: UEFI vendor: American Megatrends v: 5.11 date: 06/07/2024
    CPU:
    Info: 14-core Intel Xeon E5-2680 v4 [MT MCP] speed (MHz): avg: 1200
    min/max: 1200/3300
    Graphics:
    Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] driver: amdgpu v: kernel
    Display: wayland server: X.Org v: 24.1.10 with: Xwayland v: 24.1.10
    compositor: gnome-shell driver: dri: radeonsi gpu: amdgpu
    resolution: 1920x1080~60Hz
    API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.3-1ubuntu1
    renderer: AMD Radeon RX 570 Series (radeonsi polaris10 ACO DRM 3.64
    7.0.0-15-generic)
    Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: corectrl x11: xdriinfo,
    xdpyinfo, xprop, xrandr
    Network:
    Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    driver: r8169
    Drives:
    Local Storage: total: 1.35 TiB used: 63.36 GiB (4.6%)
    Info:
    Memory: total: 64 GiB available: 61.63 GiB used: 3.44 GiB (5.6%)
    Processes: 497 Uptime: 25m Shell: Bash inxi: 3.3.40
  • Answer selected by srllucas at May 23, 2026, 12:50 PM.
    Update,
    I’ve changed the monitor’s cable (I used to have a HDMI, and switched it by a DisplayPort). There is no issue anymore.​
    Thank you for the support.
      Before it loads up KDE you should see the login screen (SDDM). Can you confirm the login screen is showing up?
        The monitor goes to sleep before the SDDM... the splash apears in low resolution, than the video driver is loaded and it changes to high resolution... few seconds after, the monitor goes to sleep...
          At GRUB: Press e on the boot entry and add this to the linux line:
          ​amdgpu.dc=0
          Then boot with Ctrl+X.
          If KDE Wayland then works we can make it permanant,let us know
          ʟɨռʊӼ ʄօʀ ʟɨʄɛ
            ​amdgpu.dc=0
            I already tried it... same behaviour
              ok next , from a TTY:
              run these
              mkdir -p ~/.config/environment.d
              nano ~/.config/environment.d/kwin.conf​
              put this inside KWIN_DRM_NO_AMS=1
              save (ctrl+O - enter - ctrl+X) , and reboot
              ʟɨռʊӼ ʄօʀ ʟɨʄɛ
                Originally posted by srllucas View Post
                Hi everyone,
                There is no X11 installed on a fresh Kubuntu 26.04 so I haven't tried this yet. It would be interesting to know if you could set SDDM to run in X11 and then try to continue to a Wayland desktop.
                  run these
                  Again, splash screen and monitor goes to sleep.
                  TTY stays available.
                  Another information is that I can’t use the live-pendrive mode without using the “safe graphics” mode. Without it, i have the same behavior.
                  I’m quite confused. I’ve installed the gdm3 over kubuntu. It worked, and I’m able to access the system through the Ubuntu graphical interface. This sounds like the combination of kwin + my hardware + wayland holds the key of this issue.
                    Yeah, X11 packages are not available in 26.04 repositories.
                      ​amdgpu.dc=0
                      This solution makes even TTY out...
                        Yes, they are, just not installed by default:
                        sudo apt update
                        sudo apt install xorg -y
                        sudo apt install plasma-session-x11 -y
                        Then log out​ and select X11 session to log in.
                          sudo apt update
                          I really didn't know that! For sure I will try it.
                          I didn’t find it before, for the reason I was searching in a live-pendrive session. Obviously, it wouldn’t find the package…
                          • oshunluvr
                            oshunluvr commented
                            Editing a comment
                            Yes exactly. The ISO probably does not have X11 included.
                          • oshunluvr
                            oshunluvr commented
                            Editing a comment
                            FYI, I tested desktop switching in a VM and it works, but going from X11 back to Wayland results in no panel in the Wayland session. I have to reboot to get a functional Wayland session.
                          I will not try "wayland + kubuntu + my hardware" at this moment. I will keep using "Ubuntu + Wayland". Using X11 with 26.04 LTS can cause future problems too, once X11 is not the focus of Cannonical anymore. At least I've learn new things lol. Thank You all.
                            Update,
                              Not the case with my laptop. Logging out from Wayland and logging in using X11 still gives me my panel, and vice versa.
