Monitor is going to sleep after splash screen
This topic has been answered.
    Not the case with my laptop. Logging out from Wayland and logging in using X11 still gives me my panel, and vice versa.
    Testing in a VM, I was able to confirm oshunluvr 's experience here,
    I can also verify this on my PC, as I also lose the panel there until I reboot (Kubuntu 26.04 + Kubuntu Backports = Plasma 6.6.5). The Panel still shows up in the "Manage Panels" config in edit mode, though. It is an odd one, but since I never switch between the two display servers except for this sort of test, it is not an issue for me.
    I assume it is a Plasma related issue, but I have not looked to dig up any relevant bug reports on it yet. Or create one.
    I should check it out on my main PC (neon) but I imagine it will be the same.
    .......nope, on this PC, same Plasma version, it does not happen.
    neon does have a newer Frameworks version, but Plasma and Qt are identical.
    The Kubuntu PC is an older Intel with integratefd graphics, the neon box is AMD with Intel Arc GPU
