Every time I install a Linux distro, Grub fails one way or another. Kubuntu 13.04 was no different. This time the installation crashed with the following message: Executing 'grub-install /dev/sda' failed. I'm not surprised it failed, since sda has a dynamic NTFS partition, and is not the boot HD. On my system, sda is where I have my games, sdb is Windows 7, sdc is storage and linux partitions, so I'm surprised the installation tried to install it on sda.
To make matters worse, I recently had to install a new DVD-drive, which I am unable to boot from. It works perfectly inside any operating system, but BIOS doesn't detect it. Can anyone understand why? To make things even worse, my SanDisk usb stick has some kind of U3 system that prevents me from booting from it. I have another, tiny, USB stick that works fine (but can't fit an ISO on it). All the recommended ways of making the SanDisk stick bootable has not worked for me.
By using the Kubuntu boot helper or wassisname, I was able to get into the Kubuntu Live environment and start the installation. I tried to fix the problem with the grub-install /dev/sdb command, but all that happened was that I booted the computer into a Grub command line... The only thing I can think of is if I made a typo or something, like typing /dev/hdb instead of /dev/sdb or something, but that would probably give me an error message, right?
