Sound though HDMI/Displayport not working - nVidia audio
    An update if anyone is following this thread...
    OK, so I found a workaround for the nouveau driver and its locking up issue. Adding "nouveau.noaccel=1" to the boot line stops the lock ups. It also kills desktop effects but at least I can use KDEneon again. It's noticeably jerky when re-positioning windows, etc., but useable.
    I may try to go back to the nvidia driver, but an older version to see if audio becomes available. I'm hoping updates will come down that solve it. There's not a lot of locateable info out there on this (the HDMI audio) issue.
    Interestingly, I was using Manjaro with the nouveau driver because it had sound, but system notifications didn't work. I don't have time right now to run down separate issues in two distros so I'll leave it be for now.
    With both distros there's an odd lag whenever audio starts. I pinned it to a lag because I could go to the device testing in System Settings > Multimedia and when I clicked "Front Left" all I hear is "Left" but if I press it again I hear the full "Front Left" response. I only hear this through the HDMI audio, not the built-in audio.
      sorry to hear your trouble my friend ,,,,,,,all I can offer is I'm having no problem with HDMI audio with Nvidia drivers or nouveau ,,,,,in this system it's nouveau (neon-LTS)
      vinny@vinny-Bonobo-Extreme:~$ inxi -G
      Graphics:  Card: NVIDIA GK104M [GeForce GTX 860M]
              Display Server: X.Org 1.18.4 drivers: nouveau (unloaded: fbdev,vesa) Resolution: 1920x1080@60.01hz
              GLX Renderer: Gallium 0.4 on NVE4 GLX Version: 3.0 Mesa 12.0.6
      vinny@vinny-Bonobo-Extreme:~$ inxi -A
      Audio:     Card-1 Intel 8 Series/C220 Series High Definition Audio Controller driver: snd_hda_intel
              Card-2 NVIDIA GK104 HDMI Audio Controller driver: snd_hda_intel
              Sound: Advanced Linux Sound Architecture v: k4.8.0-54-generic
      vinny@vinny-Bonobo-Extreme:~$ pactl list sources
      Source #0
            State: SUSPENDED
            Description: Monitor of GK104 HDMI Audio Controller Digital Stereo (HDMI)
            Driver: module-alsa-card.c
            Sample Specification: s16le 2ch 48000Hz
            Channel Map: front-left,front-right
            Owner Module: 6
            Mute: no
            Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
                    balance 0.00
            Base Volume: 65536 / 100% / 0.00 dB
            Monitor of Sink: alsa_output.pci-0000_01_00.1.hdmi-stereo
            Latency: 0 usec, configured 0 usec
            Flags: DECIBEL_VOLUME LATENCY
            Properties:
                    device.description = "Monitor of GK104 HDMI Audio Controller Digital Stereo (HDMI)"
                    device.class = "monitor"
                    alsa.card = "1"
                    alsa.card_name = "HDA NVidia"
                    alsa.long_card_name = "HDA NVidia at 0xec080000 irq 17"
                    alsa.driver_name = "snd_hda_intel"
                    device.bus_path = "pci-0000:01:00.1"
                    sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
                    device.bus = "pci"
                    device.vendor.id = "10de"
                    device.vendor.name = "NVIDIA Corporation"
                    device.product.id = "0e0a"
                    device.product.name = "GK104 HDMI Audio Controller"
                    device.string = "1"
                    module-udev-detect.discovered = "1"
                    device.icon_name = "audio-card-pci"
            Formats:
                    pcm
      Source #1
            State: SUSPENDED
            Description: Monitor of Built-in Audio Analog Stereo
            Sample Specification: s16le 2ch 44100Hz
            Owner Module: 7
            Mute: no
                    balance 0.00
            Monitor of Sink: alsa_output.pci-0000_00_1b.0.analog-stereo
            Properties:
                    device.description = "Monitor of Built-in Audio Analog Stereo"
                    alsa.card = "0"
                    alsa.card_name = "HDA Intel PCH"
                    alsa.long_card_name = "HDA Intel PCH at 0xec310000 irq 33"
                    device.bus_path = "pci-0000:00:1b.0"
                    sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
                    device.bus = "pci"
                    device.vendor.id = "8086"
                    device.vendor.name = "Intel Corporation"
                    device.product.id = "8c20"
                    device.product.name = "8 Series/C220 Series Chipset High Definition Audio Controller"
                    device.form_factor = "internal"
                    device.string = "0"
            Formats:
                    pcm
      Source #2
            State: SUSPENDED
            Description: Built-in Audio Analog Stereo
            Owner Module: 7
            Mute: no
            Volume: front-left: 32845 /  50% / -18.00 dB,   front-right: 32845 /  50% / -18.00 dB
                    balance 0.00
            Base Volume: 20724 /  32% / -30.00 dB
            Monitor of Sink: n/a
            Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
            Properties:
                    alsa.resolution_bits = "16"
                    device.api = "alsa"
                    device.class = "sound"
                    alsa.class = "generic"
                    alsa.subclass = "generic-mix"
                    alsa.name = "ALC892 Analog"
                    alsa.id = "ALC892 Analog"
                    alsa.subdevice = "0"
                    alsa.subdevice_name = "subdevice #0"
                    alsa.device = "0"
                    alsa.card = "0"
                    device.bus = "pci"
                    device.string = "front:0"
                    device.buffering.buffer_size = "65536"
                    device.buffering.fragment_size = "32768"
                    device.access_mode = "mmap+timer"
                    device.profile.name = "analog-stereo"
                    device.profile.description = "Analog Stereo"
                    device.description = "Built-in Audio Analog Stereo"
                    alsa.mixer_name = "Realtek ALC892"
                    alsa.components = "HDA:10ec0892,15580379,00100302"
            Ports:
                    analog-input-internal-mic: Internal Microphone (priority: 8900)
                    analog-input-mic: Microphone (priority: 8700, not available)
                    analog-input-linein: Line In (priority: 8100, not available)
            Active Port: analog-input-internal-mic
            Formats:
                    pcm
        Thanks Vinny, I actually think it's a kernel confliction with the driver. I did a new KDEneon install and audio works with nouveau and no crashing. I'm using 4.10 but the newest KDEneon ISO uses 4.8.
          Ok, so I got tired of the nouveau driver always heating up my CPU so I rolled up my sleeves. I installed 5 kernels and went back to the nvidia driver but I started at 340 series. The first try: Kernel 4.10.0-27-generic and nvidia-340.102 and the audio worked!
          So I guess I'll just stick to the older driver until something else makes me change.
