Speed up apt-get
    Speed up apt-get
    Found this over on Ubuntu Geek. Try it out and watch your downloads fly. Could be especially useful to the bandwidth challenged.
    http://www.ubuntugeek.com/apt-fast-a...-upgrades.html
    Re: Speed up apt-get
    Late reply, yes, but have you installed and tested this? Is it really faster than without it?
      Yes, I am using it on both Lucid and Maverick. It works great!! Try it!! Watch those downloads fly!
        Well, the update seemed to go MUCH faster.
          Using apt-fast. Not sure how many pipes I should use. I have a 150Mbps connection (I love Brighthouse)so pretty much everything is fast anyway
            My connection is 25 Mb/s but TW limits my DL speed to around 2.8 Mb/s.
            Apt-get regularly hits that cap, so I don't see how pipes would help.
              Ditto on what GG says other than I only have 18Mbps.
                Huh, that Axel utility is pretty cool.
                steve@t520:~/junk$ [B]axel -a http://mirror.pnl.gov/fedora/linux/releases/21/Workstation/x86_64/iso/Fedora-Live-Workstation-x86_64-21-5.iso[/B]
                Initializing download: http://mirror.pnl.gov/fedora/linux/releases/21/Workstation/x86_64/iso/Fedora-Live-Workstation-x86_64-21-5.iso
                File size: 1472200704 bytes
                Opening output file Fedora-Live-Workstation-x86_64-21-5.iso
                Starting download
                Connection 0 finished                                                          ]
                Connection 1 finished                                                          ]
                Connection 3 finished                                                          ]
                [100%] [..................................................] [  56.2MB/s] [00:00]
                Downloaded 1404.0 megabytes in 24 seconds. (57582.02 KB/s)
                steve@t520:~/junk$ [B]axel -a -n 10 http://mirror.pnl.gov/fedora/linux/releases/21/Workstation/x86_64/iso/Fedora-Live-Workstation-x86_64-21-5.iso[/B]
                Starting download
                Connection 5 finished                                                          ]
                Connection 8 finished                                                          ]
                Connection 2 finished                                                          ]
                Connection 7 finished                                                          ]
                Connection 6 finished                                                          ]
                Connection 9 finished                                                          ]
                [100%] [..................................................] [  70.1MB/s] [00:00]
                Downloaded 1404.0 megabytes in 20 seconds. (71817.56 KB/s)
                Nearly a gig and half in 20 seconds. Not bad!
                  Starting download
                  Starting download
                  ya that is cool ,,,,,,,,,braking the DL into multiple streams ,,,,,,,like bit-torrent kinda hay .
                  installing
                    Old script though - 4.5 years is a couple lifetimes in the linux world. I guess I could adapt it to apt, but it would be cool to code axel into muon, right?
                    Anyone else here old enough to remember when a similar program (no way can I remember what it was called) was in use back in the bbs/14.4K modem days? Man, you could download a whole 140K Apple II floppy disk image in mere minutes!
                      BTW, everyone: Don't compare your speeds to Steve's. He's got like a million megabit connection.
                      The ONLY reason I'd consider moving back to Kansas City is they got Google Fiber.
                        I remember using QModem, which was a front end to ZMODEM on my 56K modem. The max DL speed was about 48K but with compression and after-the-fact packet checking it was rather quick.
                        On Linux I used to use prozilla but switched to aria2, which allows controlling the number of threads, but now use wget.
                        Prozilla hasn't been compiled since 2013, so I don't use it any more. But, it was the easiest and fastest tool to use and kept a database of sites I frequented to download, including the source directory structure and my destination file structure.
                        https://launchpad.net/~tahutek-team/...buntu/prozilla
                          As Jerry mentioned, you're recalling ZMODEM, which introduced the notion of sliding windows to BBS file transfer protocols.
                          Speaking of ancient datacomms... check out this pristine, working example of a Livermore Data Systems Model A Acoustic Coupler from 1964!
                            I didn't know they had laptops in 1964?
                              Watch the video. The acoustic coupler is in the brown box behind the guy's arm. The laptop in the video is also old (not from 1964, of course) -- he says finding a laptop with a serial port was a challenge.
