Mouse cursor going opposite directions on vertical & horizontal axis
    My Kubuntu kernel is 26.04 and I updated from 24.04 two weeks ago. The issue did not occur after the upgrade to 26.04 but later as I allowed some system updates that come daily. Although I'm not sure it's related to the update. Can't remember what update it was.
    After I restarted the laptop, the mouse started to malfunction. I thought it was the mouse itself but I noticed that other people had the same issue as mine. When I move the cursor to the right it goes up. When I move up it goes to the left and so on. It can also stop cooperating and freeze except for the right mouse function that still works with contextual menus.
    It's a dual mode mouse as written below it. I use it with a dungle if I remember the word correctly and it can be loaded via cable.
    Not sure what else I could provide as data to help. Thanks in advance.
