are "modular" power supply SATA power cables interchangeable?
    Last night, while in use, my desktop shut off and wouldn't power on. Going through my limited repertoire of things to try, I bumped the CPU power socket and the computer came on (at which point I got backups in order). Then it didn't, and after a bunch of cable reseating, on once more, then not. Diagnosis, failed or failing power supply, off to get a new one.
    The new supply came with 3 sockets for SATA power, but only two such cables. The sockets are the same as the old power supply. By same I mean the same combination of square, rounded, and half-rounded sockets, so that the old power supply's SATA power cables will fit. Can I use one of the old cables safely?
    The sockets and connectors may be the same but the pins may be different. On my last build, I had a modular PSU, and I did need to make sure the sleeved and combed extensions (for looks) matched the brand. I believe many are identical but I would not bank on it.
    Yup:
    https://www.corsair.com/us/en/explor...les-universal/
    And many more that are recent and not from the dark ages (2019 or so)
      Thank you. I thought it was unlikely that the weird combination of shapes matched up, but one would have to know for sure.
        I never HAD to think about this. Really good to know, just in case.
        The one exception, as it points out, is the main power cable from the outlet to the PSU, and that makes sense, industry standard.
          The answer is a resounding "Nope"! And the reason is, as pointed out, there is no industry standard - yet. Oder any new cables from the PS maker, and for the specific model.
          Intel i7 11th Gen 16GB 1TB
