How to make XSCREENSAVER autostart in Kubuntu 24.04 and function normally
    To make xscreensaver function normally and auto start do the following:
    Xscreensaver requires X11 to function. If you have Wayland you need to install X11
    sudo apt update
    sudo apt-get install xorg openbox​
    Reboot computer and at login screen choose X11
    Then:
    sudo apt update
    Install xscreensaver:
    sudo apt-get install xscreensaver xscreensaver-gl-extra xscreensaver-data-extra
    Go to start button/ settings/xscreensaver settings/ and cofigure per your preferances
    In the terminal type:
    sudo chmod +x /usr/share/xscreensaver/xscreensaver.desktop
    Hit enter
    Close terminal
    Open Dolphin / Click view / check box beside "show hidden files"
    Go to '/usr/share/xscreensaver'
    Put cursor over xscreensaver.desktop and right click/ choose "copy"
    Now, go to /home/your_user_name/.config/autostart
    Right click in autostart
    Choose paste one file
    Close dolphin and reboot computer
    Xscreensaver is now working properly
    Last edited by maverick; Jan 25, 2026, 08:41 PM. Reason: edit was for spelling error
