I spent a good portion of the day getting Evolution to work smoothly on my mom's PC, so I thought I'd share my solutions here. There were three main issues I encountered: missing icons, ugly theme and a prompt for the gnome-keyring on startup. The ugly theme is because oxygen-gtk doesn't theme gtk3 apps yet (although this is in the works). I solved this by installing the Zukitwo gtk3 theme, but other gtk3 themes should work as well.
First, here are instructions that will resolve both the missing icons and the ugly theme issues:
[/list]
These changes will affect all GTK3 apps, not just Evolution.
Now, to address the gnome-keyring issue: The problem is that the gnome-keyring is not being logged into when the user logs into the desktop session. Here is what I did to solve this:[list][*]Install the following packages: gnome-keyring libpam-gnome-keyring seahorse[*]Add the following two lines to /etc/pam.d/kdm:
...but they must be added in the correct spot, so the resultant file should look like this:
[*]Add the following line to the end of /etc/pam.d/passwd:
I hope this is helpful to someone.
MERRY CHRISTMAS!
- Install the following packages: gtk3-engines-unico gtk2-engines-murrine gtk2-engines-pixbuf humanity-icon-theme
- Download the http://gnome-look.org/content/show.php/Zukitwo?content=140562"]Zukitwo theme[/url] from gnome-look.org.
- Follow the included instructions to install it (installing to ~/.themes works fine).
- Create the file /home/username/.config/gtk-3.0/settings.ini (replacing "username" with your login name) with the following contents:
[Settings] gtk-theme-name = Zukitwo gtk-fallback-icon-theme = Humanity # next option is applicable only if selected theme supports it gtk-application-prefer-dark-theme = false # set font name and dimension gtk-font-name = Ubuntu 9
auth optional pam_gnome_keyring.so try_first_pass session optional pam_gnome_keyring.so auto_start
# # /etc/pam.d/kdm - specify the PAM behaviour of kdm # auth required pam_nologin.so auth required pam_env.so readenv=1 auth required pam_env.so readenv=1 envfile=/etc/default/locale @include common-auth auth optional pam_gnome_keyring.so try_first_pass session required pam_limits.so @include common-account @include common-password @include common-session session optional pam_gnome_keyring.so auto_start
password optional pam_gnome_keyring.so
- Run seahorse and delete the default keyring and create a new keyring called “login” with a password identical to your login password. Set this as default.
- Reboot and cross your fingers, legs, etc. and hope it works. If all went well, you shouldn't be prompted to enter your keyring password.
MERRY CHRISTMAS!
