When the last 4.x iOS was released by Apple I fired up my WinXP VM, plugged in my iPod4 Touch to the USB port, and let iTunes do its thing. No problem. It's the only justification I have for keeping XP around, even as a VM.
Yesterday, I got an email saying the iOS 5.0 was available. I fired up my XP VM, plugged my iPod4 into the USB port and let iTunes do its thing. PLENTY OF PROBLEMS. I tried four times, and each time it would die with a 1602 error, which is a "problem with the USB port".
I noticed that the GTK+ iPod app kept popping up in the background, hidden by the foreground VM display and the VB app UI. And, Nautilus kept popping up too. I noticed their icons on the panel.
Between my 4.x upgrade and yesterday I had installed a Drop-box connection, which required that Nautilus be installed. Nautilus has been a perpetual pain in my side every since but because of Drop-box I ignored its constant interference every time I plugged in a USB stick or put a CD in the CDROM. Yesterday was the last straw. I uninstalled both iPod and Nautilus, and their libraries and services. iTunes had no problem upgrading my iPod4 on the fifth try.
