I want to install Xubuntu 10.04 in about 30 computers. They all have CD drives, USB ports and LAN connection however there is virtually no Internet connection in the part of Nepal where I will do this. I would like the installs to include the apps and configurations that we use at the school where these are used. The machines range in configuration from Pentium III to some dual core machines.
What are your suggestions on doing this? I will have one fast Kubuntu 10.04 machine on the LAN. I will configure it prior to going to Nepal.
Should I consider:
I appreciate any suggestions,
Ray
Should I consider:
- Proxy Server
FSArchiver (if so, can I use only one image to put in all the various machines?)
Ray
