GRUB alternative - hardware switch
    GRUB menu editing can be intimidating for the novice user. I've used GRUB for many years dual booting on 1 hard drive (my laptop) and 2 hard drives (my desktop). Although GRUB works well, it's easy to wipe it out when you're installing a new OS. I found many build-it-yourself type switches but I just wanted a quick solution. Although this switch won't help you if you're using a laptop or using a single hard drive on a desktop, it works great with 2 hard drives. You'll use up a 3.5" front bay on your tower.
    Well worth $25 to me.
    http://www.sidewindercomputers.com/duduhadrposw.html
    Dell Inspiron 531/AMD Athlon 64 X2 5000+ 4GB RAM/GeForce 6150SE nForce 430
    Kubuntu 16.04
    "I have a problem with the fact that they just make really 3rd rate products." Steve Jobs on Microsoft. From “Triumph of the Nerds"
    Re: GRUB alternative - hardware switch
    Clever approach.
    Slava Ukraini! 🇺🇦
