KDE 3 & KDE 4 (KWin)
As default the KDE try to place windows "smartly" out of each other way but you can change this behaviour by:
a)
Right click the window border (Alt+F3) > Advanced > Special Application (or Special Window) settings:
Window pops up -> Geometry tab > Enable Position (and/or Size), choose Remember. Click Ok.
b)
The System Settings has "Window Behavior". There you can "Configure settings specially for a window".
c)
Alt+F2 and type "kcmshell kwinrules" (KDE 3)
"kcmshell kwinrules" (KDE 4)
> FAQ: Control Centre vs. System Settings
Note
Some programs have own position system.
Example > Taming the GIMP with KDE window-specific settings
Links:
> Window placement and size in KDE
> Topic: Window sizes and positions not being saved
> Topic: A small request...
> Topic: Dolphin doesn't save manually rezised window after exiting
> Topic: SOLVED!!How Do I Force an App to Start Maximized?
> Topic: How do I get the titlebar back in Firefox?
a)
b)
c)
kcmshell4 --list
kwinrules - Configure settings specifically for a window
Note
Links:
