This how to, written by Luca, and used with his permission, describes step by step how to set up your Intel Wireless card in (K)ubuntu.
"Hi!
I've seen there are many requests about how to get ipw2200 and wpa to work. So, as I've managed to get them to work, I've decided to write a howto. It's also good if you just want to get ipw2200 without wpa; just follow the first part in this case.
We have to compile and install the latest ipw2200 1.0.6 driver from http://ipw2200.sourceforge.net and we also have to install the firmware, as the ipw2200 0.19 included in the standard installation of Hoary doesn't support wpa.
Since ipw2200 1.0.5, ipw2200 project does not include ieee80211 subsystem anymore, so we also have to compile and install them from http://ieee80211.sourceforge.net.
Since we have to compile the driver from sources, we need the packages: build-essential, gcc, linux-headers-myOwnKernelVersion.
So:
Note: if you have the kernel sources installed, you won't need the linux-headers. And if you're running a custom kernel compiled by you, you won't need to install the packages mentioned above.
First of all, follow these instructions to add extra repositories, which are always handy to have.
Here are the steps (for newbies: the following commands are supposed to be typed in the same console session):
First of all, download the firmware from here.
Then install it:
Now download the latest ieee80211 subsystem from here.
Then untar it and change your current directory into the driver's one:
Now run the remove-old.sh script that comes with the driver package in order to make sure that any old module is deleted:
Now download the latest ipw22000 driver from here.
Now your system is clean and it's time to make and install ieee80211, so:
Then make and install ipw2200 as well:
Note: it seems there's currently a bug of remove-old script on some systems; if you get errors when compiling ieee80211 about the presence of old modules, you'll have to delete them manually, after having unloded all ieee80211* modules through "modprobe -r module_name" (type "lsmod" to see the current loaded modules).
Now we have to download and install the wpa_supplicant package:
Then you have to create a wpa_supplicant.conf in /etc, so:
And paste the following lines in the text editor:
Anyway there are further configuration examples in /usr/share/doc/wpasupplicant/examples/wpa_supplicant.conf.gz.
Then reboot to make sure that the new modules are loaded successfully and type:
to see if there are errors.
Then type the following command to configurate wpa_supplicant:
Note: "eth1" is your wireless device.
If you get troubles establishing the connection with the AP, try to take the "-w" flag out.
Some systems may have problems in finding the AP; so, if you get troubles finding your AP, add the "ap_scan=2" option to let wpa_supplicant performing the scan instead of the wireless card driver. So your /etc/wpa_supplicant.conf will look like the following:
Some systems may have problems in connecting to the AP; if you get this issue, try to add the directive "pairwise=TKIP" in the relative network section of /etc/wpa_supplicant.conf, so that it looks like this:
Of course, if you have problems both findind the AP and connecting to it, you have to add both "ap_scan=2" and "pairwise=TKIP", like the following:
Now we have to create a small script (first provided by fulco and edited by me) in order to get wpa starting automatically at boot:
Here's the script:
Change the script's permissions to allow it to be executed:
And create a symlink to define the relative service:
Ok, that's all!
I hope this howto will be helpful.
__________________
Proud owner of Asus M6N laptop running Ubuntu Hoary 5.04
"Human knowledge belongs to the world"
http://techplanet.altervista.org" Luca_Linux
"Hi!
So:
sudo apt-get update sudo apt-get install build-essential sudo apt-get install gcc sudo apt-get install linux-headers-$(uname -r)
Then install it:
sudo tar xvzf ipw2200-fw-2.3.tgz sudo cp ipw-2.3-*.fw /usr/lib/hotplug/firmware/
sudo tar xvzf ieee80211-1.0.3.tgz cd ieee80211-1.0.3
sudo sh remove-old
cd .. sudo tar xvzf ipw2200-1.0.6.tgz cd ipw2200-1.0.6
sudo sh remove-old
cd .. cd ieee80211-1.0.3 make sudo make install
cd .. cd ipw2200-1.0.6 make sudo make install
sudo apt-get install wpasupplicant
sudo gedit /etc/wpa_supplicant.conf
ctrl_interface=/var/run/wpa_supplicant
network={
ssid="your_network_name"
scan_ssid=1
proto=WPA
key_mgmt=WPA-PSK
psk="your_secret_key"
dmesg | grep ipw
sudo wpa_supplicant -B -i eth1 -c /etc/wpa_supplicant.conf -D ipw -w -dd
ap_scan=2
network={
scan_ssid=1
proto=WPA
key_mgmt=WPA-PSK
network={
scan_ssid=1
proto=WPA
key_mgmt=WPA-PSK
pairwise=TKIP
ap_scan=2
network={
scan_ssid=1
proto=WPA
key_mgmt=WPA-PSK
pairwise=TKIP
sudo gedit /etc/init.d/wifi_wpa.sh
#! /bin/sh
# wifi: wpa_supplicant init
echo " * [Wifi]: Enabling WPA supplicant..."
if [ -x /usr/sbin/wpa_supplicant ]; then
/usr/sbin/wpa_supplicant -B -i eth1 -c /etc/wpa_supplicant.conf -D ipw -w
fi
exit 0
sudo chmod +x /etc/init.d/wifi_wpa.sh
sudo ln -s /etc/init.d/wifi_wpa.sh /etc/rcS.d/S40netwifiwpa
__________________
and that's where I'm stuck now.
Going to find that out too
