So, you're nervous about that $59 hard drive that seemed such a bargain at the time?
Especially after your cat/dog/wife/husband/little sister knocked it off the table before you got it installed?
Modern hard disk drives incorporate Self-Monitoring Analysis and Recording Technology, aka SMART. More about that is here. Basically they have a degree of self-test capability that the user can access to help determine the health and life expectancy of a hard disk drive.
The tool I use is smartmontools. There are others -- many others. "Bonnie++" is one, and a whole suite of hard drive diagnostic tools is available on the Ultimate Boot CD as described here. However if you're simply in a hurry to discover whether your hard drive is likely to crash tomorrow, or not, here's the quick look:
1. Open a Konsole window and
	Assuming the hard disk drive of interest is /dev/sda we'll do the following examination:
2. Verify the manufacturer, model, and SMART capability, and look at the current state of health (as last recorded):
	Here it is (for my /dev/sde):
3. Do the short test in offline mode:
	This takes a few minutes, depending on the drive model.
4. Later (by however many minutes, at least) check the self test log to see the test results:
	Here it says (for /dev/sde):
If there is still reason for worry, and a couple of hours to do something else while the long test runs, then:
5.
	After the time is completed, review the long test results with the same command as #4 above.
Read all the capabilities of smartmontools with
	and check this great article for more guidance on how to use it.
Now you can relax!
	sudo apt-get install smartmontools
	sudo smartctl -ia /dev/sda
	dibl@ibex:~$ sudo smartctl -ia /dev/sde
smartctl version 5.38 [x86_64-unknown-linux-gnu] Copyright (C) 2002-8 Bruce Allen
Home page is [url]http://smartmontools.sourceforge.net/[/url]
=== START OF INFORMATION SECTION ===
Model Family:  Maxtor DiamondMax 10 family (ATA/133 and SATA/150)
Device Model:  Maxtor 6L200P0
Serial Number:  L42WA14G
Firmware Version: BAH41G10
User Capacity:  203,928,109,056 bytes
Device is:    In smartctl database [for details use: -P show]
ATA Version is: 7
ATA Standard is: ATA/ATAPI-7 T13 1532D revision 0
Local Time is:  Sun Aug 24 11:41:52 2008 EDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x02) Offline data collection activity
                    was completed without error.
                    Auto Offline Data Collection: Disabled.
Self-test execution status:   ( 0) The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:        (1622) seconds.
capabilities:          (0x5b) SMART execute Offline immediate.
                    Auto Offline data collection on/off support.
                    Suspend Offline collection upon new
                    command.
                    Offline surface scan supported.
                    Self-test supported.
                    No Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:      (0x0003) Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:    (0x01) Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:    ( 2) minutes.
Extended self-test routine
recommended polling time:    ( 82) minutes.
SCT capabilities:       (0x0021) SCT Status supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME     FLAG  VALUE WORST THRESH TYPE   UPDATED WHEN_FAILED RAW_VALUE
 3 Spin_Up_Time      0x0027 206 204 063  Pre-fail Always   -   13557
 4 Start_Stop_Count    0x0032 253 253 000  Old_age Always   -   619
 5 Reallocated_Sector_Ct 0x0033 253 253 063  Pre-fail Always   -   0
 6 Read_Channel_Margin  0x0001 253 253 100  Pre-fail Offline   -   0
 7 Seek_Error_Rate    0x000a 253 252 000  Old_age Always   -   0
 8 Seek_Time_Performance 0x0027 243 237 187  Pre-fail Always   -   48854
 9 Power_On_Minutes    0x0032 223 223 000  Old_age Always   -   740h+07m
 10 Spin_Retry_Count    0x002b 253 252 157  Pre-fail Always   -   0
 11 Calibration_Retry_Count 0x002b 253 252 223  Pre-fail Always   -   0
 12 Power_Cycle_Count   0x0032 252 252 000  Old_age Always   -   782
192 Power-Off_Retract_Count 0x0032 253 253 000  Old_age Always   -   0
193 Load_Cycle_Count    0x0032 253 253 000  Old_age Always   -   0
194 Temperature_Celsius  0x0032 038 253 000  Old_age Always   -   43
195 Hardware_ECC_Recovered 0x000a 253 252 000  Old_age Always   -   2784
196 Reallocated_Event_Count 0x0008 253 253 000  Old_age Offline   -   0
197 Current_Pending_Sector 0x0008 253 253 000  Old_age Offline   -   0
198 Offline_Uncorrectable 0x0008 253 253 000  Old_age Offline   -   0
199 UDMA_CRC_Error_Count  0x0008 199 199 000  Old_age Offline   -   0
200 Multi_Zone_Error_Rate 0x000a 253 252 000  Old_age Always   -   0
201 Soft_Read_Error_Rate  0x000a 253 252 000  Old_age Always   -   12
202 TA_Increase_Count   0x000a 253 252 000  Old_age Always   -   0
203 Run_Out_Cancel     0x000b 253 252 180  Pre-fail Always   -   0
204 Shock_Count_Write_Opern 0x000a 253 252 000  Old_age Always   -   0
205 Shock_Rate_Write_Opern 0x000a 253 252 000  Old_age Always   -   0
207 Spin_High_Current   0x002a 253 252 000  Old_age Always   -   0
208 Spin_Buzz       0x002a 253 252 000  Old_age Always   -   0
209 Offline_Seek_Performnce 0x0024 240 240 000  Old_age Offline   -   158
210 Unknown_Attribute   0x0032 253 252 000  Old_age Always   -   0
211 Unknown_Attribute   0x0032 253 252 000  Old_age Always   -   0
212 Unknown_Attribute   0x0032 253 252 000  Old_age Always   -   0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description  Status         Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline   Completed without error   00%   7486    -
SMART Selective self-test log data structure revision number 1
 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
  1    0    0 Not_testing
  2    0    0 Not_testing
  3    0    0 Not_testing
  4    0    0 Not_testing
  5    0    0 Not_testing
Selective self-test flags (0x0):
 After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
	sudo smartctl -t short /dev/sda
	sudo smartctl -l selftest /dev/sda
	dibl@ibex:~$ sudo smartctl -l selftest /dev/sde smartctl version 5.38 [x86_64-unknown-linux-gnu] Copyright (C) 2002-8 Bruce Allen Home page is [url]http://smartmontools.sourceforge.net/[/url] === START OF READ SMART DATA SECTION === SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 10570 - # 2 Short offline Completed without error 00% 7486 -
5.
	sudo smartctl -t long /dev/sda
	man smartctl
Now you can relax!
 ...and >
