"KDE Control Centre", a central place to configure your desktop enviroment.
KDE 3.5, Kubuntu 7.10
Starting Control Centre: Press Alt + F2 and type kcontrol. There is also "Settings - Control Centre modules menu" in the Add Applet menu: Right click panel > Add Applet to Panel > Settings...
A few settings that are in the Control Centre but not in the System Settings:
Launch Feedback
Appearance & Themes > Launch Feedback
You can configure tha application-launch feedback here
- Busy Cursor : No Busy Cursor, Passive Busy Cursor, Blinking Cursor, Bouncing Cursor
- Startup indication timeout
- Enable taskbar notification checkbox
KDE Help (in the Konqueror)
help:/kcontrol/kcmlaunch/index.html#launch-feedback
System Settings has "Visual feedback on activation" checkbox in the Keyboard & Mouse > Mouse
Theme Manager
Appearance & Themes > Theme Manager (choose your visual KDE theme)
This control module handles installing, removing, and creating KDE themes.
Autostart Manager
KDE Components > Autostart Manager
This module helps you configure which applications KDE runs When startting up and shutting down.
http://kubuntuforums.net/forums/inde...opic=3086795.0
File Associations
KDE Components > File Associations
This module allows you to choose which applications are associated with a given type of file.
help:/kcontrol/filetypes/index.html#file-assoc
KDE Performance
KDE Components > KDE Performance
You can configure settings that improve KDE performance here.
Storage Media (default media player, file manager)
Peripherals > Storage Media
Here you can change your default media player (when you insert CD/DVD/whatever)
Topic: Make VLC the Default Media Player
http://kubuntuforums.net/forums/inde...opic=3089257.0
CLI Magick
You can bypass both Control Centre and System Settings by using konsole or "Run Command" (Alt + F2).
man kcmshell:
KCMSHELL(1) tool to start single KDE control modules KCMSHELL(1)
NAME
kcmshell - tool to start single KDE control modules
SYNOPSIS
kcmshell [Qt-options] [KDE-options] [options] module
DESCRIPTION
kcmshell is a tool to start single KDE control modules.
OPTIONS
Arguments:
module Configuration module to open
--lang <language>
Specify a particular language
--embed <id>
Embeds the module with buttons in window with id <id>
--embed-proxy <id>
NAME
SYNOPSIS
DESCRIPTION
OPTIONS
Arguments:
--lang <language>
--embed <id>
--embed-proxy <id>
kcmshell --list
With the KDE 4:
kcmshell4 --list
Kommander front-end
> KDE-Apps.org > Kommand Center
Type:
KDE Kommander Script
Description:
Based om Klikit Linux Kommand Center by sqlpython.
Removed Klikit Linux branding and added more tabs and buttons.
Believe I better organized the KCM access and locations under the tabs.
I believe that this is a better alternative as a Kcontrol replacement layout than system-config. Though it needs a lot more work and it should be made into a full blown stand alone program.
Right now just doing layout work to get a better idea of how to make it work better.
The interface is rather stupid so it shows access to KCMs you may not have.
Like I said its a start and sqlpython did a great job in starting this project.
Description:
Links:
Topic: KControl - System Settings Table and Info
http://kubuntuforums.net/forums/index.php?topic=4181.0
