Using flashplugin-nonfree
As flashplugin-nonfree description tells:
So, flashplugin-nonfree will:
1) download install_flash_player_9_linux.tar.gz from Adobe with wget
(downloading to the /var/cache/flashplugin-nonfree)
2) unpack install_flash_player_9_linux.tar.gz
3) install libflashplayer.so
Problems ?
Check: Bugs in flashplugin-nonfree in ubuntu
If flashplugin-nonfree doesn't work:
(before downloading, look at the /var/cache/flashplugin-nonfree)
As said in the Adobe flash_player_9 readme.txt /1/ :
Adobe flash with Konqueror
As said before: " Konqueror can also use the Flash plugin if
konqueror-nsplugins is installed."
konqueror-nsplugins:
Very big problem
Topic: flashplugin r115 update breaks Konqueror
Or
Why Flash sucks | kdedevelopers.org
Solution: don't use flashplugin r115 before there is fix/workaround. Older version of flashplugin: Topic: Flash for Konqueror
Also
Treviño’s Ubuntu Repository
Testing Adobe flash
Go to the Adobe test page
about
lugins
about: URI scheme
about
lugins (Mozilla based/Konqueror)
Also Konqueror > Settings > Configure Konqueror -> Plugins
/1/
Topic: Need detailed, step by step instructions for installing flash 9
http://kubuntuforums.net/forums/index.php?topic=11057.0
More links:
Topic: Firefox and Flash plugin
http://kubuntuforums.net/forums/inde...opic=3090363.0
http://kubuntuforums.net/forums/inde...opic=3089957.0
				This package will download the Flash Player from Adobe. It is a
Netscape/Mozilla type plugin. Any browser based on Netscape or Mozilla can
use the Flash plugin. This package currently supports the following browsers:
Mozilla, Mozilla-Firefox, Firefox, Iceweasel, and Iceape. Also Galeon and
Epiphany can use the Flash plugin. Konqueror can also use the Flash plugin if
WARNING: Installing this Ubuntu package causes the Adobe flash plugin to be
downloaded from www.adobe.com. The distribution license of the Adobe flash
plugin is available at www.adobe.com. Installing this Ubuntu package implies
that you have accepted the terms of that license.
Homepage: http://wiki.ubuntu.com/FlashPlayer9
Problems ?
				Installation instructions
* Plugin
o To install the plugin as user:
+ Copy or move libflashplayer.so into your plugins directory (usually located): ~/.mozilla/plugins
+ Create the plugins folder if it doesn't exist
o To install the plugin as root:
+ Copy or move the file into your system browser installed plugins directory (usually located): /usr/lib/<browser_directory>/plugins
* Plugin
				This package includes support for Netscape plugins in Konqueror.
This package is part of KDE, and a component of the KDE base module.
See the 'kde' and 'kdebase' packages for more information.
Very big problem
				All,
Before everyone else gets hosed. I thought I should let you know: the latest flash upgrade (r115) my repositories suggested (YMMV) hosed my Konqueror (and Opera)...
				As one of my colleagues notes, this statement holds true on its own. However, for those like me too blind to see some things, there are two things about Flash you should know:
1. The latest Flash update fixes various critical security issues.
2. The latest Flash update does not work with anything that is not Gecko-based.
Do the maths yourself. Or just watch it happen as soon as your distribution's update hits your machine...
Also
Testing Adobe flash
about
luginsabout: URI scheme
				about: is an internal URI scheme (also known as a "URL scheme" or, erroneously, "protocol") in various web browsers to display certain built-in functions and Easter eggs. It is not an officially registered scheme, and has no standard syntax.
				Shows the filename, MIME type, description, suffix, and status of all installed plug-ins
	/1/
More links:
