Motivation
I run a kubuntu system with a hardware RAID mirror setup which protects me from disk failures but does not protect me from
If I ever encountered a problem I did not want to re-install the operating system and start all over again with all the customisations - therefore I needed a bare metal backup. However, I have complicated my installation using LVM and I could not find much information on how to take a backup easily when using LVM. I have found /1/ (see below) to be helpful but when it comes to backing up a system using LVM it only recommends a full dd backup e.g.
	While this will work my RAID array is 400GB in size and the backup will be too large and include stuff I don't actually need to backup. Therefore I need an approach where I can backup my OS in bits using a tool like rsync to backup the volumes where I do not need to have an exact dd copy of.
Approach
I haven't been able to get a definitive list of directories to exclude when taking an online backup so, to keep things simple (for now), the backup is done using a live CD/DVD when the OS is not in use. Below I walk through the commands I use. While I have scripts I won't include them here in their entirety basically because it would be a mistake for someone to run them without a lot of modifications for their personal system. Generalised backup and recovery scripts exists - see /2/ - but I was keen to keep things as simple as possible so I can understand what is going on. In addition there are some steps in my procedure where you have to run fdisk interactively so they can't be included in scripts. If anyone has any suggestions for improvements I'd be very happy to hear them.
I do not know show any exclusions in the approach below - they will need to be included once when you have a successful backup. Actually, I even backup tmp below too.
Warnings
Please do not run this approach on a system that you care about unless you have another reliable backup.
e.g.
Alternatively run the approach on a test system or one which you have just installed and are prepared to re-install it again if required
My system
I use the Kubuntu version of Ubuntu
	My disk set-up looks as follows
	So basically I have: a boot partition, a swap partitions and then everything else is in LVM in the extended partition. This appears to the operating system on a single SATA disk (though in hardware RAID there are two acting as a mirror).
My volumes are mounted as follows, vg1 is my volume group. I have an external volume mounted as /backup to store the backup.
	Booting a Live CD /DVD
Every time you start a backup and restore using the Live DVD you will need to do the following. I use the Kubuntu 6.10 AMD 64 Live DVD which unfortunately does not have LVM.
Set you environment up as you like if necessary.
	Create a backup directory and mount to another machine where you will store your backup using e.g. NFS, SSHFS, Samba etc. I used NFS but it performs slowly when using rsync so I use ssh for that step.
	Switch to a root shell or use sudo in front of the steps below
	Install LVM
	Test pvcreate to see if it works
	If you see
	Then your kubuntu installation has the same bug I encountered - see /3/. Fix it with:
	Backup Procedure
What we want to do now that we have mounted the LVM volumes above is cycle round the volumes and back them up using any approach we want. I use rsync. It was very important to use the option --numeric-ids otherwise I couldn't boot after my restore. Note how I actually have hard-coded an SSH path to my backup server as if I use NFS through the /backup mount it took too long.
I do not know if I have to use the -H option - if anyone can advise I would be grateful?
	With the main data backed up, back up the other partitions using dd
	Tidy-up by un-mounting
	Trashing a hard-disk
If you are going to restore to the hard-disk you were previously using you will need to remove the stuff that was there. The following approach was taken from /1/.
For my hard-disk:
	Recovery Procedure
After your Live DVD boots prepare things as we did above in the backup procedure but don't mount the LVM partitions yet as they don't exist.
Restore MBR
	fdisk -l at this point should show partitions sda1, sda2, sda3
The warning:
Warning: invalid flag 0x0000 of partition table 5 will be corrected by w(rite)
can be removed by a manual task
	Restore boot partition
	Either restore swap
	or
alternatively, and much more quickly, re-create the swap
	It will report something like
	Record the UUID as we will need it later on.
Restore Extended partition
	You should see the "8e Linux LVM" partition under sda5 now
At this point we have another manual task. Enter fdisk and write the partitions again. This is necessary for pvcreate to use them below.
Re-create the LVM physical volume
Find the physical volume UUID in the vg1 restorefile in the section "pv0 { if = ..."
Why we have do this when the UUID is in the file I don't know but pvcreate requires it on the command line.
	And restore the volume group
	Mount all the logical volumes
	Now we need to restore the data just as we did when we backed up the data but with the source and destination reversed.
	# Change the UUID for the swap, if we re-created it, via an editor using the value we recorded above
e.g.
	It is possible that you might need to change file /etc/initramfs-tools/conf.d/resume - see /4/. I didn't because my resume file did not hold a UUID.
Mine was
	which makes things simpler.
Tidy-up
	We are now done. Re-boot and you should have a recovered system. Good luck.
/1/ Backup & Recovery, W Curtis Preston, O'Reilly
/2/ http://www.faqs.org/docs/Linux-HOWTO...ery-HOWTO.html
/3/ https://bugs.launchpad.net/ubuntu/+s...vm2/+bug/96802
/4/ https://launchpad.net/ubuntu/+bug/66637/comments/23
- Theft of my computer
 - Changes to the OS which may break my system e.g. distribution upgrades
 - User mistakes
	dd if=/dev/sda of=/backup/sda.dd
Approach
Warnings
e.g.
- A RAID 1 disk which you can remove from the array, when the system is shutdown, acting as a backup
 - You perform the recovery on a brand new disk with the original disk removed
My system
	$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 6.10 Release: 6.10 Codename: edgy
	$ sudo fdisk -l Disk /dev/sda: 400.0 GB, 400087408640 bytes 255 heads, 63 sectors/track, 48641 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sda1 * 1 12 96358+ 83 Linux /dev/sda2 13 377 2931862+ 82 Linux swap / Solaris /dev/sda3 378 48641 387680580 5 Extended /dev/sda5 378 48641 387680548+ 8e Linux LVM
	$ df -h
Filesystem      Size Used Avail Use% Mounted on
/dev/mapper/vg1-root 9.9G 366M 9.0G  4% /
varrun        1006M 140K 1006M  1% /var/run
varlock       1006M   0 1006M  0% /var/lock
procbususb       10M 112K 9.9M  2% /proc/bus/usb
udev          10M 112K 9.9M  2% /dev
devshm        1006M   0 1006M  0% /dev/shm
/dev/sda1       89M  24M  61M 28% /boot
/dev/mapper/vg1-home  30G 283M  28G  1% /home
/dev/mapper/vg1-usermedia
            50G 180M  47G  1% /usermedia
/dev/mapper/vg1-tmp  9.9G 151M 9.2G  2% /tmp
/dev/mapper/vg1-usr  9.9G 2.5G 7.0G 26% /usr
/dev/mapper/vg1-usr_local
           9.9G 176M 9.2G  2% /usr/local
/dev/mapper/vg1-var  9.9G 1.1G 8.4G 12% /var
sles1:/backup/kubuntu1
            50G  17G  31G 35% /backup
	# Switch Live CD to GB keyboard # Do not run as sudo or root but the user that started X setxkbmap gb # Let root use X xhost local:root
	mkdir /backup <mount to your backup server using what ever approach you want to use>
	sudo -i
	apt-get -y install lvm2
	# What we should see is
pvcreate --help
 pvcreate: Initialize physical volume(s) for use by LVM
pvcreate
    [--restorefile file]
    [-d|--debug]
    [-f[f]|--force [--force]]
    [-h|-?|--help]
    [--labelsector sector]
    [-M|--metadatatype 1|2]
    [--metadatacopies #copies]
    [--metadatasize MetadataSize[kKmMgGtT]]
    [--setphysicalvolumesize PhysicalVolumeSize[kKmMgGtT]
    [-t|--test]
    [-u|--uuid uuid]
    [-v|--verbose]
    [-y|--yes]
    [-Z|--zero {y|n}]
    [--version]
    PhysicalVolume [PhysicalVolume...]
	# pvcreate --help # No program "pvcreate" found for your current version of LVM
	ln -s /lib/lvm-200 /lib/lvm-0
	# Add LVM modprobe dm-mod # Make all Logical volumes available vgchange -ay # We see: # 7 logical volume(s) in volume group "vg1" now active # Mount all the logical volumes mount /dev/vg1/home /LVM/home mount /dev/vg1/usermedia /LVM/usermedia mount /dev/vg1/root /LVM/root mount /dev/vg1/tmp /LVM/tmp mount /dev/vg1/usr /LVM/usr mount /dev/vg1/usr_local /LVM/usr_local mount /dev/vg1/var /LVM/var|
BASE_SOURCE=/LVM
# Directories to backup. Separate with a space. Exclude trailing slash.
SOURCES="home usermedia root tmp usr usr_local var"
# Directory to backup to. This is where your backup(s) will be stored.
# :: NOTICE :: -> Make sure this directory is empty or contains ONLY backups created by
#	            this script and NOTHING else. Exclude trailing slash.
TARGET="/backup/set1/volumes"
# Comment out the following line to disable verbose output
VERBOSE="-v"
echo "Verifying Sources..."
for source in $SOURCES; do
	echo "Checking $BASE_SOURCE/$source..."
	if [ ! -x $BASE_SOURCE/$source ]; then
   echo "Error with $BASE_SOURCE/$source!"
   echo "Directory either does not exist, or you do not have proper permissions."
   exit 2
  fi
done
echo "Sources verified. Running rsync..."
 # Create directories in $TARGET to mimick source directory hiearchy
 if [ ! -d $TARGET/$source ]; then
  mkdir -p $TARGET/$source
 fi
 rsync $VERBOSE -a -H --numeric-ids --delete $BASE_SOURCE/$source/ -e ssh root@192.168.1.4:/backup/kubuntu1/set1/volumes/$source/ 2> temp_system_backup_$source.err > system_backup_$source.log
 errorCode=$?
 echo "rsync return code: $errorCode"
 if [ ${errorCode} -gt 0 ] ; then
  echo
  echo Errors were:
  more temp_system_backup_$source.err
  more temp_system_backup_$source.err >> system_backup.err
 fi
done
	# Backup MBR dd if=/dev/sda of=/backup/set1/mbr bs=512 count=1 # Backup boot partition dd if=/dev/sda1 of=/backup/set1/sda1.dd # Optional step - backup swap - either the whole lot if you want to or we can re-create this during recovery dd if=/dev/sda2 of=/backup/set1/sda2.dd # Backup Extended partition dd if=/dev/sda3 of=/backup/set1/sda3.dd # Most importantly - backup LVM configuration cp /LVM/root/etc/lvm/backup/vg1 /backup/set1 # Save fdisk output - for information purposes fdisk -l > /backup/set1/fdisk.txt
	umount /LVM/home umount /LVM/usermedia umount /LVM/root umount /LVM/tmp umount /LVM/usr umount /LVM/usr_local umount /LVM/var umount /backup
For my hard-disk:
	echo Before fdisk -l dd if=/dev/zero of=/dev/sda bs=512 count=1 dd if=/dev/zero of=/dev/sda1 bs=1024k count=50 dd if=/dev/zero of=/dev/sda2 bs=1024k count=50 dd if=/dev/zero of=/dev/sda3 bs=1024k count=50 dd if=/dev/zero of=/dev/sda5 bs=1024k count=50 echo After fdisk -l
Restore MBR
	dd if=/backup/set1/mbr of=/dev/sda bs=512 count=1
The warning:
	fdisk /dev/sda and writing the partitions with command w
	dd if=/backup/set1/sda1.dd of=/dev/sda1
	dd if=/backup/set1/sda2.dd of=/dev/sda2
	# mkswap /dev/sda2
	#Setting up swapspace version 1, size = 3002220 kB #no label, UUID=a8bc1fd6-bcdd-4abd-971f-cfc0989e14b4
	dd if=/backup/set1/sda3.dd of=/dev/sda3
	UUID="lh9seu-HGWf-5ZkP-yF52-LKqu-xFey-tFWkqe" pvcreate --uuid $UUID --restorefile /backup/set1/vg1 /dev/sda5
	vgcfgrestore --file /backup/set1/vg1 vg1
	# Add LVM modprobe dm-mod # Make all Logical volumes available vgchange -ay # Format all the logical volumes mkfs.ext3 /dev/vg1/home mkfs.ext3 /dev/vg1/usermedia mkfs.ext3 /dev/vg1/root mkfs.ext3 /dev/vg1/tmp mkfs.ext3 /dev/vg1/usr mkfs.ext3 /dev/vg1/usr_local mkfs.ext3 /dev/vg1/var
	BASE_SOURCE=/backup/set1/volumes/
# Directories to restore from. Separate with a space. Exclude trailing slash.
# Directory to restore to. Exclude trailing slash.
TARGET="/LVM"
VERBOSE="-v"
   echo "Checking $source..."
   exit 2
  fi
done
 rsync $VERBOSE -a -F --numeric-ids -e ssh root@192.168.1.4:/backup/kubuntu1/set1/volumes/$source/ $TARGET/$source/ 2> temp_system_restore_$source.err > system_restore_$source.log
 errorCode=$?
  echo
  echo Errors were:
  more temp_system_restore_$source.err
  more temp_system_restore_$source.err >> system_restore.err
 fi
done
e.g.
	sudo vim /LVM/root/etc/fstab
Mine was
	RESUME=/dev/sda2
Tidy-up
