Core/Crash Dumps and Debugging? How to make it (not) work?
    Kubuntu 22.04
    I'm fiddling about with basic C programming to learn Linux system calls. I am using gcc to compile. I am trying to deliberately generate some core/crash dumps in order to learn how to debug with them. Problem is I can't actually generate core dumps. I've tried ulimit -c unlimited, I've enabled core dumps in apparmor, installed and configured kdump according to the docs.
    And I get absolutely NOTHING. Not even so much as an error message.
    How do I make Kubuntu generate core dumps and then find them afterwards?
    Should I use some other distro for this?
    Ubuntu these days sets up apport to handle core dumps. (see /proc/sys/kernel/core_pattern). In my 23.04 they've gone to /var/lib/apport/coredump, though I don't know what magic is required to persuade apport to actually write things there.
    Simplest might be to edit /proc/sys/kernel/core_pattern to have a single word, say "my_core". Again, I'm not sure what's required, perhaps some group membership.
    Installing systemd-coredump​ might be a more modern approach, but I haven't tried it.
      Maybe https://askubuntu.com/questions/9664...109747#1109747 (see 31)
        Seems like modern Debian robustly prevents core dumps. Neither Kubuntu nor Kali generate them (that I can see) no matter how many hacks I shove down their throats.
        There might be something to Jlittle's suggestion of systemd-coredump.
        I'm going to drop these two links from Suse here for later.
        https://www.suse.com/support/kb/doc/?id=000015982
        https://www.suse.com/support/kb/doc/?id=000018634
          For future reference:
          /etc/systemd/systemd.conf
          try uncommenting:
          #DumpCore=yes
