Bash help
    Bash help
    Would someone please help me on Bash? Here is a broken script. I need someone to make it work.
    #!/bin/bash
    echo -n "
      How are you feeling?
        Tire
        Bored
        Hungry
          Enter: " #Type how you feel
    read option
      if $option 'Tire'; then
      echo "You should get some rest."
      if $option 'Bored'; then
      echo "Play a game of Frozen Bubble."
      If $option 'Hungry'; then
      echo "Order pizza!"
    Would someone please fix it for me? If possible add an error prompt that will say something like "You must have made a typo. Select option again." if I choose something that is not in the options.
    Also, how do I make the script stay active until I exit it? Like after the script replies me, it goes back to asking me how I feel?
    Thanks in advance for the help.
    Re: Bash help
    Try http://www.tldp.org/LDP/abs/html/ and look for loops.
    Blog: Tasty Tidbits
      Re: Bash help
      #!/bin/bash
      echo -n "
              Tire
              Bored
              Hungry
      read option
         if [ $option = "Tire" ]; then
         echo "You should get some rest."; fi
         if [ $option = "Bored" ]; then
         echo "Play a game of Frozen Bubble."; fi
         if [ $option = "Hungry" ]; then
         echo "Order pizza!"; fi
      as you can see, adding [] to the area that has to be tested does the trick. You also have to end the 'if' with 'fi'
      This script is not a good one, it'll return an error if nothing is typed. It might also be more wrong as I don't know anything about bash programming... yet...
      An easier to understand tutorial can be found at http://pegasus.rutgers.edu/~elflord/unix/bash-tute.html
      Edit:
      If you add: if [ $option != "" ]; then
      after 'read option' and 'fi' at the end, then you wont get the error message if nothing is entered
      Here is the codes with typo and loop: (as goos as I could get it after working with bash for only 4hours (got some 'basic' programming skills from the earlier days))
      #!/bin/bash
      while [ "$option" != "exit" ]; do   #makes a loop until 'option' = "exit"
      echo -n
              Tire
              Bored
              Hungry
                  Enter: "
      #Prits the text on the screen
      read option   #Asks for what to put in option
      if [ "$option" != "exit" ]; then  #This jumps over the last 'read' if 'exit' is typed
      if [ "$option" != "" ]; then   #Checks if you have written anything (no_text)
         if [ "$option" = "Tire" ]; then   #Tests if you typed Tired
         echo "You should get some rest."; else   #If you didn't type Tired, It'll test next
         if [ "$option" = "Bored" ]; then
         echo "Play a game of Frozen Bubble."; else
         if [ "$option" = "Hungry" ]; then
         echo "Order pizza!"; else
      echo "typo"   #As it didn't stop at any ifs, this line is executed
      fi; fi; fi   #All ifs ends here. While the exit and no_text ends later
         else
         echo "You have to type something!"   #if there was no_text typed, the echo is executed
      fi   #The no_text if ends here
         read; clear   #this makes a pause until you hit enter, then clears the screen
      fi   #ends the exit if. If exit is typed, it jumps here
      done   #ends the loop or restarts it
         clear   #Clears the screen before exiting
         echo "Good Bye!"
        Re: Bash help
        you can also use a case statement:
        if [ "$option" != "exit" -o "$option" != "EXIT" ]; then
           case $option in
               "tired" | "TIRED") echo "something" ;;  # the ;;'s end each condition
               "bored" | "BORED") echo "something" ;;
               "another" | "ANOTHER") echo "antoher" ;;
                *) exit 1 ;; #everything else
            esac
        fi
          Re: Bash help
          I knew that! But mine just looks so much nicer with all the lines and the ifs inside the ifs and all that other nice things that keeps peoples away from steeling my codes.
          Or I could just admit that my biggest program ever just makes ANSII pictures from 4 collored bitmaps (and that is infact verry easy, but with my logical programming it almost took an whole page in VB and a whole day of work)
            Re: Bash help
            heh. I used to do the same thing. You'll get better at it, takes time.
