I tried to install eq-xmms-0.7 after puting myself through many fialed debian packages and aliening a few rpms . i still get GTK+ >= 1.2.7 not installed - please install first ***
NOTE: You may need to install the GTK development package.
Look for a RPM called 'libgtk1.2-devel' or 'gtkdev'.
(It should contain a shell script called 'gtk-config')
then i tried to install oem-config.trunk
No package 'gtk+-2.0' found
No package 'pygtk-2.0' found
then i found
http://www.realtek.com.tw/downloads/...&GetDown=false
a linux driver by realtek whom makes my on board card we will see if that fixes it
make[3]: Leaving directory `/home/wolf/realtek-linux-audiopack-5.11/alsa-utils-1.0.19/alsactl/init'
make[2]: Leaving directory `/home/wolf/realtek-linux-audiopack-5.11/alsa-utils-1.0.19/alsactl/init'
make[2]: Entering directory `/home/wolf/realtek-linux-audiopack-5.11/alsa-utils-1.0.19/alsactl'
xmlto man alsactl_init.xml
/bin/bash: xmlto: command not found
make[2]: *** [alsactl_init.7] Error 127
make[2]: Leaving directory `/home/wolf/realtek-linux-audiopack-5.11/alsa-utils-1.0.19/alsactl'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/home/wolf/realtek-linux-audiopack-5.11/alsa-utils-1.0.19/alsactl'
make: *** [install-recursive] Error 1
Remove Folder.....
./install: 101: alsaconf: not found
not sure whats wrong here gonna reboot see if a equalizer appears.
then i found
Remove Folder.....
