Hi, I am a very recent convert to Ubuntu/Kubuntu when my older Windows laptop crashed. I was able to get it working again by downloading an Ubuntu iso via thumbdrive and boot thru it. I admit my grandson provided me with some advise as to how. After working with Ubuntu 12.04 for awhile, I found it a little too basic looking and just today switched to Kubuntu. Unfortunately I chose to repartition and get rid of Ubuntu and use only Kubuntu. After successfully downloading and installing I find that I don,t have any connectivity with my router or with my bluetooth adapter (usb). I don,t know what to do. I get an error message that says my wireless transceiver hardware switch is turned off. Also in network manager it says that my network interface and my WLAN interface are both unmanaged. Anybody have any advise that a newby can follow? Thanks Gateway CS2726
connectivity problems
Pan-Galactic QuordlepleenSo Long, and Thanks for All the Fish
- Jul 2011
- 9625
- Seattle, WA, USA
- Send PM
To begin, please open a console window. Type the following commands. Copy-paste the output into a reply here.
Code:rfkill list sudo lshw -C net cat /etc/network/interfaces
Code:bob@bob-CX2726:~$ rfkill list 0: phy0: Wireless LAN Soft blocked: no Hard blocked: yes bob@bob-CX2726:~$ sudo lshw -c net [sudo] password for bob: *-network description: Ethernet interface product: 82573L Gigabit Ethernet Controller vendor: Intel Corporation physical id: 0 bus info: pci@0000:02:00.0 logical name: eth0 version: 00 serial: 00:e0:b8:b0:00:3f capacity: 1Gbit/s width: 32 bits clock: 33MHz capabilities: pm msi pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=1.5.1-k firmware=0.5-1 latency=0 link=no multicast=yes port=twisted pair resources: irq:45 memory:d4000000-d401ffff ioport:2000(size=32) *-network DISABLED description: Wireless interface product: PRO/Wireless 3945ABG [Golan] Network Connection vendor: Intel Corporation physical id: 0 bus info: pci@0000:03:00.0 logical name: wlan0 version: 02 serial: 00:18:de:b1:71:26 width: 32 bits clock: 33MHz capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless configuration: broadcast=yes driver=iwl3945 driverversion=3.2.0-58-generic-pae firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11abg resources: irq:44 memory:d6000000-d6000fffLast edited by SteveRiley; Feb 18, 2014, 10:47 PM.
I see that some info is missing for the output for cat /etc/network/interface command:
Code:auto lo lface lo inet loopback
I think he meant Gateway CX2726Slava Ukraini! 🇺🇦
Sorry, late night and fingers too big -- supposed to be CX2726. Yes the network switch was off, activated it and now the Wi Lan is no longer hard blocked, but still no wireless. In the mean time I hooked up to router through cable and have internet again on this laptop. Interesting note on bluetooth, I can see the Cx2726 with my other laptops, but the CX2726 won't see anything else on network. I have 2 other laptops, 2 tablets and several phones that all are working fine on network. The CX2726 is only Linux OS, I have a Win 7 and a Mac also, and 1 Android tablet and an Ipad. Thanks for looking into this. I have been researching Ubuntu terminal commands, but so far nothing has helped.
