Where are hplipopensource's cli commands?
    [SOLVED] Where are hplipopensource's cli commands?
    Hello,
    HP's hplipopensource site includes instructions for downloading/installing HP's printer software, its Device Manager, on its site http://hplipopensource.com/hplip-web...all/index.html. That page used to include the commands each instruction set refers to; now it doesn't. I've asked its help section, hplipopensource's page in Ubuntu's Launchpad, to no avail; no answer after nearly two weeks. Can anyone here tell me where those commands are?
    Regards,
    Lynn
    Open a konsole and cd into the directory you downloaded the file to.
    Type: sh ./hplip-x.xx.x.run, where x is the version number.
      Thank you, snowhog; that did it. I installed it into four distros.
        What are the advantages to the normal HPLIP in the repositories?
          I've used them both. The website has the latest version. The repository version works well for me and tells me if there is a newer version on the website. Both pull down the necessary plugin to get duplex printing..
