conky stuff
    conky stuff
    Here's my script
    # UBUNTU-CONKY
    # A comprehensive conky script, configured for use on
    # Ubuntu / Debian Gnome, without the need for any external scripts.
    # Based on conky-jc and the default .conkyrc.
    # INCLUDES:
    # - tail of /var/log/messages
    # - netstat connections to your computer
    # -- Pengo (conky@pengo.us)
    # Create own window instead of using desktop (required in nautilus)
    own_window yes
    own_window_type override
    own_window_hints below
    # Use double buffering (reduces flicker, may not work for everyone)
    double_buffer yes
    # fiddle with window
    use_spacer yes
    use_xft no
    # Update interval in seconds
    update_interval 3.0
    #Maximum Width of Window
    maximum_width 320
    # Minimum size of text area
    # minimum_size 250 5
    # Draw shades?
    draw_shades no
    # Text stuff
    draw_outline no # amplifies text if yes
    draw_borders no
    font arial
    uppercase no # set to yes if you want all text to be in uppercase
    # Stippled borders?
    stippled_borders 3
    # border margins
    border_margin 5
    # border width
    border_width 6
    # Default colors and also border colors, grey90 == #e5e5e5
    default_color FFFFCC
    own_window_colour brown
    own_window_transparent yes
    # Text alignment, other possible values are commented
    #alignment top_left
    alignment top_right
    #alignment bottom_left
    #alignment bottom_right
    # Gap between borders of screen and text
    gap_x 25
    gap_y 50
    # stuff after ‘TEXT’ will be formatted on screen
    TEXT
    $color
    ${color CC9900}SYSTEM ${hr 2}$color
    $nodename $sysname $kernel on $machine
    ${color CC9900}CPU ${hr 2}$color
    AMD E1-1200
    Total CPU: ${cpu cpu0}%
    ${color 597DB2}${cpubar}$color
    ${cpugraph 000000 597DB2}
    Core 1: ${freq 1} MHz        Temprature: $color ${exec sensors|grep 'Core0'|awk '{print $3}'}
    ${cpu cpu1}% ${color 597DB2}${cpubar cpu1}$color
    Core 2: ${freq 2} MHz        Temprature: $color ${exec sensors|grep 'Core1'|awk '{print $3}'}
    ${cpu cpu2}% ${color 597DB2}${cpubar cpu2}$color
    NAME            PID     CPU%      MEM%
    ${color CCFFFF}${top name 1} ${top pid 1} ${top cpu 1} ${top mem 1}
    ${top name 2} ${top pid 2} ${top cpu 2} ${top mem 2}
    ${top name 3} ${top pid 3} ${top cpu 3} ${top mem 3}
    ${top name 4} ${top pid 4} ${top cpu 4} ${top mem 4}$color
    ${color CC9900}MEMORY ${hr 2}$color
    RAM Used: ${mem}    RAM Free: ${memfree}/ ${memmax}
     RAM: $memperc%  ${color FF6600} ${membar 6}$color
    Swap: $swapperc%   ${color FF6600} ${swapbar 6}$color
    ${color CC9900}DISK ${hr 2}$color
    Root ${fs_type}  ${fs_free_perc /}% ${color FFFF33} ${fs_bar 6 /}$color
    ${color CC9900}NETWORK (${addr eth0}) ${hr 2}$color
    Down: $color${downspeed eth0} k/s ${alignr}Up: ${upspeed eth0} k/s
    ${downspeedgraph eth0 25,140 000000 ff0000} ${alignr}${upspeedgraph eth0
    25,140 000000 00ff00}$color
    ${color CC9900}Uptime ${hr 2}$color
    ${alignc}${uptime}
    ${font Ubuntu:bold:size=72}${color EAEAEA}${alignc}${time %H:%M}
    ${alignc}${color EAEAEA}${time %A} ${time %d} ${time %B}
    Trying to make the time and date large. Tried setting the size to 172 and nothing happened. It stays the same size as everything else. Barely starting to understand conky. I'm sure it uses some resources, but doesnt seem to slow the system much. It's already slow, but it was free (abandoned in a house father in law cleaned).
    Read through this thread: How to change conky font size?
    Slava Ukraini! 🇺🇦
      That worked. Will have to play with it a little to get columns of my top4 pids lined up, but that shouldn't be too hard
      What I love about this forum is that someone always knows where to find the inf someone else is looking for
        I use top 3 in cpu load and mem load ,,,,like this .
        Highest CPU $alignr CPU% MEM%
        ${color E40016}${top name 1}$alignr${top cpu 1}${top mem 1}${color}
        ${color d2d00a}${top name 2}$alignr${top cpu 2}${top mem 2}${color}
        ${color 0538ab}${top name 3}$alignr${top cpu 3}${top mem 3}${color}
        Highest MEM $alignr CPU% MEM%
        ${color E40016}${top_mem name 1}$alignr${top_mem cpu 1}${top_mem mem 1}${color}
        ${color d2d00a}${top_mem name 2}$alignr${top_mem cpu 2}${top_mem mem 2}${color}
        ${color 0538ab}${top_mem name 3}$alignr${top_mem cpu 3}${top_mem mem 3}${color}
        screenshot ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
        just conky,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,
        and desktop,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,
          Borrowed this from you. Can't get it transparent though. Added own_windows_transparent yes but no change
          Here's what it looks like now
            See https://www.kubuntuforums.net/showth...l=1#post278220
            Slava Ukraini! 🇺🇦
              Tried the things listed on the link. Still not transparent. There must be someting else overriding it.
              Here it is again if any conky gurus come strolling by
              # UBUNTU-CONKY
              # INCLUDES:
              own_window yes
              own_window_argb_visual yes
              own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
              double_buffer yes
              use_spacer yes
              use_xft yes
              update_interval 3.0
              maximum_width 380
              # Draw shades?
              draw_shades no
              # Text stuff
              draw_borders no
              font arial
              # Stippled borders?
              stippled_borders 3
              # border margins
              border_margin 5
              # border width
              border_width 6
              #alignment top_left
              alignment top_right
              gap_x 25
              gap_y 50
              TEXT
              $color${font Ubuntu:size=8}
              ${execi 1000 cat /proc/cpuinfo | grep 'model name' | sed -e 's/model name.*: //'| uniq}
              #        Temprature: $color ${exec sensors|grep 'Core0'|awk '{print $3}'}
              #        Temprature: $color ${exec sensors|grep 'Core1'|awk '{print $3}'}
              ${color 00ff00}${top name 3}$alignr${top cpu 3}${top mem 3}${color}
              ${color 00ff00}${top_mem name 3}$alignr${top_mem cpu 3}${top_mem mem 3}${color}
              RAM : $memperc%  ${color 66FF66} ${goto 70}${membar 6}$color
              Swap: $swapperc% ${color 66FF66}${goto 70}${swapbar 6}$color
              ${color CC9900}DISK FREE${hr 2}$color
              ${alignc}${uptime}
              ${font Ubuntu:bold:size=20}${color EAEAEA}${alignc}${time %H:%M}
                Changed own_window to normal and transparent works
                  hear is my hole .conkyrc ,,,,,,,,,,,,mostly borrowed from @Snowhog
                   background no
                   use_xft yes
                  xftfont Ubuntu Mono:size=9
                  update_interval 3.0
                  total_run_times 0
                  own_window yes
                  own_window_type normal
                  own_window_argb_visual true
                  double_buffer yes
                  minimum_size 220 5
                  maximum_width 220
                  draw_shades no
                  draw_outline no
                  draw_borders no
                  draw_graph_borders yes
                  default_color gray
                  #default_shade_color black
                  alignment top_right
                  gap_x 12
                  gap_y 35
                  cpu_avg_samples 2
                  override_utf8_locale yes
                  uppercase yes # set to yes if you want all text to be in uppercase
                  TEXT
                  ${color gray}SYSTEM ${hr 1}${color}
                  Hostname: $alignr$nodename
                  Kernel: $alignr$kernel
                  Release: $alignr${pre_exec lsb_release -rs | awk '{print $1}'}
                  Codename: $alignr${pre_exec lsb_release -cs | awk '{print $1}'}
                  Desktop: ${alignr}KDE ${pre_exec kde4-config --version | grep KDE | awk '{print $4}'}
                  Uptime: $alignr$uptime
                  #Temperatures: ${alignr}GPU ${intel temp}°C
                  #${alignr}Core0 ${execi 5 sensors | grep "Core 0" | awk '{print $3}' | cut -c2-3}°C
                  ${color 0538ab}Avgerage: ${execi 8 sensors | grep -A 0 'temp1' | cut -c14-19 | sed '/^$/d'}°C $alignr${execi 8 sensors -f | grep -A 0 'temp1' | cut -c14-19 | sed '/^$/d'}°F${color}
                  Core 1  : ${execi 8 sensors | grep -A 0 'Core 0' | cut -c14-19 | sed '/^$/d'}°C $alignr${execi 8 sensors -f | grep -A 0 'Core 0' | cut -c14-19 | sed '/^$/d'}°F
                  Core 2  : ${execi 8 sensors | grep -A 0 'Core 1' | cut -c14-19 | sed '/^$/d'}°C $alignr${execi 8 sensors -f | grep -A 0 'Core 1' | cut -c14-19 | sed '/^$/d'}°F
                  Core 3  : ${execi 8 sensors | grep -A 0 'Core 2' | cut -c14-19 | sed '/^$/d'}°C $alignr${execi 8 sensors -f | grep -A 0 'Core 2' | cut -c14-19 | sed '/^$/d'}°F
                  Core 4  : ${execi 8 sensors | grep -A 0 'Core 3' | cut -c14-19 | sed '/^$/d'}°C $alignr${execi 8 sensors -f | grep -A 0 'Core 3' | cut -c14-19 | sed '/^$/d'}°F
                  CPU: ${alignr}${freq} MHz
                  Processes: ${alignr}$processes ($running_processes running)
                  Load: ${alignr}$loadavg
                  CPU1 ${alignr}${cpu cpu1}%
                  ${color 00af00}${cpubar 4 cpu1}${color}
                  CPU2 ${alignr}${cpu cpu2}%
                  ${color 00af00}${cpubar 4 cpu2}${color}
                  CPU3 ${alignr}${cpu cpu3}%
                  ${color 00af00}${cpubar 4 cpu3}${color}
                  CPU4 ${alignr}${cpu cpu4}%
                  ${color 00af00}${cpubar 4 cpu4}${color}
                  Ram ${alignr}$mem / $memmax ($memperc%)
                  ${color 00af00}${membar 4}${color}
                  swap ${alignr}$swap / $swapmax ($swapperc%)
                  ${color 00af00}${swapbar 4}${color}
                  ${color gray}Filesystem ${hr 1}${color}
                  Root: ${alignr}${fs_free /} / ${fs_size /}
                  ${color 00af00}${fs_bar 4 /}${color}
                  Disk: ${alignr}${fs_free /mnt/btrfs} / ${fs_size /mnt/btrfs}
                  ${color 00af00}${fs_bar 4 /mnt/btrfs}${color}
                  ${color gray}NETWORK ${hr 1}${color}
                  Down ${downspeed wlan0} k/s ${alignr}Up ${upspeed wlan0} k/s
                  ${downspeedgraph wlan0 25,107 0000ff 00ff00 scale -t -l}${alignr}${upspeedgraph wlan0 25,107 d0c40c 6b0853}
                  Total ${totaldown wlan0} ${alignr}Total ${totalup wlan0}
                  ${image /home/vinny/Downloads/banner1.png -p 0,950 -s 234x30}
                  I did not see "background no" in yours .
                  PS: any where you see "${color E40016}" the #'s can be changed ,,,,,,just use a color picker(like in system settings>applacation apperance>colors>colors and click a background,txt, color ) and use the HTML code you see for the color.
                    Got transparent working now. My cpu and hdd temp sensors don't seem to work. Or, I haven't figured out which ones they are. Not critical I guess, I printed a 6-digit hex code chart. Raced inkjet and laser. Gave inkjet 10 second head start and the laser still won.
                      LOL ,,,,,do you have
                      vinny@vinny-Bonobo-Extreme:~/Pictures$ apt show lm-sensors
                      Package: lm-sensors
                      Priority: extra
                      Section: universe/utils
                      Installed-Size: 423 kB
                      Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
                      Original-Maintainer: Aurelien Jarno <aurel32@debian.org>
                      Version: 1:3.3.4-2ubuntu1
                      Depends: sed (>= 4.0.5-1), lsb-base (>= 3.2-13), init-system-helpers (>= 1.13~), libc6 (>= 2.4), libsensors4 (>= 1:3.1.1), perl
                      Suggests: fancontrol, sensord, read-edid, i2c-tools
                      Download-Size: 84.6 kB
                      Homepage: http://www.lm-sensors.org
                      Bugs: https://bugs.launchpad.net/ubuntu/+filebug
                      Origin: Ubuntu
                      APT-Manual-Installed: no
                      APT-Sources: http://us.archive.ubuntu.com/ubuntu/ trusty/universe amd64 Packages
                      Description: utilities to read temperature/voltage/fan sensors
                       Lm-sensors is a hardware health monitoring package for Linux. It allows you
                       to access information from temperature, voltage, and fan speed sensors. It
                       works with most newer systems.
                       This package contains programs to help you set up and read data from
                       lm-sensors.
                      installed?
                        lm-sensors.
                        [/CODE]
                        installed?
                        LM-sensosrs installed. not sure how to use this
                        virgil@reeser-20-b011:~$ sensors -f -u
                        radeon-pci-0008
                        Adapter: PCI adapter
                        temp1:
                          temp1_input: 48.000
                          temp1_crit: 120.000
                          temp1_crit_hyst: 90.000
                        k10temp-pci-00c3
                        temp1:
                          temp1_input: 48.750
                          temp1_max: 70.000
                          temp1_crit: 100.000
                        It does show it's picking up something, but how do I use the info? Something of a control freak with the computer. maybe info-freak would be a better word
                          radeon-pci-0008
                          temp1:
                            temp1_input: 48.000
                            temp1_crit: 120.000
                          k10temp-pci-00c3
                          temp1:
                            temp1_input: 48.750
                            temp1_max: 70.000
                            temp1_crit: 100.000
                          I gave you the code,,,,,,,,,,,,,,,,,,,,,,,,,,
                          remove the "core 3 & core 4" lines if you only have 2
                          I dont have HD temps ,,,,,so
                            O and sensors looks better if you drop the -u
                            vinny@vinny-Bonobo-Extreme:~/Pictures$ sensors -f
                            acpitz-virtual-0
                            Adapter: Virtual device
                            temp1:       +123.8°F  (crit = +248.0°F)
                            coretemp-isa-0000
                            Adapter: ISA adapter
                            Physical id 0: +125.6°F  (high = +183.2°F, crit = +212.0°F)
                            Core 0:        +125.6°F  (high = +183.2°F, crit = +212.0°F)
                            Core 1:        +114.8°F  (high = +183.2°F, crit = +212.0°F)
                            Core 2:        +122.0°F  (high = +183.2°F, crit = +212.0°F)
                            Core 3:        +116.6°F  (high = +183.2°F, crit = +212.0°F)
                            VINNY ........ (info freek)
                              It got the info. Came out really strange. I'll have to learn more about grep, cut, and how to use sed. For the time being working on genealogy. Basically copy and paste from familysearch.org to my own program, export a gedcom, and import it to my website. I'll get back to this later
