No space left on device and startx problem
    I've got any problem installing any package, and get the following.
    root@andgmdlaptop:~# aptitude install deborphan
    Reading package lists... Done
    Building dependency tree
    Reading extended state information
    Initializing package states... Done
    Writing extended state information... Done
    The following packages are BROKEN:
    linux-headers-generic
    0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 0B of archives. After unpacking 0B will be used.
    linux-headers-generic: Depends: linux-headers-2.6.31-20-generic but it is not installable
    The following actions will resolve these dependencies:
    Install the following packages:
    linux-headers-2.6.31-19 [2.6.31-19.56 (karmic-updates, karmic-security)]
    linux-headers-2.6.31-19-generic [2.6.31-19.56 (karmic-updates, karmic-security)]
    Downgrade the following packages:
    linux-headers-generic [2.6.31.20.33 (karmic-updates, now) -> 2.6.31.19.32
    (karmic-security)]
    Score is 62
    Accept this solution? [Y/n/q/?] y
    The following packages will be DOWNGRADED:
    linux-headers-2.6.31-19{a} linux-headers-2.6.31-19-generic{a}
    0 packages upgraded, 2 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
    Need to get 10.2MB of archives. After unpacking 82.1MB will be used.
    Do you want to continue? [Y/n/?] y
    Get:1 http://security.ubuntu.com karmic-security/main linux-headers-generic 2.6.31.19.32 [3,372B]
    Get:2 http://es.archive.ubuntu.com karmic-updates/main linux-headers-2.6.31-19 2.6.31-19.56 [9,531kB]
    Get:3 http://es.archive.ubuntu.com karmic-updates/main linux-headers-2.6.31-19-generic 2.6.31-19.56 [695kB]
    Fetched 10.2MB in 2s (3,841kB/s)
    (Reading database ... 119896 files and directories currently installed.)
    Unpacking linux-headers-2.6.31-19 (from .../linux-headers-2.6.31-19_2.6.31-19.56_all.deb) ...
    dpkg: error processing /var/cache/apt/archives/linux-headers-2.6.31-19_2.6.31-19.56_all.deb (--unpack):
    error creating directory `./usr/src/linux-headers-2.6.31-19/drivers/net/irda': No space left on device
    No apport report written because the error message indicates a disk full error
    dpkg-deb: subprocess paste killed by signal (Broken pipe)
    Selecting previously deselected package linux-headers-2.6.31-19-generic.
    Unpacking linux-headers-2.6.31-19-generic (from .../linux-headers-2.6.31-19-generic_2.6.31-19.56_amd64.deb) ...
    Preparing to replace linux-headers-generic 2.6.31.20.33 (using .../linux-headers-generic_2.6.31.19.32_amd64.deb) ...
    Unpacking replacement linux-headers-generic ...
    A package failed to install. Trying to recover:
    dpkg: dependency problems prevent configuration of linux-headers-2.6.31-19-generic:
    linux-headers-2.6.31-19-generic depends on linux-headers-2.6.31-19; however:
    Package linux-headers-2.6.31-19 is not installed.
    dpkg: error processing linux-headers-2.6.31-19-generic (--configure):
    dependency problems - leaving unconfigured
    dpkg: dependency problems prevent configuration of linux-headers-generic:
    linux-headers-generic depends on linux-headers-2.6.31-19-generic; however:
    Package linux-headers-2.6.31-19-generic is not configured yet.
    dpkg: error processing linux-headers-generic (--configure):
    root@andgmdlaptop:~# aptitude -f install
    compiz-fusion-plugins-main compiz-plugins python-compizconfig
    compiz-wrapper googleearth-data googleearth-package linux-headers-2.6.31-14 linux-headers-2.6.31-19{a} linux-headers-2.6.31-20 linux-headers-2.6.31-20-generic
    linux-image-2.6.31-19-server winbind
    The following partially installed packages will be configured:
    The following packages are RECOMMENDED but will NOT be installed:
    googleearth
    0 packages upgraded, 12 newly installed, 0 to remove and 1 not upgraded.
    Need to get 60.1MB/69.6MB of archives. After unpacking 383MB will be used.
    python-compizconfig: Depends: libcompizconfig0 but it is not installable
    compiz-plugins: Depends: compiz-core (= 1:0.8.4-0ubuntu2) but it is not installable
    compiz-fusion-plugins-main: Depends: compiz-core but it is not installable
    Depends: compiz-core-abiversion-20090619 which is a virtual package.
    compiz-core [1:0.8.4-0ubuntu2 (karmic, now)]
    googleearth [5.1.3509.4636-0medibuntu1 (karmic)]
    Keep the following packages at their current version:
    python-compizconfig [Not Installed]
    Score is 101
    compiz-core{a} compiz-fusion-plugins-main compiz-plugins compiz-wrapper googleearth{a} googleearth-data googleearth-package linux-headers-2.6.31-14
    linux-headers-2.6.31-19{a} linux-headers-2.6.31-20 linux-headers-2.6.31-20-generic linux-image-2.6.31-19-server winbind
    0 packages upgraded, 13 newly installed, 0 to remove and 1 not upgraded.
    Need to get 77.3MB/86.9MB of archives. After unpacking 439MB will be used.
    Get:1 http://packages.medibuntu.org karmic/non-free googleearth-data 5.1.3509.4636-0medibuntu1 [4,745kB]
    Get:2 http://es.archive.ubuntu.com karmic-updates/main linux-image-2.6.31-19-server 2.6.31-19.56 [28.9MB]
    Get:3 http://packages.medibuntu.org karmic/non-free googleearth 5.1.3509.4636-0medibuntu1 [17.1MB]
    Get:4 http://es.archive.ubuntu.com karmic/main compiz-wrapper 1:0.8.4-0ubuntu2 [46.9kB]
    Get:5 http://es.archive.ubuntu.com karmic/main compiz-core 1:0.8.4-0ubuntu2 [258kB]
    Get:6 http://es.archive.ubuntu.com karmic/main compiz-plugins 1:0.8.4-0ubuntu2 [545kB]
    Get:7 http://es.archive.ubuntu.com karmic/multiverse googleearth-package 0.5.6ubuntu2 [10.6kB]
    Get:8 http://es.archive.ubuntu.com karmic/main linux-headers-2.6.31-14 2.6.31-14.48 [9,526kB]
    Get:9 http://es.archive.ubuntu.com karmic-updates/main linux-headers-2.6.31-20 2.6.31-20.57 [9,540kB]
    Err http://packages.medibuntu.org karmic/non-free googleearth 5.1.3509.4636-0medibuntu1
    Error writing to output file - write (28: No space left on device)
    Err http://es.archive.ubuntu.com karmic-updates/main linux-headers-2.6.31-20 2.6.31-20.57
    Error writing to output file - write (28: No space left on device) [IP: 150.214.5.135 80]
    Err http://es.archive.ubuntu.com karmic-updates/main linux-headers-2.6.31-20-generic 2.6.31-20.57
    Bad header line [IP: 150.214.5.135 80]
    Err http://es.archive.ubuntu.com karmic-updates/main winbind 2:3.4.0-3ubuntu5.4
    Err http://es.archive.ubuntu.com karmic/main compiz-fusion-plugins-main 0.8.4-0ubuntu1
    Get:10 http://security.ubuntu.com karmic-security/main winbind 2:3.4.0-3ubuntu5.4 [4,780kB]
    Err http://security.ubuntu.com karmic-security/main winbind 2:3.4.0-3ubuntu5.4
    Error writing to output file - write (28: No space left on device) [IP: 91.189.88.37 80]
    Fetched 44.0MB in 8s (5,224kB/s)
    dpkg: unrecoverable fatal error, aborting:
    unable to flush /var/lib/dpkg/updates/tmp.i after padding: No space left on device
    E: Failed to fetch http://packages.medibuntu.org/pool/n...tu1_amd64.deb: Error writing to output file - write (28: No space left on device)
    E: Sub-process /usr/bin/dpkg returned an error code (2)
    Writing extended state information... 0%
    This is my disk usage.
    root@andgmdlaptop:~# df -h
    Filesystem Size Used Avail Use% Mounted on
    /dev/sda6 3.7G 3.7G 0 100% /
    udev 468M 280K 468M 1% /dev
    none 468M 140K 468M 1% /dev/shm
    none 468M 80K 468M 1% /var/run
    none 468M 0 468M 0% /var/lock
    none 468M 0 468M 0% /lib/init/rw
    /dev/sda7 5.3G 1.6G 3.5G 31% /home
    I've got the mistake of update the system, But I haven't got enough space in my disk. What can I do for return to the last configuration before to update?
    I've problems to get starting startx too.
    I've got 2 errors:
    bad length in CompotMap
    output file "/tmp/server-0/xkm" removed.
    Please help me.
    Re: No space left on device and many problems more.
    Let's get some space first - do a sudo apt-get remove followed by a sudo apt-get autoremove to flush your package cache. Looks like you were busy downloading a bit. What is your df -h now?
    BTW, how did you partition your hard drive? Or better, how big is /?
      Look at the prompts -- he has no need of sudo.
        Yep, quite right. It's late. I'm off to bed - good night
          Re: No space left on device and startx problem.
          thanks for the first solution.
          I'm using these 2 codes to clean temp and trashes I found them in some forums.
          open terminal and type.
          sudo nano /urs/sbin/clear_tmp.sh
          copy and paste the following code
          #!/bin/bash
          OLDCONF=$(dpkg -l|grep "^rc"|awk '{print $2}')
          CURKERNEL=$(uname -r|sed 's/-*[a-z]//g'|sed 's/-386//g')
          LINUXPKG="linux-(image|headers|ubuntu-modules|restricted-modules)"
          METALINUXPKG="linux-(image|headers|restricted-modules)-(generic|i386|server|common|rt|xen)"
          OLDKERNELS=$(dpkg -l|awk '{print $2}'|grep -E $LINUXPKG |grep -vE $METALINUXPKG|grep -v $CURKERNEL)
          YELLOW="\033[1;33m"
          RED="\033[0;31m"
          ENDCOLOR="\033[0m"
          if [ $USER != root ]; then
          echo -e $RED"Error: must be root"
          echo -e $YELLOW"Exiting..."$ENDCOLOR
          exit 0
          fi
          echo -e $YELLOW"Cleaning apt cache..."$ENDCOLOR
          aptitude clean
          aptitude autoclean
          echo -e $YELLOW"Removing old config files..."$ENDCOLOR
          sudo aptitude purge $OLDCONF
          echo -e $YELLOW"Removing old kernels..."$ENDCOLOR
          sudo aptitude purge $OLDKERNELS
          echo -e $YELLOW"Emptying every trashes..."$ENDCOLOR
          rm -rf /home/*/.local/share/Trash/*/** &> /dev/null
          rm -rf /root/.local/share/Trash/*/** &> /dev/null
          echo -e $YELLOW"Script Finished!"$ENDCOLOR
          for compile and execute.
          chmod + clear_tmp.sh
          sudo ./clear_tmp.sh or sudo clear_tmp.sh in any point
          And the second for cleaning clean orphans.
          requirement. Deborphan
          for install type:
          sudo aptitude install deborphan
          in the same terminal type.
          sudo nano /usr/sbin/clean_orphans.sh
          GNU nano 2.0.9 File: clean_orphans.sh
          #!/bin/bash
          # clean_orphans.sh #
          for i in `deborphan --show-size --guess-all`
          do
          packages="$packages $i"
          done
          echo
          echo "************************************************* "
          echo "Waste packages (not necessary) to be deleted:"
          echo $packages
          echo "Would you like continue? (Y/n)?"
          read
          if [ "$REPLY" = "n" ]; then
          cancel
          else
          sudo aptitude purge $packages
          fi
          for compile and execute type.
          sudo chmod +x clean_orphans
          sudo ./clean_orphans.sh
          or save them into /usr/sbin/ and you can run these from any point.
          sudo clear_tmp.sh
          sudo clean_orphans.sh
          --> many times that you need.
          The final result is:
          The second code you must to execute many times because some packages will be orphans too.
          MY SECOND PROBLEM I CAN'T STARTING "STARTX"
          Now, I can using startx in root only.
          The XKEYBOARD keymap compiler (xkbcomp) reports:
          > Warning: Type "one level" has 1 levels, but <RALT> has 2 symbols
          > Ignoring extra symbols
          > Error: bad length in CompatMap
          > Output file "/tmp/server-0.xkm" removed
          Errors from xkbcomp are not fatal to the Xserver
          (EE) Error compiling keyMap (server-0)
          (EE) XKB: couldn't compile KeyMap
          Waiting for X server to shutdown error setting MTRR (base = 0xd0000000, size = 04000000, type =1) Invalid argument (22)
          ddxSigGiveUp: Closing log
          How could I solve this problem?
            Good morning Glad you got some space to work with.
            A quick hint on readability: Could you add code and/or quote tags where appropriate? Just makes it easier to get on overview.
            Now on to X. Could you just give us a quick rundown of your boot process. I take it you boot into the shell? What does startx give you? What does sudo /etc/init.d/kdm start give you? You could always try to reinstall Xorg (you are on karmic, are you not?). If none of the above yield a result check your logs -> /var/log/Xorg.0.log for any error messages you could google.
              Hellow toad and thanks.
              yeah I've got many problems with cache space and don't let me install any program.
              I've solved the issue following these steps. It take many time while I searched into into /var folder.
              This is only experimental But I couldn't solve the space into /var/cache/man folder yet , for now works excelent in root because I haven't solve the X server issue.
              type.
              from root
              su
              password:
              type
              nano /usr/sbin/clear_cache.sh
              #!/bin/bash
              %' Clean cache manually'
              rm /var/cache/apt/archives/*.deb
              rm /var/cache/apt/*.bin
              rm /var/cache/fontconfig/*
              cat dato1 > /var/cache/ldconfig/aux-cache
              rm /var/cache/samba/*
              rm /var/cache/hald/*
              rm /var/lib/apt/lists/ /var/lib/apt/lists/partial
              rm /var/lib/defoma/x-ttcidfont-conf.d/id-cache
              rm /var/lib/doc-base/info/*.db
              rm /var/lib/mlocate/*.db
              rm /var/tmp/serverauth.Lux39DLGwa
              rm /var/tmp/kdecache-*/*
              rm /var/tmp/kdecache-*/favicons/*
              rm -R /var/tmp/kdecache-*/http/*
              rm /var/tmp/kdecache-*/ksplashx/*
              aptitude remove
              aptitude clean
              aptitude autoclean
              apt-get remove
              apt-get autoremove
              apt-get clean
              %'removing old config files'
              %'removing old kernels'
              aptitude dist-upgrade
              aptitude update
              aptitude safe-upgrade
              chmod +x /usr/sbin/clear_cache.sh
              for execute:
              from root type: clear_cache.sh
              from user type: sudo clear_cache.sh s work sudo let that you working as root
              This code I've used if have got any problems with cache space. but I repeat I can't solve the space in /var/cache/man folder this don't implies any problem for now. and this could be happen if you're working root in KDE root.
              I'll try to reinstall Xorg.
                i've just to solve my problem and reinstall Xorg again reboot my computer. run clear_tmp code and this remove 2 programs of linux-headers. Now linux works excelent,
                Install xserver-xorg-input-vmmouse because my keyboard and mouse doesn't working.
                Thanks Toad.
                  I'm happy to say that I've done nothing - you have done all the hard work - good job!
                  Could you please mark this topic as solved (see my signature for instructions).
                  Thanks and happy computing
                    Re: No space left on device and startx problem .
                    I'm understand something. When you working in KDE as root you haven't enough cache I use the last code for every time that I was installing something. This save my live.
                    The solution.
                    Enter as root in KDE (you can enter from recovery mode in Boot or typing su from user).
                    run clear_cache.sh
                    every time that you don't have space left run this program. Try to work in terminal KDE because KDE spends so much cache.
                    I installed the following packages (I searched into KPackageKit application in KDE root and the return in terminal doing click on logout):
                    xserver-xorg-video-all (video)
                    xserver-xorg-input-all (mouse, keyboard, and others)
                    sudo aptitude reinstall xorg
                    sudo aptitude reinstall xserver-xorg
                    sudo aptitude reinstall kubuntu-desktop
                    type
                    sudo clear-tmp.sh . for removing obsolete programs
                    sudo clean_orphans.sh for remove orphans dependencies.
                    if you want delete the command History type
                    sudo cat ~/.bash_history > /home/user/Desktop/command_history.txt (optional if you want to save it in Desktop)
                    sudo rm ~/.bash_history Eliminate the command History.
                    These programs are in the beginning of this post.
                      I hope that this work help you to solve this kind of problems.
                        continue the problems
                        Again fails Startx when I updated aptitude.
                        This is the main problem is with the old drivers. when I try to install linux-headers have got some issues with dependencies anmet.
                        root@andgmdlaptop:~# apt-get dist-upgrade
                        You might want to run `apt-get -f install' to correct these.
                        linux-headers-2.6.31-19-generic: Depends: linux-headers-2.6.31-19 but it is not installed
                        E: Unmet dependencies. Try using -f.
                        root@andgmdlaptop:~# aptitude dist-upgrade
                        1 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        Need to get 3,396B of archives. After unpacking 0B will be used.
                        linux-headers-2.6.31-19-generic: Depends: linux-headers-2.6.31-19 but it is not installable
                        Score is 41
                        1 packages upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                        Need to get 3,396B/9,535kB of archives. After unpacking 73.3MB will be used.
                        Get:1 http://es.archive.ubuntu.com karmic-updates/main linux-headers-generic 2.6.31.20.33 [3,396B]
                        Fetched 3,396B in 3s (932B/s)
                        (Reading database ... 147375 files and directories currently installed.)
                        failed in buffer_write(fd) (10, ret=-1): backend dpkg-deb during `./usr/src/linux-headers-2.6.31-19/arch/cris/include/arch-v32/mach-a3/mach/hwregs/marb_bar_defs.h': No space left on device
                        Preparing to replace linux-headers-generic 2.6.31.19.32 (using .../linux-headers-generic_2.6.31.20.33_amd64.deb) ...
                        Setting up linux-headers-generic (2.6.31.20.33) ...
                        Current status: 0 updates [-1].
                        root@andgmdlaptop:~# dpkg --configure -a
                        linux-headers-2.6.31-20{p} linux-headers-2.6.31-20-generic{p}
                        0 packages upgraded, 2 newly installed, 2 to remove and 0 not upgraded.
                        Need to get 9,526kB/19.1MB of archives. After unpacking 64.4MB will be used.
                        linux-headers-generic [2.6.31.20.33 (karmic-updates, now) -> 2.6.31.19.32 (karmic-security)]
                        Score is 80
                        0 packages upgraded, 2 newly installed, 1 downgraded, 2 to remove and 0 not upgraded.
                        Need to get 9,530kB/19.1MB of archives. After unpacking 64.4MB will be used.
                        Get:2 http://es.archive.ubuntu.com karmic/main linux-headers-2.6.31-14 2.6.31-14.48 [9,526kB]
                        Fetched 9,530kB in 9s (954kB/s)
                        failed in buffer_write(fd) (10, ret=-1): backend dpkg-deb during `./usr/src/linux-headers-2.6.31-19/arch/blackfin/mach-bf533/include/mach/defBF532.h': No space left on device
                        dpkg: warning: downgrading linux-headers-generic from 2.6.31.20.33 to 2.6.31.19.32.
                        root@andgmdlaptop:~# aptitude -f remove xorg
                        kubuntu-desktop linux-headers-2.6.31-19-generic
                        xorg
                        0 packages upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                        Need to get 0B of archives. After unpacking 24.6kB will be freed.
                        kubuntu-desktop: Depends: xorg but it is not installable
                        Remove the following packages:
                        kubuntu-desktop
                        Score is 110
                        kubuntu-desktop{a} xorg
                        0 packages upgraded, 1 newly installed, 2 to remove and 0 not upgraded.
                        Need to get 0B/9,531kB of archives. After unpacking 73.2MB will be used.
                        failed in buffer_write(fd) (10, ret=-1): backend dpkg-deb during `./usr/src/linux-headers-2.6.31-19/arch/avr32/include/asm/cacheflush.h': No space left on device
                        root@andgmdlaptop:~# reboot
                        I booted like recover mode and access to pkgs repair broken packages.
                          Same problem, same solution. And next time you try again, you will run into the same problem again!
                          / should at least be 5GB. Use a live CD and gparted or similar to adjust your partition size.
                            Yes i think the same.
                            I will reinstall Kubuntu. I've got this partitions.
                            112G for windows and 12 G for linux
                            What partition size you recomended me for swap Root and data into 12G?.
                              But my main problem is not the disk size. is when I try to install linux headers. I got problems with these dependencies. This is the problem that I had before. When this issue was solved linux uninstall this packages and startx works but now i cant unnistall.
                              Iĺl show you.
                              xorg
                              kubuntu-desktop
                              Score is 110
