I have made several posts regarding this problem, and so far no solutions. So I am going to summarize what I know here, and see if any ideas emerge.
1. I cannot boot k/u/x/buntu live cds. The problem started with Jaunty -- I could boot the u/xu/buntu cds, but not kubuntu. The problem is worse in Karmic -- I cannot boot any of the live cds. What happens is I get the screen for selecting language, then the menu for run without installing, install, etc. Choosing any option results in the screen going black/blank, with a cursor in the upper left. The cd spins for a second or two, then stops, and that's it. Hard power off is the only option, no response from CTRL-ALT-DEL, ALT-SYSRQ-REISUB, or anything else.
I have tried changing F4-safe mode, f6- all of the options, and editing the boot options line, removing the quiet and splash, adding various vga= options that I know work with grub. Same death.
2. Today, I downloaded the latest Sidux CD. Sidux is, like ubuntu, a debian-sid based distribution. The last version with the 2.6.31 kernel booted fine, but todays, with a 2.6.32 kernel, dies just like the *buntu disks. Well, almost like them. I get the test screen that says the kernel is loading, the dots, then ready. Then death.
3. The lucid alpha cds do the same. Same goes for the "alternative cd", same death, same place.
4. Trying to upgrade a karmic system to lucid results in a non-working system. It appears to load the kernel, then a mess of udev messages (which I also get from a working sidux system), then a message saying it is starting the crypto disks, then death. Boot freezes, but interestingly, CTRL-ALT-DEL will reboot the system. No logs, or any other info, are being written to the file system. This suggests that the file system is not mounting. I have tried rebuilding the initramfs, removing plymouth and splash, chaning vga= and gfxpayload options - nothing.
Yeah, yeah, "lucid is alpha", I know that, but the others are not, and an ominous pattern is emerging here. I really don't want to think about what happens if I can't run linux on this system. So I want to get to the bottom of what this problem is. Or at least find out just WHAT to file a bug report on.
So I suppose I'm really on a fishing expedition here, looking for some answers.
First, to find out if there is anyone out there who has similar hardware and has it working; or maybe figured out how to get it working.
Second, if there are any ideas how to go about filing a bug report, and exactly what I should be reporting a bug with.
Third, if maybe I've missed something, or what else I could do to determine the problem.
This system is:
Dell XPS-630i
NVIDIA system board
Intel Q9550 Core2 Quad cpu (64 bit)
8gb ram
dual/sli NVIDIA GForce 9800 GT video (I have tried removing the slave card, no help)
2 sata drives, 1 sata cdrom and 1 ide cdrom
Output of lspci:
Hopefully we can sniff this out, so I won't have to bore everyone with this further...
This system is:
Dell XPS-630i
NVIDIA system board
8gb ram
Output of lspci:
00:00.0 Host bridge: nVidia Corporation C55 Host Bridge (rev a2) 00:00.1 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:00.2 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:00.3 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:00.4 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:00.5 RAM memory: nVidia Corporation C55 Memory Controller (rev a2) 00:00.6 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:00.7 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:01.0 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:01.1 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:01.2 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:01.3 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:01.4 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:01.5 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:01.6 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:02.0 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:02.1 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:02.2 RAM memory: nVidia Corporation C55 Memory Controller (rev a1) 00:03.0 PCI bridge: nVidia Corporation C55 PCI Express bridge (rev a1) 00:05.0 PCI bridge: nVidia Corporation C55 PCI Express bridge (rev a1) 00:09.0 RAM memory: nVidia Corporation MCP51 Host Bridge (rev a2) 00:0a.0 ISA bridge: nVidia Corporation MCP51 LPC Bridge (rev a3) 00:0a.1 SMBus: nVidia Corporation MCP51 SMBus (rev a3) 00:0a.2 RAM memory: nVidia Corporation MCP51 Memory Controller 0 (rev a3) 00:0b.0 USB Controller: nVidia Corporation MCP51 USB Controller (rev a3) 00:0b.1 USB Controller: nVidia Corporation MCP51 USB Controller (rev a3) 00:0d.0 IDE interface: nVidia Corporation MCP51 IDE (rev a1) 00:0e.0 RAID bus controller: nVidia Corporation MCP51 Serial ATA Controller (rev a1) 00:0f.0 RAID bus controller: nVidia Corporation MCP51 Serial ATA Controller (rev a1) 00:10.0 PCI bridge: nVidia Corporation MCP51 PCI Bridge (rev a2) 00:10.1 Audio device: nVidia Corporation MCP51 High Definition Audio (rev a2) 00:14.0 Bridge: nVidia Corporation MCP51 Ethernet Controller (rev a3) 01:00.0 VGA compatible controller: nVidia Corporation G92 [GeForce 9800 GT] (rev a2) 02:00.0 VGA compatible controller: nVidia Corporation G92 [GeForce 9800 GT] (rev a2) 03:05.0 FireWire (IEEE 1394): Agere Systems FW322/323 (rev 70) 03:07.0 Communication controller: Conexant Systems, Inc. HSF 56k Data/Fax Modem 03:08.0 Audio device: Creative Labs SB X-Fi
