I tried the edgy live cd which worked fine untill I installed it; wireless assistant showed my network twice and couldn't connect to anything.
I'm currently using dapper and whenever I use wireless assistant to connect to my network it says "connection failed" but if I click refresh it connects straight away.
Is there an alternative to wireless assistant to connect to a network?
also, is wireless assistant a frontend for something? could I connect from the command line?
I've installed Kwlan but it doesn't seem to have an option to use ath0 instead of eth0 and I've installed KWiFiManager but it doesn't seem to have a function for actually connecting to a network.
Auisce
Auisce
