KubuntuForums and ZB-Block
    mine says (get_config) instead.
    Might need to update the tapatalk plugin. It's at 5.6.14, and the latest is 5.7.4
    https://tapatalk.com/download_vBulletin.php
      Thank you claydoh. Tapatalk plugin just updated to 5.7.4 and the Push Notification test shows success.
      Slava Ukraini! πŸ‡ΊπŸ‡¦
        still no go for me, just for KFN.
        dunno if it means much but
        https://www.kubuntuforums.net/mobiquo/status.php
        There probably aren't more than a handful of us using it, seeing the lack of comments about it. The mobile web theme here is extremely clunky/buggy for me nowadays.
          Plugin directory/files status
          Plugin directory permissions: 0755
          Plugin files permissions: 0644
          Can write in plugin directory: No
          Can execute mobiquo.php file: Yes
          Can execute upload.php file: Yes
          Should the mobiquo directory be writable?
            Looking into it briefly, I think this is output is correct, so 'nothing to see here'.
              I sort of figure that was so. I hate sites that don't provide Legend information. In this case, they are using color and Yes/No to convey 'meaningful' information. One assumes that Yes is 'good' and No is 'not good', but then they further confuse by making the words (Yes/No) either Green (again, 'good') or Yellow ('questionable'?), and I assume also Red ('bad').
