Unanswered posts
    Unanswered posts
    I've just spent half an hour trying to find a link to unanswered posts so I could be of some use to others.
    As I still can't find a link, I suspect others may be put off helping for the same reason!
    Where the hell is the link to unanswered questions, and why isn't it more obvious on the site?
    Re: Unanswered posts
    Well you can always sort the forums lists by 'Replies'. That brings up the all of the posts with not replies. I know it's not a link, but is a work around!
    Weaseling out of things is important to learn. It's what separates us from the animals ... except the weasel.
      Thanks for the info, hope the Forum chiefs take note though.
        Correction -- Chief (singular)
        OpenSource is a good guy, and runs this thing all by himself, and without compensation!
        I just go into the Gutsy section, and open the "Installation" or "Software" subject, and look for "0" on the replies column -- and see if I can do anything for them. I'm not sure a more elegant link would accomplish much. I guess it would get all the folks that I can't help onto a single list ..... :P
          Does a great job too!
            me, I just go to view all new posts, and don't always look for 0 replies, as even one or two replies may not be solved topics.
              as far as i can see, this feature isn't yet available in smf, though some are working on a mod for it.
                There used to be a "show posts with no replies" link in the top bar (where the "Show unread posts since last visit" link is)...I wonder what happened to it :P
                  http://www.simplemachines.org/commun...topic=210127.0
                  but that led me to this
                  http://custom.simplemachines.org/mods/index.php?mod=965
                  so it is relatively new, and requires the theme to be hacked. If we had that link before, perhaps a forum update/theme update got rid of it?
                    I think I took it out upon request, but I don't remember for sure. I didn't really want to have too many links in the top right hand box. If everyone would really like the said link, I can try and add it back.
                      The link has been added back. Thanks
