I installed ppa-purge via the terminal after running sudo apt update.
Is the "Not building database ..." line normal in KDE neon or did I do something to break things (which I don't believe I did)? man ppa-purge works just fine.
... Fetched 1,113 kB in 3s (370 kB/s) Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. chimak@neon:~$ sudo apt install ppa-purge Reading package lists... Done Building dependency tree Reading state information... Done Starting pkgProblemResolver with broken count: 0 Starting 2 pkgProblemResolver with broken count: 0 Done Suggested packages: aptitude The following NEW packages will be installed: ppa-purge 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 6,312 B of archives. After this operation, 24.6 kB of additional disk space will be used. Get:1 http://archive.ubuntu.com/ubuntu focal/universe amd64 ppa-purge all 0.2.8+bzr63 [6,312 B] Fetched 6,312 B in 5s (1,148 B/s) Selecting previously unselected package ppa-purge. (Reading database ... 186152 files and directories currently installed.) Preparing to unpack .../ppa-purge_0.2.8+bzr63_all.deb ... Unpacking ppa-purge (0.2.8+bzr63) ... Setting up ppa-purge (0.2.8+bzr63) ... Processing triggers for man-db (2.9.1-1) ... Not building database; man-db/auto-update is not 'true'. chimak@neon:~$
