Is saving backups in Kate with time-stamp possible?
    Kate Version 18.12.1 in KDE Neon 5.14.5
    For example, if I have /home/chimak/Desktop/text.txt and I edit and save it, I would like to have the backup file stored in ~/Public/Backups with a suffix like -20180122190631 (year, month, date, hour in 24h format, minutes, and seconds).
    In Settings > Configure Kate > Open/Save>Advanced,
    I have /home/chimak/Public/Backups/ in the Prefix box
    But if I put -$(date +%Y%m%d%H%M%S) or even "-$(date +%Y%m%d%H%M%S)" in the Suffix box, both appear literally and are not converted to a time-stamp.
    So after editing /home/chimak/Desktop/text.txt, ~/Public/Backups/ has test.txt-$(date +%Y%m%d%H%M%S) or test.txt-"$(date +%Y%m%d%H%M%S)" whereas what I want is test.txt-20180122190631.
    The idea is to have time-stamped backups of files I edit with Kate in case I mess up and need to go back.
    If I use the default ~ as suffix, the incoming test.txt~ replaces the previous test.txt~.
    Also asked here: https://www.reddit.com/r/kde/comment..._backups_with/
    Kubuntu 20.04
    Geany has a "Save As" plugin, which if active, allows the user a choice of suffixes via the Plugin Preferences GUI:
    Kubuntu 20.04
      I do this with vim, it's a very good idea.
      But googling kate scripting and plugins has found no hint of an events framework, or triggers, or the like. Of course, maybe I just don't know the right search term...
      However, there's other approaches. A background script using inotifywait could do the job (minimally tested):
      #!/bin/bash
      dir_to_watch=whatever
      inotifywait -r -m --exclude '[^~]$' -e create,close --format '%w%f'  $dir_to_watch |
       while read line
       do
           newname=${line%\~}$(printf "%(%F-%T)T.bk")
           mv $line $newname
       done
      Another good idea is to check the file in to a private branch of your VCS of choice on every save; I keep meaning to set that up...
        @jlittle, Thanks for looking into this!
        The inotify route would be, I'm guessing, an always-on feature whereas with Geany (or Kate, if there's a solution) would be as and when needed. Further, I would need to specify a whole lot of directories to watch because of dir_to_watch=whatever.
        I've not ever wrapped my head around VCS
        As for my other needs, like LibreOffice documents and spreadsheets, they're in my Dropbox folder and so I can get at older versions that way.
        For now, it seems that Geany has what I need but let's hope that someone comes up with something for Kate.
        Kubuntu 20.04
          Well, it isn't available at this time: https://www.reddit.com/r/kde/comment...s_with/eerg3m5
          Kubuntu 20.04
