GUI for NTFS Auto mount?
    [SOLVED] GUI for NTFS Auto mount?
    I have seen a lot of websites mentioning that I need to edit the fstab to make my secondary NTFS SSD automount.
    But I swear I have done it before in a GUI that let me change the properties of the drive to auto mount and I can't seem to find that info.
    Any thoughts?
    system settings>removable devices>removable devices tab .
    you could try hear .
      I guess the question is a laptop internal SSD a removable device? My SSD doesn't show up in there not sure if it just needs to be checked on and it will just work. Unfortunately I just used ntfs-config so that might be interfering with it. The interface is rough but I managed to make the ssd mount through there. I guess next time I set up my system I'll try the kde setting first.
        Humm , strange , all my internal HD's ,2 (and partitions) and the one SSD show their .
        I will confess I do not use it for mounting them , the 1 I need mounted at boot (a 1TB storage drive) gets mounted through /etc/fstab to a location in /mnt .
        the rest if I need in quick like I just click them in dolphins places panel .
