Calibre Installation
    Hello
    I have a bit of time and want to use it to evaluate KDE neon. Up to now everyhing I did went well. Now I have a first problem with Calibre, A program I do use quite often. I tried to install it:
    [sudo] password for bruno:
    Reading package lists... Done
    Building dependency tree
    Starting pkgProblemResolver with broken count: 1
    Starting 2 pkgProblemResolver with broken count: 1
    Investigating (0) calibre:amd64 < none -> 3.21.0+dfsg-1build1 @un puN Ib >
    Broken calibre:amd64 Depends on calibre-bin:amd64 < none | 3.21.0+dfsg-1build1 @un uH > (>= 3.21.0+dfsg-1build1)
    Considering calibre-bin:amd64 0 as a solution to calibre:amd64 9998
    Reinst Failed early because of qtbase-abi-5-9-5:amd64
    Done
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    calibre : Depends: calibre-bin (>= 3.21.0+dfsg-1build1) but it is not going to be installed
    E: Unable to correct problems, you have held broken packages.
    Is anyone able and willing to help me?
    In Discover is a version "Calibre -- E-book Editor“ listed. Actually this would be absolutely sufficient for me. So, if there is a way to install just this, I'd be happy.
    Thanks to all.
    Greetings from Scotland's best holiday island – The Isle of Arran
    I keep fighting for an independent Scotland without any nuclear weapons. If the Englanders want them, they can host them. We do not.
    Re. Calibre, see https://forum.kde.org/viewtopic.php?f=309&t=140850
    If that doesn't help, post the entire output of sudo apt update and sudo apt full-upgrade.
    Kubuntu 20.04
      The Calibre from the Ubuntu repositories cannot be installed in Neon as it was built with and depends on different version of Qt than the one Neon has.
      So install direct from the Calibre website, which has builds that bundle their own Qt libs so it can work on any system.
      https://calibre-ebook.com/download_linux
      sudo -v && wget -nv -O- https://download.calibre-ebook.com/linux-installer.sh | sudo sh /dev/stdin
