You will probably notice today's updates have a few small updates.
Looks like the 20.04 has had the mozillateam PPA added for FF, in prep for Jammy upgrades.
For those already on Jammy, this may mess with any pinning etc.
I see this when updating after the changes:
These are from /etc/apt/preferences.d/99-jammy-overrides, not sure if they will be similar in Focal.
I already poked the devs.
it's just s W, so nothing is broken as afaik. FF is still pinned corectly, but other components might potentially be effected in the futute if not adresssed.
Theses are the additions top the file that are causing it so nothing critical
W: Did not understand pin type a=jammy W: Did not understand pin type a=jammy W: Did not understand pin type a=jammy W: Did not understand pin type a=jammy
# Neon focal shipped qtfeedback with 5.15 while jammy has 5.0 Package: libqt5feedback5 Pin: a=jammy Pin-Priority: 1100 Package: qml-module-qtfeedback Pin: a=jammy Pin-Priority: 1100 Package: qtfeedback5-dev Pin: a=jammy Pin-Priority: 1100 Package: qtfeedback5-examples Pin: a=jammy Pin-Priority: 1100
