Left mouse click NOW not working in Neon
    After an update yesterday the "left mouse click on desktop" for something like changing activities is not working as it is not working in Kubuntu Don't Mess With Zesty Zohan.
    This on KDE Neon Developers git-stable 5.10.0 ... fully updated as of this writing.
    As I have mentioned elsewhere I keep many usb sticks, and old hard drives, around with previous versions of distros on them as "fall back in case of failure" and also just to compare things.
    The SAME KDE Neon Developers git-stable 5.10.0 which was LAID ASIDE 6 days before the the date of this post ...prior to 4 June 2017...and NOT UPDATED has a fully functional left click for changing activities and right click for configuration.
    ( The reason for it being "laid aside" is that I decided to run the OS on a larger usb stick ).
    This situation should probably be considered "a bug".
    woodsmoke
    Well after an intensive search of the web I have found out a couple of things about the left mouse click on desktop thing:
    a) it is a recurring bug going back many years that comes and goes IN MOST CASES AFTER AN UPDATE ...and the situation is not resolved for...a year or more...
    b) odd things cause it like...get this ...having "mute" set on a headset, I guess while playing games that have chat enabled.
    c) a variety of fixes have worked with different distros from Manjuro to Mint... like ctrl + alt + L , or alt + win + tab or ctrl alt f1 and on and on this person says it works others say it doesn't.
    So, I did the xdiagnose thiing, it does not really work in KDE very well it has to be invoked from terminal.
    I tried the reporting thing but it said that "this is not a valid app it is not part of KDE"
    Running appport-collect -p xorg 1316873 ran me all the way through Ubuntu One and...it all worked until the end...lol...
    But, anyway, I ran xdiagnose in terminal and here is the report and for the Grey One's benefit, notice last line it BTRFS. lol
    This is on the Neon develper git-stable machine
    /usr/lib/python3/dist-packages/xdiagnose/applet.py:30: PyGIWarning: Gtk was imported without specifying a version first. Use gi.require_version('Gtk', '3.0') before import to ensure that the right version gets loaded.
    from gi.repository import Gtk
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
    [ 0.000000] Linux version 4.8.0-53-generic (buildd@lgw01-56) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.4) ) #56~16.04.1-Ubuntu SMP Tue May 16 01:18:56 UTC 2017 (Ubuntu 4.8.0-53.56~16.04.1-generic 4.8.17)
    [ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.8.0-53-generic root=UUID=9340ece8-7d51-4b35-b089-d197e9dee430 ro quiet splash vt.handoff=7
    [ 0.000000] KERNEL supported cpus:
    [ 0.000000] Intel GenuineIntel
    [ 0.000000] AMD AuthenticAMD
    [ 0.000000] Centaur CentaurHauls
    [ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
    [ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
    [ 0.000000] x86/fpu: Enabled xstate features 0x3, context size is 576 bytes, using 'standard' format.
    [ 0.000000] x86/fpu: Using 'eager' FPU context switches.
    [ 0.000000] e820: BIOS-provided physical RAM map:
    [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dbff] usable
    [ 0.000000] BIOS-e820: [mem 0x000000000009dc00-0x000000000009ffff] reserved
    [ 0.000000] BIOS-e820: [mem 0x00000000000e5000-0x00000000000fffff] reserved
    [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bff8ffff] usable
    [ 0.000000] BIOS-e820: [mem 0x00000000bff90000-0x00000000bff9dfff] ACPI data
    [ 0.000000] BIOS-e820: [mem 0x00000000bff9e000-0x00000000bffdffff] ACPI NVS
    [ 0.000000] BIOS-e820: [mem 0x00000000bffe0000-0x00000000bfffffff] reserved
    [ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
    [ 0.000000] BIOS-e820: [mem 0x00000000ffb00000-0x00000000ffffffff] reserved
    [ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000013fffffff] usable
    [ 0.000000] NX (Execute Disable) protection: active
    [ 0.000000] SMBIOS 2.6 present.
    [ 0.000000] DMI: Acer Aspire M3900/EG43M, BIOS P01-B0 06/01/2010
    [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
    [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
    [ 0.000000] e820: last_pfn = 0x140000 max_arch_pfn = 0x400000000
    [ 0.000000] MTRR default type: uncachable
    [ 0.000000] MTRR fixed ranges enabled:
    [ 0.000000] 00000-9FFFF write-back
    [ 0.000000] A0000-BFFFF uncachable
    [ 0.000000] C0000-CFFFF write-protect
    [ 0.000000] D0000-DFFFF uncachable
    [ 0.000000] E0000-EFFFF write-through
    [ 0.000000] F0000-FFFFF write-protect
    [ 0.000000] MTRR variable ranges enabled:
    [ 0.000000] 0 base 000000000 mask F00000000 write-back
    [ 0.000000] 1 base 100000000 mask FC0000000 write-back
    [ 0.000000] 2 base 0C0000000 mask FC0000000 uncachable
    [ 0.000000] 3 disabled
    [ 0.000000] 4 disabled
    [ 0.000000] 5 disabled
    [ 0.000000] 6 disabled
    [ 0.000000] 7 disabled
    [ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
    [ 0.000000] total RAM covered: 4096M
    [ 0.000000] Found optimal setting for mtrr clean up
    [ 0.000000] gran_size: 64K chunk_size: 64K num_reg: 3 lose cover RAM: 0G
    [ 0.000000] e820: update [mem 0xc0000000-0xffffffff] usable ==> reserved
    [ 0.000000] e820: last_pfn = 0xbff90 max_arch_pfn = 0x400000000
    [ 0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [ffff9db4000ff780]
    [ 0.000000] Scanning 1 areas for low memory corruption
    [ 0.000000] Base memory trampoline at [ffff9db400097000] 97000 size 24576
    [ 0.000000] BRK [0x13663b000, 0x13663bfff] PGTABLE
    [ 0.000000] BRK [0x13663c000, 0x13663cfff] PGTABLE
    [ 0.000000] BRK [0x13663d000, 0x13663dfff] PGTABLE
    [ 0.000000] BRK [0x13663e000, 0x13663efff] PGTABLE
    [ 0.000000] BRK [0x13663f000, 0x13663ffff] PGTABLE
    [ 0.000000] BRK [0x136640000, 0x136640fff] PGTABLE
    [ 0.000000] BRK [0x136641000, 0x136641fff] PGTABLE
    [ 0.000000] BRK [0x136642000, 0x136642fff] PGTABLE
    [ 0.000000] RAMDISK: [mem 0x33062000-0x35828fff]
    [ 0.000000] ACPI: Early table checksum verification disabled
    [ 0.000000] ACPI: RSDP 0x00000000000FA720 000014 (v00 ACPIAM)
    [ 0.000000] ACPI: RSDT 0x00000000BFF90000 000048 (v01 ACRSYS ACRPRDCT 20100601 MSFT 00000097)
    [ 0.000000] ACPI: FACP 0x00000000BFF90200 000084 (v01 060110 FACP1940 20100601 MSFT 00000097)
    [ 0.000000] ACPI: DSDT 0x00000000BFF905C0 006BDB (v01 1AAAA 1AAAA000 00000000 INTL 20051117)
    [ 0.000000] ACPI: FACS 0x00000000BFF9E000 000040
    [ 0.000000] ACPI: APIC 0x00000000BFF90390 00006C (v01 060110 APIC1940 20100601 MSFT 00000097)
    [ 0.000000] ACPI: MCFG 0x00000000BFF90400 00003C (v01 060110 OEMMCFG 20100601 MSFT 00000097)
    [ 0.000000] ACPI: SLIC 0x00000000BFF90440 000176 (v01 ACRSYS ACRPRDCT 20100601 MSFT 00000097)
    [ 0.000000] ACPI: OEMB 0x00000000BFF9E040 000072 (v01 060110 OEMB1940 20100601 MSFT 00000097)
    [ 0.000000] ACPI: HPET 0x00000000BFF985C0 000038 (v01 060110 OEMHPET 20100601 MSFT 00000097)
    [ 0.000000] ACPI: GSCI 0x00000000BFF9E0C0 002024 (v01 060110 GMCHSCI 20100601 MSFT 00000097)
    [ 0.000000] ACPI: AWMI 0x00000000BFFA00F0 00004E (v01 060110 OEMB1940 20100601 MSFT 00000097)
    [ 0.000000] ACPI: SSDT 0x00000000BFFA0C10 000A7C (v01 DpgPmm CpuPm 00000012 INTL 20051117)
    [ 0.000000] ACPI: Local APIC address 0xfee00000
    [ 0.000000] No NUMA configuration found
    [ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000013fffffff]
    [ 0.000000] NODE_DATA(0) allocated [mem 0x13fffb000-0x13fffffff]
    [ 0.000000] Zone ranges:
    [ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
    [ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
    [ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff]
    [ 0.000000] Device empty
    [ 0.000000] Movable zone start for each node
    [ 0.000000] Early memory node ranges
    [ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009cfff]
    [ 0.000000] node 0: [mem 0x0000000000100000-0x00000000bff8ffff]
    [ 0.000000] node 0: [mem 0x0000000100000000-0x000000013fffffff]
    [ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000013fffffff]
    [ 0.000000] On node 0 totalpages: 1048364
    [ 0.000000] DMA zone: 64 pages used for memmap
    [ 0.000000] DMA zone: 21 pages reserved
    [ 0.000000] DMA zone: 3996 pages, LIFO batch:0
    [ 0.000000] DMA32 zone: 12223 pages used for memmap
    [ 0.000000] DMA32 zone: 782224 pages, LIFO batch:31
    [ 0.000000] Normal zone: 4096 pages used for memmap
    [ 0.000000] Normal zone: 262144 pages, LIFO batch:31
    [ 0.000000] ACPI: PM-Timer IO Port: 0x808
    [ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
    [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
    [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
    [ 0.000000] ACPI: IRQ0 used by override.
    [ 0.000000] ACPI: IRQ9 used by override.
    [ 0.000000] Using ACPI (MADT) for SMP configuration information
    [ 0.000000] ACPI: HPET id: 0x8086a301 base: 0xfed00000
    [ 0.000000] smpboot: Allowing 4 CPUs, 2 hotplug CPUs
    [ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
    [ 0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
    [ 0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
    [ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000e4fff]
    [ 0.000000] PM: Registered nosave memory: [mem 0x000e5000-0x000fffff]
    [ 0.000000] PM: Registered nosave memory: [mem 0xbff90000-0xbff9dfff]
    [ 0.000000] PM: Registered nosave memory: [mem 0xbff9e000-0xbffdffff]
    [ 0.000000] PM: Registered nosave memory: [mem 0xbffe0000-0xbfffffff]
    [ 0.000000] PM: Registered nosave memory: [mem 0xc0000000-0xfedfffff]
    [ 0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
    [ 0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xffafffff]
    [ 0.000000] PM: Registered nosave memory: [mem 0xffb00000-0xffffffff]
    [ 0.000000] e820: [mem 0xc0000000-0xfedfffff] available for PCI devices
    [ 0.000000] Booting paravirtualized kernel on bare hardware
    [ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
    [ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
    [ 0.000000] percpu: Embedded 36 pages/cpu @ffff9db53fc00000 s107864 r8192 d31400 u524288
    [ 0.000000] pcpu-alloc: s107864 r8192 d31400 u524288 alloc=1*2097152
    [ 0.000000] pcpu-alloc: [0] 0 1 2 3
    [ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 1031960
    [ 0.000000] Policy zone: Normal
    [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.8.0-53-generic root=UUID=9340ece8-7d51-4b35-b089-d197e9dee430 ro quiet splash vt.handoff=7
    [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
    [ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
    [ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
    [ 0.000000] Memory: 4001492K/4193456K available (8829K kernel code, 1441K rwdata, 3836K rodata, 1548K init, 1296K bss, 191964K reserved, 0K cma-reserved)
    [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [ 0.000000] Hierarchical RCU implementation.
    [ 0.000000] Build-time adjustment of leaf fanout to 64.
    [ 0.000000] RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
    [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
    [ 0.000000] NR_IRQS:33024 nr_irqs:456 16
    [ 0.000000] vt handoff: transparent VT on vt#7
    [ 0.000000] Console: colour dummy device 80x25
    [ 0.000000] console [tty0] enabled
    [ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
    [ 0.000000] hpet clockevent registered
    [ 0.000000] tsc: Fast TSC calibration failed
    [ 0.000000] tsc: PIT calibration matches HPET. 1 loops
    [ 0.000000] tsc: Detected 2799.953 MHz processor
    [ 0.008012] Calibrating delay loop (skipped), value calculated using timer frequency.. 5599.90 BogoMIPS (lpj=11199812)
    [ 0.008015] pid_max: default: 32768 minimum: 301
    [ 0.008027] ACPI: Core revision 20160422
    [ 0.015348] ACPI: 2 ACPI AML tables successfully acquired and loaded
    [ 0.015379] Security Framework initialized
    [ 0.015381] Yama: becoming mindful.
    [ 0.015401] AppArmor: AppArmor initialized
    [ 0.015659] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
    [ 0.017586] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
    [ 0.018624] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
    [ 0.018631] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
    [ 0.019048] CPU: Physical Processor ID: 0
    [ 0.019050] CPU: Processor Core ID: 0
    [ 0.019052] mce: CPU supports 6 MCE banks
    [ 0.019060] CPU0: Thermal monitoring enabled (TM2)
    [ 0.019065] process: using mwait in idle threads
    [ 0.019071] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
    [ 0.019072] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
    [ 0.019433] Freeing SMP alternatives memory: 32K (ffffffff99aed000 - ffffffff99af5000)
    [ 0.024004] ftrace: allocating 33454 entries in 131 pages
    [ 0.032138] smpboot: APIC(0) Converting physical 0 to logical package 0
    [ 0.032139] smpboot: Max logical packages: 2
    [ 0.032949] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
    [ 0.076000] smpboot: CPU0: Intel Pentium(R) Dual-Core CPU E5500 @ 2.80GHz (family: 0x6, model: 0x17, stepping: 0xa)
    [ 0.076000] Performance Events: PEBS fmt0+, Core2 events, Intel PMU driver.
    [ 0.076000] ...
    version: 2
    [ 0.076000] ... bit width: 40
    [ 0.076000] ... generic registers: 2
    [ 0.076000] ... value mask: 000000ffffffffff
    [ 0.076000] ... max period: 000000007fffffff
    [ 0.076000] ... fixed-purpose events: 3
    [ 0.076000] ... event mask: 0000000700000003
    [ 0.076000] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
    [ 0.076000] x86: Booting SMP configuration:
    [ 0.076000] ...
    node #0, CPUs: #1
    [ 0.076000] x86: Booted up 1 node, 2 CPUs
    [ 0.076000] smpboot: Total of 2 processors activated (11199.81 BogoMIPS)
    [ 0.076272] devtmpfs: initialized
    [ 0.076272] x86/mm: Memory block size: 128MB
    [ 0.076521] evm: security.selinux
    [ 0.076522] evm: security.SMACK64
    [ 0.076522] evm: security.SMACK64EXEC
    [ 0.076523] evm: security.SMACK64TRANSMUTE
    [ 0.076523] evm: security.SMACK64MMAP
    [ 0.076524] evm: security.ima
    [ 0.076525] evm: security.capability
    [ 0.080010] PM: Registering ACPI NVS region [mem 0xbff9e000-0xbffdffff] (270336 bytes)
    [ 0.080010] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [ 0.080010] pinctrl core: initialized pinctrl subsystem
    [ 0.080010] RTC time: 11:18:03, date: 06/05/17
    [ 0.080010] NET: Registered protocol family 16
    [ 0.092008] cpuidle: using governor ladder
    [ 0.108006] cpuidle: using governor menu
    [ 0.108009] PCCT header not found.
    [ 0.108079] ACPI: bus type PCI registered
    [ 0.108082] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
    [ 0.108214] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
    [ 0.108215] PCI: not using MMCONFIG
    [ 0.108216] PCI: Using configuration type 1 for base access
    [ 0.128074] HugeTLB registered 2 MB page size, pre-allocated 0 pages
    [ 0.128079] ACPI: Added _OSI(Module Device)
    [ 0.128079] ACPI: Added _OSI(Processor Device)
    [ 0.128080] ACPI: Added _OSI(3.0 _SCP Extensions)
    [ 0.128081] ACPI: Added _OSI(Processor Aggregator Device)
    [ 0.128296] ACPI: Executed 1 blocks of module-level executable AML code
    [ 0.130961] ACPI: Dynamic OEM Table Load:
    [ 0.130967] ACPI: SSDT 0xFFFF9DB53A58DC00 0002B9 (v01 DpgPmm P001Ist 00000011 INTL 20051117)
    [ 0.131277] ACPI: Dynamic OEM Table Load:
    [ 0.131282] ACPI: SSDT 0xFFFF9DB53A5CA000 0004B2 (v01 PmRef P001Cst 00003001 INTL 20051117)
    [ 0.132115] ACPI: Dynamic OEM Table Load:
    [ 0.132120] ACPI: SSDT 0xFFFF9DB53A58F800 0002B9 (v01 DpgPmm P002Ist 00000012 INTL 20051117)
    [ 0.132409] ACPI: Dynamic OEM Table Load:
    [ 0.132413] ACPI: SSDT 0xFFFF9DB53A5C7840 000085 (v01 PmRef P002Cst 00003000 INTL 20051117)
    [ 0.134186] ACPI: Interpreter enabled
    [ 0.134202] ACPI: (supports S0 S3 S4 S5)
    [ 0.134203] ACPI: Using IOAPIC for interrupt routing
    [ 0.134229] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
    [ 0.136025] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
    [ 0.136036] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
    [ 0.144267] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
    [ 0.144272] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
    [ 0.144398] acpi PNP0A08:00: _OSC: platform does not support [PCIeCapability]
    [ 0.144458] acpi PNP0A08:00: _OSC: not requesting control; platform does not support [PCIeCapability]
    [ 0.144459] acpi PNP0A08:00: _OSC: OS requested [PCIeHotplug PME AER PCIeCapability]
    [ 0.144461] acpi PNP0A08:00: _OSC: platform willing to grant [PCIeHotplug PME AER]
    [ 0.144462] acpi PNP0A08:00: _OSC failed (AE_SUPPORT); disabling ASPM
    [ 0.144686] PCI host bridge to bus 0000:00
    [ 0.144688] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
    [ 0.144689] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
    [ 0.144690] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
    [ 0.144691] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff window]
    [ 0.144693] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xdfffffff window]
    [ 0.144694] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfed8ffff window]
    [ 0.144696] pci_bus 0000:00: root bus resource [bus 00-ff]
    [ 0.144703] pci 0000:00:00.0: [8086:2e20] type 00 class 0x060000
    [ 0.144726] DMAR: Forcing write-buffer flush capability
    [ 0.144727] DMAR: Disabling IOMMU for graphics on this chipset
    [ 0.144804] pci 0000:00:01.0: [8086:2e21] type 01 class 0x060400
    [ 0.144840] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
    [ 0.144879] pci 0000:00:01.0: System wakeup disabled by ACPI
    [ 0.144941] pci 0000:00:1a.0: [8086:3a37] type 00 class 0x0c0300
    [ 0.144979] pci 0000:00:1a.0: reg 0x20: [io 0xbc00-0xbc1f]
    [ 0.145063] pci 0000:00:1a.0: System wakeup disabled by ACPI
    [ 0.145107] pci 0000:00:1a.1: [8086:3a38] type 00 class 0x0c0300
    [ 0.145144] pci 0000:00:1a.1: reg 0x20: [io 0xb880-0xb89f]
    [ 0.145226] pci 0000:00:1a.1: System wakeup disabled by ACPI
    [ 0.145271] pci 0000:00:1a.2: [8086:3a39] type 00 class 0x0c0300
    [ 0.145309] pci 0000:00:1a.2: reg 0x20: [io 0xb800-0xb81f]
    [ 0.145389] pci 0000:00:1a.2: System wakeup disabled by ACPI
    [ 0.145437] pci 0000:00:1a.7: [8086:3a3c] type 00 class 0x0c0320
    [ 0.145453] pci 0000:00:1a.7: reg 0x10: [mem 0xfe8ffc00-0xfe8fffff]
    [ 0.145531] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
    [ 0.145572] pci 0000:00:1a.7: System wakeup disabled by ACPI
    [ 0.145618] pci 0000:00:1b.0: [8086:3a3e] type 00 class 0x040300
    [ 0.145632] pci 0000:00:1b.0: reg 0x10: [mem 0xfe8f8000-0xfe8fbfff 64bit]
    [ 0.145697] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
    [ 0.145778] pci 0000:00:1c.0: [8086:3a40] type 01 class 0x060400
    [ 0.145836] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
    [ 0.145878] pci 0000:00:1c.0: System wakeup disabled by ACPI
    [ 0.145923] pci 0000:00:1c.1: [8086:3a42] type 01 class 0x060400
    [ 0.145986] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
    [ 0.146028] pci 0000:00:1c.1: System wakeup disabled by ACPI
    [ 0.146076] pci 0000:00:1d.0: [8086:3a34] type 00 class 0x0c0300
    [ 0.146113] pci 0000:00:1d.0: reg 0x20: [io 0xb480-0xb49f]
    [ 0.146194] pci 0000:00:1d.0: System wakeup disabled by ACPI
    [ 0.146239] pci 0000:00:1d.1: [8086:3a35] type 00 class 0x0c0300
    [ 0.146276] pci 0000:00:1d.1: reg 0x20: [io 0xb400-0xb41f]
    [ 0.146356] pci 0000:00:1d.1: System wakeup disabled by ACPI
    [ 0.146399] pci 0000:00:1d.2: [8086:3a36] type 00 class 0x0c0300
    [ 0.146436] pci 0000:00:1d.2: reg 0x20: [io 0xb080-0xb09f]
    [ 0.146517] pci 0000:00:1d.2: System wakeup disabled by ACPI
    [ 0.146566] pci 0000:00:1d.7: [8086:3a3a] type 00 class 0x0c0320
    [ 0.146582] pci 0000:00:1d.7: reg 0x10: [mem 0xfe8ff800-0xfe8ffbff]
    [ 0.146659] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
    [ 0.146699] pci 0000:00:1d.7: System wakeup disabled by ACPI
    [ 0.146742] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
    [ 0.146821] pci 0000:00:1e.0: System wakeup disabled by ACPI
    [ 0.146866] pci 0000:00:1f.0: [8086:3a16] type 00 class 0x060100
    [ 0.146939] pci 0000:00:1f.0: quirk: [io 0x0800-0x087f] claimed by ICH6 ACPI/GPIO/TCO
    [ 0.146943] pci 0000:00:1f.0: quirk: [io 0x0480-0x04bf] claimed by ICH6 GPIO
    [ 0.146945] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0a00 (mask 00ff)
    [ 0.147046] pci 0000:00:1f.2: [8086:2822] type 00 class 0x010400
    [ 0.147060] pci 0000:00:1f.2: reg 0x10: [io 0xb000-0xb007]
    [ 0.147066] pci 0000:00:1f.2: reg 0x14: [io 0xac00-0xac03]
    [ 0.147073] pci 0000:00:1f.2: reg 0x18: [io 0xa880-0xa887]
    [ 0.147079] pci 0000:00:1f.2: reg 0x1c: [io 0xa800-0xa803]
    [ 0.147086] pci 0000:00:1f.2: reg 0x20: [io 0xa480-0xa49f]
    [ 0.147093] pci 0000:00:1f.2: reg 0x24: [mem 0xfe8ff000-0xfe8ff7ff]
    [ 0.147130] pci 0000:00:1f.2: PME# supported from D3hot
    [ 0.147208] pci 0000:00:1f.3: [8086:3a30] type 00 class 0x0c0500
    [ 0.147222] pci 0000:00:1f.3: reg 0x10: [mem 0xfe8fec00-0xfe8fecff 64bit]
    [ 0.147240] pci 0000:00:1f.3: reg 0x20: [io 0x0400-0x041f]
    [ 0.147364] pci 0000:01:00.0: [1002:954f] type 00 class 0x030000
    [ 0.147377] pci 0000:01:00.0: reg 0x10: [mem 0xd0000000-0xdfffffff 64bit pref]
    [ 0.147386] pci 0000:01:00.0: reg 0x18: [mem 0xfe9f0000-0xfe9fffff 64bit]
    [ 0.147393] pci 0000:01:00.0: reg 0x20: [io 0xc000-0xc0ff]
    [ 0.147404] pci 0000:01:00.0: reg 0x30: [mem 0xfe9c0000-0xfe9dffff pref]
    [ 0.147436] pci 0000:01:00.0: supports D1 D2
    [ 0.147483] pci 0000:01:00.1: [1002:aa38] type 00 class 0x040300
    [ 0.147496] pci 0000:01:00.1: reg 0x10: [mem 0xfe9ec000-0xfe9effff 64bit]
    [ 0.147553] pci 0000:01:00.1: supports D1 D2
    [ 0.147609] pci 0000:00:01.0: PCI bridge to [bus 01]
    [ 0.147611] pci 0000:00:01.0: bridge window [io 0xc000-0xcfff]
    [ 0.147613] pci 0000:00:01.0: bridge window [mem 0xfe900000-0xfe9fffff]
    [ 0.147616] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
    [ 0.147657] pci 0000:00:1c.0: PCI bridge to [bus 02]
    [ 0.147720] pci 0000:03:00.0: [1106:3403] type 00 class 0x0c0010
    [ 0.147743] pci 0000:03:00.0: reg 0x10: [mem 0xfeaff800-0xfeafffff 64bit]
    [ 0.147754] pci 0000:03:00.0: reg 0x18: [io 0xd800-0xd8ff]
    [ 0.147850] pci 0000:03:00.0: supports D2
    [ 0.147851] pci 0000:03:00.0: PME# supported from D2 D3hot D3cold
    [ 0.156027] pci 0000:00:1c.1: PCI bridge to [bus 03]
    [ 0.156033] pci 0000:00:1c.1: bridge window [io 0xd000-0xdfff]
    [ 0.156038] pci 0000:00:1c.1: bridge window [mem 0xfea00000-0xfeafffff]
    [ 0.156122] pci 0000:04:01.0: [10b7:9055] type 00 class 0x020000
    [ 0.156143] pci 0000:04:01.0: reg 0x10: [io 0xec00-0xec7f]
    [ 0.156155] pci 0000:04:01.0: reg 0x14: [mem 0xfebffc00-0xfebffc7f]
    [ 0.156208] pci 0000:04:01.0: reg 0x30: [mem 0xfebc0000-0xfebdffff pref]
    [ 0.156235] pci 0000:04:01.0: supports D1 D2
    [ 0.156236] pci 0000:04:01.0: PME# supported from D1 D2 D3hot D3cold
    [ 0.156313] pci 0000:00:1e.0: PCI bridge to [bus 04] (subtractive decode)
    [ 0.156316] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff]
    [ 0.156319] pci 0000:00:1e.0: bridge window [mem 0xfeb00000-0xfebfffff]
    [ 0.156324] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
    [ 0.156325] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
    [ 0.156326] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
    [ 0.156328] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff window] (subtractive decode)
    [ 0.156329] pci 0000:00:1e.0: bridge window [mem 0xc0000000-0xdfffffff window] (subtractive decode)
    [ 0.156330] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xfed8ffff window] (subtractive decode)
    [ 0.157622] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 *10 11 12 14 15)
    [ 0.157672] ACPI: PCI Interrupt Link [LNKB] (IRQs *5)
    [ 0.157717] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 10 11 12 *14 15)
    [ 0.157765] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 *11 12 14 15)
    [ 0.157813] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 *4 6 7 10 11 12 14 15)
    [ 0.157861] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12 14 *15)
    [ 0.157912] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 6 7 10 11 12 14 15)
    [ 0.157960] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 6 *7 10 11 12 14 15)
    [ 0.158038] ACPI: Enabled 2 GPEs in block 00 to 3F
    [ 0.158327] SCSI subsystem initialized
    [ 0.158360] libata version 3.00 loaded.
    [ 0.158360] vgaarb: setting as boot device: PCI:0000:01:00.0
    [ 0.158360] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks= none
    [ 0.158360] vgaarb: loaded
    [ 0.158360] vgaarb: bridge control possible 0000:01:00.0
    [ 0.158360] ACPI: bus type USB registered
    [ 0.158360] usbcore: registered new interface driver usbfs
    [ 0.158360] usbcore: registered new interface driver hub
    [ 0.158360] usbcore: registered new device driver usb
    [ 0.158360] PCI: Using ACPI for IRQ routing
    [ 0.164079] PCI: pci_cache_line_size set to 64 bytes
    [ 0.164125] e820: reserve RAM buffer [mem 0x0009dc00-0x0009ffff]
    [ 0.164126] e820: reserve RAM buffer [mem 0xbff90000-0xbfffffff]
    [ 0.164247] NetLabel: Initializing
    [ 0.164248] NetLabel: domain hash size = 128
    [ 0.164248] NetLabel: protocols = UNLABELED CIPSOv4
    [ 0.164267] NetLabel: unlabeled traffic allowed by default
    [ 0.164286] HPET: 4 timers in total, 0 timers will be used for per-cpu timer
    [ 0.164286] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
    [ 0.164286] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
    [ 0.166068] clocksource: Switched to clocksource hpet
    [ 0.174891] VFS: Disk quotas dquot_6.6.0
    [ 0.174920] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [ 0.175060] AppArmor: AppArmor Filesystem Enabled
    [ 0.175131] pnp: PnP ACPI init
    [ 0.175245] system 00:00: [mem 0xfed14000-0xfed19fff] has been reserved
    [ 0.175247] system 00:00: [mem 0xfed90000-0xfed93fff] has been reserved
    [ 0.175251] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
    [ 0.175326] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
    [ 0.176075] pnp 00:02: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active)
    [ 0.176216] system 00:03: [io 0x0a00-0x0a0f] has been reserved
    [ 0.176218] system 00:03: [io 0x0a10-0x0a1f] has been reserved
    [ 0.176220] system 00:03: [io 0x0a20-0x0a2f] has been reserved
    [ 0.176221] system 00:03: [io 0x0a30-0x0a3f] has been reserved
    [ 0.176224] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
    [ 0.176360] system 00:04: [io 0x04d0-0x04d1] has been reserved
    [ 0.176362] system 00:04: [io 0x04c0-0x04cf] has been reserved
    [ 0.176363] system 00:04: [io 0x04d2-0x04ff] has been reserved
    [ 0.176365] system 00:04: [io 0x0800-0x087f] has been reserved
    [ 0.176366] system 00:04: [io 0x0480-0x04bf] has been reserved
    [ 0.176368] system 00:04: [mem 0xfed1c000-0xfed1ffff] has been reserved
    [ 0.176369] system 00:04: [mem 0xfed20000-0xfed3ffff] has been reserved
    [ 0.176371] system 00:04: [mem 0xfed40000-0xfed8ffff] has been reserved
    [ 0.176373] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
    [ 0.176462] system 00:05: [mem 0xffc00000-0xffefffff] has been reserved
    [ 0.176465] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
    [ 0.176559] system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved
    [ 0.176561] system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved
    [ 0.176563] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
    [ 0.176793] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
    [ 0.176795] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
    [ 0.176977] system 00:08: [mem 0x00000000-0x0009ffff] could not be reserved
    [ 0.176979] system 00:08: [mem 0x000c0000-0x000cffff] could not be reserved
    [ 0.176981] system 00:08: [mem 0x000e0000-0x000fffff] could not be reserved
    [ 0.176982] system 00:08: [mem 0x00100000-0xbfffffff] could not be reserved
    [ 0.176984] system 00:08: [mem 0xfed90000-0xffffffff] could not be reserved
    [ 0.176986] system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
    [ 0.177095] pnp: PnP ACPI: found 9 devices
    [ 0.183674] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
    [ 0.183694] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02] add_size 1000
    [ 0.183696] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
    [ 0.183698] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 02] add_size 200000 add_align 100000
    [ 0.183705] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
    [ 0.183716] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
    [ 0.183717] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
    [ 0.183719] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
    [ 0.183720] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
    [ 0.183722] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
    [ 0.183723] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
    [ 0.183725] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
    [ 0.183726] pci 0000:00:1c.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
    [ 0.183731] pci 0000:00:1c.0: BAR 14: assigned [mem 0xc0000000-0xc01fffff]
    [ 0.183735] pci 0000:00:1c.0: BAR 15: assigned [mem 0xc0200000-0xc03fffff 64bit pref]
    [ 0.183738] pci 0000:00:1c.1: BAR 15: assigned [mem 0xc0400000-0xc05fffff 64bit pref]
    [ 0.183740] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
    [ 0.183742] pci 0000:00:01.0: PCI bridge to [bus 01]
    [ 0.183744] pci 0000:00:01.0: bridge window [io 0xc000-0xcfff]
    [ 0.183747] pci 0000:00:01.0: bridge window [mem 0xfe900000-0xfe9fffff]
    [ 0.183749] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
    [ 0.183753] pci 0000:00:1c.0: PCI bridge to [bus 02]
    [ 0.183755] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
    [ 0.183758] pci 0000:00:1c.0: bridge window [mem 0xc0000000-0xc01fffff]
    [ 0.183761] pci 0000:00:1c.0: bridge window [mem 0xc0200000-0xc03fffff 64bit pref]
    [ 0.183766] pci 0000:00:1c.1: PCI bridge to [bus 03]
    [ 0.183768] pci 0000:00:1c.1: bridge window [io 0xd000-0xdfff]
    [ 0.183772] pci 0000:00:1c.1: bridge window [mem 0xfea00000-0xfeafffff]
    [ 0.183774] pci 0000:00:1c.1: bridge window [mem 0xc0400000-0xc05fffff 64bit pref]
    [ 0.183780] pci 0000:00:1e.0: PCI bridge to [bus 04]
    [ 0.183781] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff]
    [ 0.183785] pci 0000:00:1e.0: bridge window [mem 0xfeb00000-0xfebfffff]
    [ 0.183792] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
    [ 0.183794] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
    [ 0.183795] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
    [ 0.183796] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff window]
    [ 0.183797] pci_bus 0000:00: resource 8 [mem 0xc0000000-0xdfffffff window]
    [ 0.183799] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfed8ffff window]
    [ 0.183800] pci_bus 0000:01: resource 0 [io 0xc000-0xcfff]
    [ 0.183801] pci_bus 0000:01: resource 1 [mem 0xfe900000-0xfe9fffff]
    [ 0.183802] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
    [ 0.183804] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
    [ 0.183805] pci_bus 0000:02: resource 1 [mem 0xc0000000-0xc01fffff]
    [ 0.183806] pci_bus 0000:02: resource 2 [mem 0xc0200000-0xc03fffff 64bit pref]
    [ 0.183807] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
    [ 0.183809] pci_bus 0000:03: resource 1 [mem 0xfea00000-0xfeafffff]
    [ 0.183810] pci_bus 0000:03: resource 2 [mem 0xc0400000-0xc05fffff 64bit pref]
    [ 0.183811] pci_bus 0000:04: resource 0 [io 0xe000-0xefff]
    [ 0.183812] pci_bus 0000:04: resource 1 [mem 0xfeb00000-0xfebfffff]
    [ 0.183814] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7 window]
    [ 0.183815] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff window]
    [ 0.183816] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff window]
    [ 0.183817] pci_bus 0000:04: resource 7 [mem 0x000d0000-0x000dffff window]
    [ 0.183819] pci_bus 0000:04: resource 8 [mem 0xc0000000-0xdfffffff window]
    [ 0.183820] pci_bus 0000:04: resource 9 [mem 0xf0000000-0xfed8ffff window]
    [ 0.183854] NET: Registered protocol family 2
    [ 0.184065] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
    [ 0.184179] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
    [ 0.184364] TCP: Hash tables configured (established 32768 bind 32768)
    [ 0.184414] UDP hash table entries: 2048 (order: 4, 65536 bytes)
    [ 0.184441] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
    [ 0.184504] NET: Registered protocol family 1
    [ 0.185448] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
    [ 0.185456] PCI: CLS 32 bytes, default 64
    [ 0.185511] Unpacking initramfs...
    [ 0.828135] Freeing initrd memory: 40732K (ffff9db433062000 - ffff9db435829000)
    [ 0.828141] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
    [ 0.828143] software IO TLB [mem 0xbbf90000-0xbff90000] (64MB) mapped at [ffff9db4bbf90000-ffff9db4bff8ffff]
    [ 0.828375] Scanning for low memory corruption every 60 seconds
    [ 0.828775] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [ 0.828823] audit: initializing netlink subsys (disabled)
    [ 0.828851] audit: type=2000 audit(1496661483.828:1): initialized
    [ 0.829185] Initialise system trusted keyrings
    [ 0.829289] workingset: timestamp_bits=40 max_order=20 bucket_order=0
    [ 0.831316] zbud: loaded
    [ 0.831769] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [ 0.832028] fuse init (API version 7.25)
    [ 0.832183] Allocating IMA blacklist keyring.
    [ 0.833112] Key type asymmetric registered
    [ 0.833114] Asymmetric key parser 'x509' registered
    [ 0.833157] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [ 0.833183] io scheduler noop registered
    [ 0.833184] io scheduler deadline registered (default)
    [ 0.833193] io scheduler cfq registered
    [ 0.833469] pcieport 0000:00:1c.0: enabling device (0104 -> 0107)
    [ 0.833730] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
    [ 0.833735] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
    [ 0.833770] vesafb: mode is 1400x1050x32, linelength=5632, pages=0
    [ 0.833771] vesafb: scrolling: redraw
    [ 0.833772] vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
    [ 0.833788] vesafb: framebuffer at 0xd0000000, mapped to 0xffffaeabc0800000, using 5824k, total 5824k
    [ 0.833901] Console: switching to colour frame buffer device 175x65
    [ 0.833932] fb0: VESA VGA frame buffer device
    [ 0.833945] intel_idle: does not run on family 6 model 23
    [ 0.834051] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
    [ 0.834055] ACPI: Power Button [PWRB]
    [ 0.834098] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
    [ 0.834100] ACPI: Power Button [PWRF]
    [ 0.834192] Monitor-Mwait will be used to enter C-1 state
    [ 0.834196] Monitor-Mwait will be used to enter C-2 state
    [ 0.834199] tsc: Marking TSC unstable due to TSC halts in idle
    [ 0.834455] GHES: HEST is not enabled!
    [ 0.834531] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
    [ 0.836326] Linux agpgart interface v0.103
    [ 0.838025] loop: module loaded
    [ 0.838244] libphy: Fixed MDIO Bus: probed
    [ 0.838246] tun: Universal TUN/TAP device driver, 1.6
    [ 0.838246] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
    [ 0.838285] PPP generic driver version 2.4.2
    [ 0.838331] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [ 0.838334] ehci-pci: EHCI PCI platform driver
    [ 0.838472] ehci-pci 0000:00:1a.7: EHCI Host Controller
    [ 0.838478] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
    [ 0.838489] ehci-pci 0000:00:1a.7: debug port 1
    [ 0.842387] ehci-pci 0000:00:1a.7: cache line size of 32 is not supported
    [ 0.842401] ehci-pci 0000:00:1a.7: irq 18, io mem 0xfe8ffc00
    [ 0.856028] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
    [ 0.856119] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [ 0.856122] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 0.856125] usb usb1: Product: EHCI Host Controller
    [ 0.856129] usb usb1: Manufacturer: Linux 4.8.0-53-generic ehci_hcd
    [ 0.856131] usb usb1: SerialNumber: 0000:00:1a.7
    [ 0.856295] hub 1-0:1.0: USB hub found
    [ 0.856304] hub 1-0:1.0: 6 ports detected
    [ 0.856637] ehci-pci 0000:00:1d.7: EHCI Host Controller
    [ 0.856641] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
    [ 0.856651] ehci-pci 0000:00:1d.7: debug port 1
    [ 0.860545] ehci-pci 0000:00:1d.7: cache line size of 32 is not supported
    [ 0.860554] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfe8ff800
    [ 0.876026] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
    [ 0.876103] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
    [ 0.876107] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 0.876110] usb usb2: Product: EHCI Host Controller
    [ 0.876113] usb usb2: Manufacturer: Linux 4.8.0-53-generic ehci_hcd
    [ 0.876116] usb usb2: SerialNumber: 0000:00:1d.7
    [ 0.876285] hub 2-0:1.0: USB hub found
    [ 0.876290] hub 2-0:1.0: 6 ports detected
    [ 0.876543] ehci-platform: EHCI generic platform driver
    [ 0.876556] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [ 0.876559] ohci-pci: OHCI PCI platform driver
    [ 0.876572] ohci-platform: OHCI generic platform driver
    [ 0.876579] uhci_hcd: USB Universal Host Controller Interface driver
    [ 0.876652] uhci_hcd 0000:00:1a.0: UHCI Host Controller
    [ 0.876657] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
    [ 0.876662] uhci_hcd 0000:00:1a.0: detected 2 ports
    [ 0.876684] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000bc00
    [ 0.876724] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
    [ 0.876726] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 0.876727] usb usb3: Product: UHCI Host Controller
    [ 0.876728] usb usb3: Manufacturer: Linux 4.8.0-53-generic uhci_hcd
    [ 0.876729] usb usb3: SerialNumber: 0000:00:1a.0
    [ 0.876836] hub 3-0:1.0: USB hub found
    [ 0.876844] hub 3-0:1.0: 2 ports detected
    [ 0.877023] uhci_hcd 0000:00:1a.1: UHCI Host Controller
    [ 0.877027] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
    [ 0.877032] uhci_hcd 0000:00:1a.1: detected 2 ports
    [ 0.877053] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000b880
    [ 0.877092] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
    [ 0.877094] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 0.877095] usb usb4: Product: UHCI Host Controller
    [ 0.877096] usb usb4: Manufacturer: Linux 4.8.0-53-generic uhci_hcd
    [ 0.877097] usb usb4: SerialNumber: 0000:00:1a.1
    [ 0.877206] hub 4-0:1.0: USB hub found
    [ 0.877211] hub 4-0:1.0: 2 ports detected
    [ 0.877390] uhci_hcd 0000:00:1a.2: UHCI Host Controller
    [ 0.877396] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
    [ 0.877401] uhci_hcd 0000:00:1a.2: detected 2 ports
    [ 0.877423] uhci_hcd 0000:00:1a.2: irq 19, io base 0x0000b800
    [ 0.877462] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
    [ 0.877464] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 0.877465] usb usb5: Product: UHCI Host Controller
    [ 0.877466] usb usb5: Manufacturer: Linux 4.8.0-53-generic uhci_hcd
    [ 0.877467] usb usb5: SerialNumber: 0000:00:1a.2
    [ 0.877578] hub 5-0:1.0: USB hub found
    [ 0.877583] hub 5-0:1.0: 2 ports detected
    [ 0.877755] uhci_hcd 0000:00:1d.0: UHCI Host Controller
    [ 0.877760] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
    [ 0.877765] uhci_hcd 0000:00:1d.0: detected 2 ports
    [ 0.877781] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000b480
    [ 0.877820] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
    [ 0.877821] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 0.877823] usb usb6: Product: UHCI Host Controller
    [ 0.877824] usb usb6: Manufacturer: Linux 4.8.0-53-generic uhci_hcd
    [ 0.877825] usb usb6: SerialNumber: 0000:00:1d.0
    [ 0.877928] hub 6-0:1.0: USB hub found
    [ 0.877933] hub 6-0:1.0: 2 ports detected
    [ 0.878106] uhci_hcd 0000:00:1d.1: UHCI Host Controller
    [ 0.878110] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
    [ 0.878116] uhci_hcd 0000:00:1d.1: detected 2 ports
    [ 0.878131] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000b400
    [ 0.878169] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
    [ 0.878171] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 0.878172] usb usb7: Product: UHCI Host Controller
    [ 0.878174] usb usb7: Manufacturer: Linux 4.8.0-53-generic uhci_hcd
    [ 0.878175] usb usb7: SerialNumber: 0000:00:1d.1
    [ 0.878279] hub 7-0:1.0: USB hub found
    [ 0.878284] hub 7-0:1.0: 2 ports detected
    [ 0.878450] uhci_hcd 0000:00:1d.2: UHCI Host Controller
    [ 0.878454] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
    [ 0.878461] uhci_hcd 0000:00:1d.2: detected 2 ports
    [ 0.878477] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000b080
    [ 0.878517] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
    [ 0.878518] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 0.878520] usb usb8: Product: UHCI Host Controller
    [ 0.878521] usb usb8: Manufacturer: Linux 4.8.0-53-generic uhci_hcd
    [ 0.878522] usb usb8: SerialNumber: 0000:00:1d.2
    [ 0.878628] hub 8-0:1.0: USB hub found
    [ 0.878633] hub 8-0:1.0: 2 ports detected
    [ 0.878805] i8042: PNP: PS/2 Controller [PNP0f03:PS2M] at 0x60,0x64 irq 12
    [ 0.878806] i8042: PNP: PS/2 controller doesn't have KBD irq; using default 1
    [ 0.879188] serio: i8042 KBD port at 0x60,0x64 irq 1
    [ 0.879196] serio: i8042 AUX port at 0x60,0x64 irq 12
    [ 0.879487] mousedev: PS/2 mouse device common for all mice
    [ 0.879647] rtc_cmos 00:01: RTC can wake from S4
    [ 0.879764] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
    [ 0.879784] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
    [ 0.879791] i2c /dev entries driver
    [ 0.879854] device-mapper: uevent: version 1.0.3
    [ 0.879930] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
    [ 0.879953] ledtrig-cpu: registered to indicate activity on CPUs
    [ 0.880278] NET: Registered protocol family 10
    [ 0.880517] NET: Registered protocol family 17
    [ 0.880526] Key type dns_resolver registered
    [ 0.880698] microcode: sig=0x1067a, pf=0x1, revision=0xa07
    [ 0.880749] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
    [ 0.880895] registered taskstats version 1
    [ 0.880900] Loading compiled-in X.509 certificates
    [ 0.883739] Loaded X.509 cert 'Build time autogenerated kernel key: 890c85f7e22f136898a4920c18a4a187fdae3343'
    [ 0.883762] zswap: loaded using pool lzo/zbud
    [ 0.895884] Key type big_key registered
    [ 0.897467] Key type trusted registered
    [ 0.899047] Key type encrypted registered
    [ 0.899050] AppArmor: AppArmor sha1 policy hashing enabled
    [ 0.899053] ima: No TPM chip found, activating TPM-bypass!
    [ 0.899075] evm: HMAC attrs: 0x1
    [ 0.899356] Magic number: 5:810:326
    [ 0.899502] rtc_cmos 00:01: setting system clock to 2017-06-05 11:18:04 UTC (1496661484)
    [ 0.899906] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
    [ 0.899906] EDD information not available.
    [ 0.899951] PM: Hibernation image not present or could not be loaded.
    [ 0.901457] Freeing unused kernel memory: 1548K (ffffffff9996a000 - ffffffff99aed000)
    [ 0.901458] Write protecting the kernel read-only data: 14336k
    [ 0.902212] Freeing unused kernel memory: 1396K (ffff9db535ca3000 - ffff9db535e00000)
    [ 0.902921] Freeing unused kernel memory: 260K (ffff9db5361bf000 - ffff9db536200000)
    [ 0.910842] x86/mm: Checked W+X mappings: passed, no W+X pages found.
    [ 0.922756] random: systemd-udevd: uninitialized urandom read (16 bytes read)
    [ 0.922837] random: systemd-udevd: uninitialized urandom read (16 bytes read)
    [ 0.922849] random: systemd-udevd: uninitialized urandom read (16 bytes read)
    [ 0.922864] random: systemd-udevd: uninitialized urandom read (16 bytes read)
    [ 0.924955] random: udevadm: uninitialized urandom read (16 bytes read)
    [ 0.924992] random: udevadm: uninitialized urandom read (16 bytes read)
    [ 0.926127] random: udevadm: uninitialized urandom read (16 bytes read)
    [ 0.926144] random: udevadm: uninitialized urandom read (16 bytes read)
    [ 0.926195] random: udevadm: uninitialized urandom read (16 bytes read)
    [ 0.926541] random: udevadm: uninitialized urandom read (16 bytes read)
    [ 0.975006] FUJITSU Extended Socket Network Device Driver - version 1.1 - Copyright (c) 2015 FUJITSU LIMITED
    [ 0.975705] [drm] Initialized drm 1.1.0 20060810
    [ 0.988250] wmi: Mapper loaded
    [ 0.994016] 3c59x: Donald Becker and others.
    [ 0.994023] 0000:04:01.0: 3Com PCI 3c905B Cyclone 100baseTx at ffffaeabc073ac00.
    [ 1.020898] [drm] radeon kernel modesetting enabled.
    [ 1.021040] ahci 0000:00:1f.2: version 3.0
    [ 1.021134] ahci 0000:00:1f.2: controller can't do SNTF, turning off CAP_SNTF
    [ 1.021224] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
    [ 1.021260] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl RAID mode
    [ 1.021262] ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pio slum part ccc ems sxs
    [ 1.023702] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
    [ 1.023703] AMD IOMMUv2 functionality not available on this system
    [ 1.028286] CRAT table not found
    [ 1.028288] Finished initializing topology ret=0
    [ 1.028302] kfd kfd: Initialized module
    [ 1.028520] checking generic (d0000000 5b0000) vs hw (d0000000 10000000)
    [ 1.028521] fb: switching to radeondrmfb from VESA VGA
    [ 1.028693] Console: switching to colour dummy device 80x25
    [ 1.029186] [drm] initializing kernel modesetting (RV710 0x1002:0x954F 0x1462:0x1618 0x00).
    [ 1.029199] [drm] register mmio base: 0xFE9F0000
    [ 1.029200] [drm] register mmio size: 65536
    [ 1.029275] ATOM BIOS: 113
    [ 1.029312] radeon 0000:01:00.0: VRAM: 512M 0x0000000000000000 - 0x000000001FFFFFFF (512M used)
    [ 1.029314] radeon 0000:01:00.0: GTT: 1024M 0x0000000020000000 - 0x000000005FFFFFFF
    [ 1.029315] [drm] Detected VRAM RAM=512M, BAR=256M
    [ 1.029316] [drm] RAM width 64bits DDR
    [ 1.029376] [TTM] Zone kernel: Available graphics memory: 2022730 kiB
    [ 1.029376] [TTM] Initializing pool allocator
    [ 1.029382] [TTM] Initializing DMA pool allocator
    [ 1.029404] [drm] radeon: 512M of VRAM memory ready
    [ 1.029404] [drm] radeon: 1024M of GTT memory ready.
    [ 1.029558] [drm] Loading RV710 Microcode
    [ 1.029646] [drm] Internal thermal controller with fan control
    [ 1.031263] [drm] radeon: dpm initialized
    [ 1.031392] [drm] GART: num cpu pages 262144, num gpu pages 262144
    [ 1.034253] [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
    [ 1.043428] [drm] PCIE GART of 1024M enabled (table at 0x000000000014C000).
    [ 1.043482] radeon 0000:01:00.0: WB enabled
    [ 1.043484] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000020000c00 and cpu addr 0xffff9db5308eec00
    [ 1.043486] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000020000c0c and cpu addr 0xffff9db5308eec0c
    [ 1.043796] radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x000000000005c598 and cpu addr 0xffffaeabc101c598
    [ 1.043798] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [ 1.043799] [drm] Driver supports precise vblank timestamp query.
    [ 1.043801] radeon 0000:01:00.0: radeon: MSI limited to 32-bit
    [ 1.043843] radeon 0000:01:00.0: radeon: using MSI.
    [ 1.043870] [drm] radeon: irq initialized.
    [ 1.086748] scsi host0: ahci
    [ 1.090395] [drm] ring test on 0 succeeded in 1 usecs
    [ 1.090402] [drm] ring test on 3 succeeded in 2 usecs
    [ 1.091949] scsi host1: ahci
    [ 1.094144] 3c59x 0000:04:01.0 enp4s1: renamed from eth0
    [ 1.094353] scsi host2: ahci
    [ 1.094546] scsi host3: ahci
    [ 1.094724] scsi host4: ahci
    [ 1.094899] scsi host5: ahci
    [ 1.094960] ata1: SATA max UDMA/133 abar m2048@0xfe8ff000 port 0xfe8ff100 irq 27
    [ 1.094962] ata2: SATA max UDMA/133 abar m2048@0xfe8ff000 port 0xfe8ff180 irq 27
    [ 1.094963] ata3: SATA max UDMA/133 abar m2048@0xfe8ff000 port 0xfe8ff200 irq 27
    [ 1.094965] ata4: SATA max UDMA/133 abar m2048@0xfe8ff000 port 0xfe8ff280 irq 27
    [ 1.094967] ata5: SATA max UDMA/133 abar m2048@0xfe8ff000 port 0xfe8ff300 irq 27
    [ 1.094968] ata6: SATA max UDMA/133 abar m2048@0xfe8ff000 port 0xfe8ff380 irq 27
    [ 1.095558] firewire_ohci 0000:03:00.0: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x11
    [ 1.188015] usb 1-3: new high-speed USB device number 2 using ehci-pci
    [ 1.274988] [drm] ring test on 5 succeeded in 1 usecs
    [ 1.274991] [drm] UVD initialized successfully.
    [ 1.275413] [drm] ib test on ring 0 succeeded in 0 usecs
    [ 1.275430] [drm] ib test on ring 3 succeeded in 0 usecs
    [ 1.344017] usb 8-2: new low-speed USB device number 2 using uhci_hcd
    [ 1.348315] usb 1-3: New USB device found, idVendor=154b, idProduct=00d2
    [ 1.348317] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [ 1.348318] usb 1-3: Product: USB 3.0 FD
    [ 1.348319] usb 1-3: Manufacturer: PNY
    [ 1.348320] usb 1-3: SerialNumber: 070B730A8BB52B69
    [ 1.351797] usb-storage 1-3:1.0: USB Mass Storage device detected
    [ 1.352088] scsi host6: usb-storage 1-3:1.0
    [ 1.352166] usbcore: registered new interface driver usb-storage
    [ 1.353530] usbcore: registered new interface driver uas
    [ 1.410944] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
    [ 1.412569] ata1.00: ATAPI: ATAPI DVD A DH16AASH, SA15, max UDMA/100
    [ 1.413308] ata1.00: configured for UDMA/100
    [ 1.416393] scsi 0:0:0:0: CD-ROM ATAPI DVD A DH16AASH SA15 PQ: 0 ANSI: 5
    [ 1.447929] sr 0:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
    [ 1.447932] cdrom: Uniform CD-ROM driver Revision: 3.20
    [ 1.448212] sr 0:0:0:0: Attached scsi CD-ROM sr0
    [ 1.448334] sr 0:0:0:0: Attached scsi generic sg0 type 5
    [ 1.532047] usb 8-2: New USB device found, idVendor=046d, idProduct=c05a
    [ 1.532051] usb 8-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [ 1.532054] usb 8-2: Product: USB Optical Mouse
    [ 1.532057] usb 8-2: Manufacturer: Logitech
    [ 1.538466] hidraw: raw HID events driver (C) Jiri Kosina
    [ 1.553329] usbcore: registered new interface driver usbhid
    [ 1.553330] usbhid: USB HID core driver
    [ 1.555083] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1d.2/usb8/8-2/8-2:1.0/0003:046D:C05A.0001/input/input5
    [ 1.555203] hid-generic 0003:046D:C05A.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1d.2-2/input0
    [ 1.628177] firewire_core 0000:03:00.0: created device fw0: GUID 000000251197ae1f, S400
    [ 1.636032] random: fast init done
    [ 1.762513] ata2: SATA link down (SStatus 0 SControl 300)
    [ 1.852042] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x285c14bd6d8, max_idle_ns: 440795340632 ns
    [ 1.948055] [drm] ib test on ring 5 succeeded
    [ 1.948777] [drm] Radeon Display Connectors
    [ 1.948778] [drm] Connector 0:
    [ 1.948778] [drm] VGA-1
    [ 1.948780] [drm] DDC: 0x7e40 0x7e40 0x7e44 0x7e44 0x7e48 0x7e48 0x7e4c 0x7e4c
    [ 1.948780] [drm] Encoders:
    [ 1.948781] [drm] CRT2: INTERNAL_KLDSCP_DAC2
    [ 1.948782] [drm] Connector 1:
    [ 1.948782] [drm] HDMI-A-1
    [ 1.948783] [drm] HPD1
    [ 1.948784] [drm] DDC: 0x7e50 0x7e50 0x7e54 0x7e54 0x7e58 0x7e58 0x7e5c 0x7e5c
    [ 1.948784] [drm] Encoders:
    [ 1.948785] [drm] DFP1: INTERNAL_UNIPHY
    [ 1.948785] [drm] Connector 2:
    [ 1.948786] [drm] DVI-I-1
    [ 1.948786] [drm] HPD4
    [ 1.948787] [drm] DDC: 0x7f10 0x7f10 0x7f14 0x7f14 0x7f18 0x7f18 0x7f1c 0x7f1c
    [ 1.948788] [drm] Encoders:
    [ 1.948788] [drm] CRT1: INTERNAL_KLDSCP_DAC1
    [ 1.948789] [drm] DFP2: INTERNAL_UNIPHY2
    [ 2.045129] [drm] fb mappable at 0xD034D000
    [ 2.045130] [drm] vram apper at 0xD0000000
    [ 2.045131] [drm] size 8294400
    [ 2.045131] [drm] fb depth is 24
    [ 2.045132] [drm] pitch is 7680
    [ 2.045193] fbcon: radeondrmfb (fb0) is primary device
    [ 2.045279] Console: switching to colour frame buffer device 240x67
    [ 2.045324] radeon 0000:01:00.0: fb0: radeondrmfb frame buffer device
    [ 2.068138] [drm] Initialized radeon 2.46.0 20080528 for 0000:01:00.0 on minor 0
    [ 2.074359] ata3: SATA link down (SStatus 0 SControl 300)
    [ 2.104031] usb 5-1: new low-speed USB device number 2 using uhci_hcd
    [ 2.386480] ata4: SATA link down (SStatus 0 SControl 300)
    [ 2.506063] usb 5-1: New USB device found, idVendor=0c16, idProduct=0002
    [ 2.506067] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [ 2.506070] usb 5-1: Product: Gyration RF Technology Receiver
    [ 2.506073] usb 5-1: Manufacturer: Gyration
    [ 2.698512] ata5: SATA link down (SStatus 0 SControl 300)
    [ 3.010495] ata6: SATA link down (SStatus 0 SControl 300)
    [ 3.163358] scsi 6:0:0:0: Direct-Access PNY USB 3.0 FD PMAP PQ: 0 ANSI: 6
    [ 3.163895] sd 6:0:0:0: Attached scsi generic sg1 type 0
    [ 3.164977] sd 6:0:0:0: [sda] 121012224 512-byte logical blocks: (62.0 GB/57.7 GiB)
    [ 3.165586] sd 6:0:0:0: [sda] Write Protect is off
    [ 3.165591] sd 6:0:0:0: [sda] Mode Sense: 23 00 00 00
    [ 3.166214] sd 6:0:0:0: [sda] No Caching mode page found
    [ 3.166222] sd 6:0:0:0: [sda] Assuming drive cache: write through
    [ 3.176712] sda: sda1 sda2 < sda5 >
    [ 3.180468] sd 6:0:0:0: [sda] Attached SCSI removable disk
    [ 4.060059] floppy0: no floppy controllers found
    [ 7.093918] EXT4-fs (sda1): mounted filesystem with ordered data mode.
    Opts: (null)
    [ 7.617678] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
    [ 7.617947] systemd[1]: Detected architecture x86-64.
    [ 7.619783] systemd[1]: Set hostname to <jamesneondevstable>.
    [ 8.102785] systemd[1]: Reached target User and Group Name Lookups.
    [ 8.102980] systemd[1]: Listening on Journal Socket.
    [ 8.103070] systemd[1]: Started Trigger resolvconf update for networkd DNS.
    [ 8.103192] systemd[1]: Listening on Journal Audit Socket.
    [ 8.103208] systemd[1]: Reached target Remote File Systems (Pre).
    [ 8.103259] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [ 8.103308] systemd[1]: Listening on Device-mapper event daemon FIFOs.
    [ 8.390417] lp: driver loaded but no devices found
    [ 8.407776] ppdev: user-space parallel port driver
    [ 8.854508] EXT4-fs (sda1): re-mounted.
    Opts: errors=remount-ro
    [ 8.913303] systemd-journald[318]: Received request to flush runtime journal from PID 1
    [ 9.313125] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
    [ 9.341684] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000800-0x000000000000084F (\PMRG) (20160422/utaddress-255)
    [ 9.341692] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
    [ 9.341726] lpc_ich: Resource conflict(s) found affecting gpio_ich
    [ 9.623671] input: Gyration Gyration RF Technology Receiver as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.0/0003:0C16:0002.0002/input/input6
    [ 9.638609] random: crng init done
    [ 9.681228] gyration 0003:0C16:0002.0002: input,hiddev0,hidraw1: USB HID v1.10 Keyboard [Gyration Gyration RF Technology Receiver] on usb-0000:00:1a.2-1/input0
    [ 9.681836] input: Gyration Gyration RF Technology Receiver as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.1/0003:0C16:0002.0003/input/input7
    [ 9.741268] gyration 0003:0C16:0002.0003: input,hiddev0,hidraw2: USB HID v1.20 Mouse [Gyration Gyration RF Technology Receiver] on usb-0000:00:1a.2-1/input1
    [ 9.825864] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
    [ 9.855782] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8
    [ 9.966228] intel_powerclamp: No package C-state available
    [ 10.252518] gpio_ich: GPIO from 451 to 511 on gpio_ich
    [ 10.528568] audit: type=1400 audit(1496661494.128:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=673 comm="apparmor_parser"
    [ 10.528577] audit: type=1400 audit(1496661494.128:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=673 comm="apparmor_parser"
    [ 10.624018] audit: type=1400 audit(1496661494.220:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=671 comm="apparmor_parser"
    [ 10.624028] audit: type=1400 audit(1496661494.224:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=671 comm="apparmor_parser"
    [ 10.624033] audit: type=1400 audit(1496661494.224:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=671 comm="apparmor_parser"
    [ 10.624038] audit: type=1400 audit(1496661494.224:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=671 comm="apparmor_parser"
    [ 10.638908] audit: type=1400 audit(1496661494.236:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=674 comm="apparmor_parser"
    [ 10.669534] audit: type=1400 audit(1496661494.268:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ippusbxd" pid=676 comm="apparmor_parser"
    [ 10.716458] audit: type=1400 audit(1496661494.316:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/tcpdump" pid=678 comm="apparmor_parser"
    [ 10.719155] audit: type=1400 audit(1496661494.316:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=675 comm="apparmor_parser"
    [ 11.123523] Adding 4191228k swap on /dev/sda5.
    Priority:-1 extents:1 across:4191228k FS
    [ 12.252079] floppy0: no floppy controllers found
    [ 12.252094] work still pending
    [ 12.856061] snd_hda_intel 0000:00:1b.0: azx_get_response timeout, switching to polling mode: last cmd=0x300f0000
    [ 13.864058] snd_hda_intel 0000:00:1b.0: No response from codec, disabling MSI: last cmd=0x300f0000
    [ 14.149628] IPv6: ADDRCONF(NETDEV_UP): enp4s1: link is not ready
    [ 14.150843] enp4s1: setting full-duplex.
    [ 14.872052] snd_hda_intel 0000:00:1b.0: Codec #3 probe error; disabling it...
    [ 14.903882] snd_hda_codec_realtek hdaudioC0D0: ALC888: SKU not ready 0x411111f0
    [ 14.905551] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC888: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
    [ 14.905556] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
    [ 14.905558] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
    [ 14.905559] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
    [ 14.905560] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x1e
    [ 14.905562] snd_hda_codec_realtek hdaudioC0D0: inputs:
    [ 14.905564] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
    [ 14.905565] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
    [ 14.905567] snd_hda_codec_realtek hdaudioC0D0: Line=0x1c
    [ 14.921566] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
    [ 14.921654] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
    [ 14.921724] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
    [ 14.921795] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
    [ 14.921867] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
    [ 14.921942] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
    [ 14.922015] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
    [ 14.922092] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
    [ 415.768222] SGI XFS with ACLs, security attributes, realtime, no debug enabled
    [ 415.810877] JFS: nTxBlock = 8192, nTxLock = 65536
    [ 415.859245] ntfs: driver 2.1.32 [Flags: R/O MODULE].
    [ 415.953206] QNX4 filesystem 0.2.3 registered.
    [ 416.064021] raid6: sse2x1 gen() 4475 MB/s
    [ 416.132016] raid6: sse2x1 xor() 4711 MB/s
    [ 416.200014] raid6: sse2x2 gen() 5137 MB/s
    [ 416.268030] raid6: sse2x2 xor() 5727 MB/s
    [ 416.336015] raid6: sse2x4 gen() 8091 MB/s
    [ 416.404012] raid6: sse2x4 xor() 6326 MB/s
    [ 416.404014] raid6: using algorithm sse2x4 gen() 8091 MB/s
    [ 416.404014] raid6: ...
    xor() 6326 MB/s, rmw enabled
    [ 416.404016] raid6: using ssse3x2 recovery algorithm
    [ 417.851152] xor: measuring software checksum speed
    [ 417.888011] prefetch64-sse: 11542.000 MB/sec
    [ 417.928017] generic_sse: 10193.000 MB/sec
    [ 417.928019] xor: using function: prefetch64-sse (11542.000 MB/sec)
    [ 418.120194] Btrfs loaded, crc32c=crc32c-generic
    [ 0.076000] ...
    version: 2
    [ 0.076000] ...
    node #0, CPUs: #1
    Opts: (null)
    [ 418/quote].120194] Btrfs loaded, crc32c=crc32c-generic
    sorry about taking up so much server space, maybe somebody can get this to the appropriate developer.
    woodsmoke
      Were you trying to use RAID6 ? RAID 5&6 are not yet ready for Btrfs.
        ummmm no. lol
        woodisasimpleguysmoke
          You were using Btrfs, weren't you?
            lol
            I'm just
            woodahardwarekindaguysmoke
