Mint parts company with KDE
    Right-click on the little triangle in the system tray, the one that shows hidden icons.
    Configure System Tray > Entries, Updates > Hidden.
    I saw that solution from search. That didn't work.
    Boot Info Script
      How could it not? In the Updates section of Muon turn off automatic security updates, set to notify only, and check for updates every two weeks. I also set for the LTS release only, since I am running 20.04.
      THEN, hide the updates icon in the system tray so you won't get notified of any pending updates.
      Every so often open Konsole and do a "sudo apt update" to check what is pending.
        Well that's funny. I did that ages ago and never saw an update notification since.
          Here is muon with updates disabled. Still on reboot Discovery shows updates available.
          Boot Info Script
            I was able to rid myself of DiscoverNotifier by following the following thread:
            https://www.reddit.com/r/kde/comment...ifier/fbb9hry/
            and rename DiscoverNotifier to BACKUP.DiscoverNotifier, but that only gets rid of the notifier. Something else is triggering Discover;but what?
            /usr/lib/x86_64-linux-gnu/plasma-discover/libDiscoverNotifiers.so
            /usr/lib/x86_64-linux-gnu/plasma-discover/libDiscoverCommon.so
            /usr/lib/x86_64-linux-gnu/libexec/BACKUP.DiscoverNotifier
            /usr/lib/x86_64-linux-gnu/qt5/plugins/discover-notifier/DiscoverPackageKitNotifier.so
            I couldn't find any autostart program that triggers Discover.
            Boot Info Script
              How to stop "updates available" on task manager. I tried several suggestions: muon > automotic updates unchecked, "20auto-upgrades" set to "1". All to no avail. "20auto-upgrades" resets it back to "0"
              Your choice, of course, but why would you not want to know about available updates?
              Intel i7 11th Gen 16GB 1TB
                I use terminal to update and upgrade updates. Its just annoying that Discover is there and I can't turn it off.
                Boot Info Script
                  Have you read posts #2 and #3 in https://www.kubuntuforums.net/showth...-updates/page2
                    Thanks, but yes #2 I did. No effect, #3 mine is missings the "Updates". Most likely because I renamed "DiscoverNotifier", as above. I will try #3 after I change "DiscoverNotifier" back to correct name.
                    Boot Info Script
