Dual booting *ubuntus, multi-disk, 1 or more ESPs
    -- advertisement -- ;-)
    My how-to ain't half bad:
    Dual booting two (or more) *ubuntu operating systems in UEFI mode -- 1 drive or 2 drives, 1 ESP or 2 ESPs
    https://www.kubuntuforums.net/forum/...-esp-or-2-esps
    It addresses topics I see people asking about around here regarding UEFI and ESPs.
    It is written in a tutorial mode, which should help anyone doing this stuff for the first or second time or for review.
    I just read through it myself and caught a couple typos I corrected.
    Of course, it can't be purely tutorial, it would be three to five times as long (it's already 19 pages, 8.5x11" 1/2-inch margins, single space 12 pt type).
    But it's pretty clear for DIY.
    Note: It does not deal with Windows. It deals only with Ubuntu-based OSs (but I think you can usually, easily extend it to other Linux OSs).
    You can certainly use the principles to help you set up dual booting with Windows OSs. There's plenty of sources for help on this.
    My how-to should equip you with the know-how when it comes to dealing with your UEFI booting.
    Table of Contents
    SECTION 1 Dual booting two OSs on the SSD with one ESP
    SECTION 2 Using two ESPs on one disk drive
    SECTION 3 Labels and NVRAM boot variables
    -- Changing labels of NVRAM boot variables in the efibootmgr list
    -- Creating NVRAM boot variables (to appear in UEFI-BIOS boot menus)
    -- sudo efibootmgr -c -d /dev/sdx -p n -L NewLabel -l \\EFI\\<directory_current>\\<boot_loader>
    SECTION 4 Creating separate NVRAM variables for two *ubuntu OSs
    SECTION 5 Installing an SSD M.2 as a second drive -- using the disk name nvme_n_p_
    SECTION 6 Install Kubuntu 24.04 to the M.2 as a third OS (so, 2 drives, 3 OSs, 1 ESP)
    SECTION 7 Three OSs on two drives using an ESP on each drive
    SECTION 8 Concluding comment, and surviving updates
    APPENDIX -- Table of Contents
    1 -- Summary of key commands and some facts
    2 -- ESP -- how big?
    3 -- Partitioning with GParted
    4 -- Getting the new Kubuntu 24.04
    5 -- Making the live USB Kubuntu installer
    6 -- Experimenting -- accessing the ESP
    7 -- rEFInd
    8 -- Make a rEFInd flash drive
    9 -- How to re-enable os-prober so you can use the GRUB command update-grub
    10 -- The /boot/efi/EFI/ubuntu directory: An IMPORTANT fact about it
    11 -- Installing OSs to a system with two or more ESPs -- Calamares installer and another trick.
    12 -- How to boot into an operating system if it is no longer set as 'first in boot order'
    This how-to contains a listing of all my UEFI how-to's:
    UEFI, GPT, ESP, GRUB2-EFI, dual-booting, fixing things
    https://www.kubuntuforums.net/forum/...-fixing-things
    A decent, quick read, for those who sort of know the basics is:
    UEFI Simplified, a quicker version
    https://www.kubuntuforums.net/showth...l=1#post379977
