Because SteveRiley has ventured over to Arch Linux, I decided to try it out in an Oracle VirtualBox VM. I'm writing this post, from Firefox, inside my newly installed (as of about 10 minutes ago) Arch Linux. It only took me about six attempts, completely riding all VM files each time, BECAUSE I DIDN'T READ THE LAST INSTRUCTION!!! Long story short, I was rebooting back into the attached .iso and NOT the newly installed system. Doh!
I'm not moving away from Kubuntu. As long as it is supported, I'll be using it. But it is 'sound practice' to not keep ones eggs in just one basket. Knowing how to use (install and maintain) other Linux distributions ensures your flexability and increases your options, if and when you need to exercise them.
With Plasma installed, there is little difference 'visually' between Kubuntu and Arch. And of course, that's likely true for any distribution using Plasma.
