Living on the Edge with KDE Project Neon
    Since Kubuntu 14.10 beta was released, the Plasma5 option iso was relesed. So I decided to install that instead of the neon5 which was based on 14.04. Since doing this change, there have hardly been any updates to plasma5. Also, the performace seems to have gone backwards. The login screen now requires me to click on the password window to login. Also, the network manager now requires me to connect each time I boot. There are no options for akonadi on the System Settings which is a definite limitation.
    Currently this and other issues such as, widgets with limited number and control, no HP icon, VLC menu selection not working, no volume control icon, make plasma5 more limited than neon5.
    I am surprised that there is this difference and I hope we see some improvement in the near future.
      In the mean time we've received a few new system icons, I like the clipboard one.
      The KOrganiser one fails with an error report that certain Akonadi services are not running.
      I have just copied korganizer files from my 14.10 system onto my 14.10 plasma5 directory ~/.kde/share/apps/korganizer/ and I was able to launch KOrganizer with the Calendar entries. The approach I use for my Calendar is not using Akonadi directories.
        For some time now since installing plasma5, I had never seen access to the ppa added by sudo apt-add-repository ppa:kubuntu-ppa/next. Just to make sure that I had not missed it, I copied all the sites accessed doing sudo apt-get update and pasted them into Kate. I did a search for "next" and nothing was found.
        I cannot see how this can happen and would like to know how I can get accessed to this ppa which is in the muon package manager.
          If you installed kubuntu via the special plasma 5 iso, you already have the kubuntu-next ppa enabled. What do you mean by accessing it, specifically?
          If you open muon package manager and look at the "origin' tab on the left, you will see "Kubuntu Next" listed. Clicking on that entry will filter Muon to show only those packages from that ppa. If you don't use Muon, look in /etc/apt/sources.list.d, and peek at the file ubuntu-defaults file you will see the ppa there (I do not know why it is listed as ubuntu-defaults there, but it is). All your ppa's will have a file in this folder, what you see running apt-get update does not show the full repo information , just the base url for them (such as ppa.launchpad.net)
          Plasma 5 is not updated that often, as KDE have not released that many official updates to it so far, and as Plasma 5 is basically the base desktop and not the applications so much, there have been few of these official updates for it at this point, at least not since the time your iso was created.
          However, those using Neon daily builds would get stuff more regularly
          Yes, kmix and ark are missing (still, I think) but can be installed, i also think that there was a bug where kmix was not starting at login automatically, but I myself have not experienced that one.
          Last edited by claydoh; Sep 03, 2014, 05:15 AM. Reason: don't post with zero sleep, claydoh
            Thanks for the useful tips. I did find next where you said it was. I also tried another approach by using "plasma" in the search for muon. I found many plasma applications to install. I must confess that I should have stayed with Neon. At the moment I will not change this as I am in the process of fixing up problems on my utopic installation.
              There will be a lot of packages with the term "plasma" in them, and a lot of them are not for Plasma-5, but are for KDE4's version of Plasma Desktop so you might not see many of the widgets etc in your plasma 5 desktop
              (Darn those pesky KDE devs for making a muck of the namings of things!!)
              here is muon, filtered for the plasma-net ppa
              Also can check for it here:
                After today's (3rd Sept.) updates the Neon project boots for me to a black screen with mouse but zero options...
                  Neon is still running fine, on the large screen t.v. and is very stable, however, the only real advantage I see for it over Kubuntu is that I can place an icon/link on the desktop like one can with XP. I'll prolly just install Kubuntu and put a folder view on the desktop, or I could put some kind of "user bar/launcher" on...
                  The default video media player Tangerine DOES remember a stream like SOMA fm from day to day and will restart the stream with one click, and it does play a list of converted flvs. to mpeg (so I can take them to the college) and will play a folder with one click.
                  woodsmoke
                    I was rather disappointed with 14.10 plasma 5. So I have followed the procedures here for installing it on 14.04. I have installed the weekly updates using this ppa: ppa:neon/kf5-snapshot-weekly. Today I had about 90 updates for project-neon5. So I guess the updates are on Monday each week. Nothing is broken with these updates and I find it is better than the 14.10 plasma 5 installation for which I hardly saw any updates related to plasma 5.
                      woodsmoke
                      Aaaaa woody you can put a icon/link on your desktop in Kubuntu.
                      @NoWorries I use that PPA as well only this one not the weekly deb http://ppa.launchpad.net/neon/kf5/ubuntu trusty main
                      I get updates every day ,,,,,,,,
                        I also have this ppa on my system and I wasn't getting updates every day so I added the weekly one. I assume that having both activated will not cause problems. This morning there were not updates, so I hope all is well with my software sources and it is not a case of being on the other side of the Pacific Ocean.
                          Humm I had these today
                          Start-Date: 2014-09-10 21:04:15
                          Commandline: apt-get dist-upgrade
                          Upgrade: project-neon5-kcodecs:amd64 (0.0+git20140909.0316+neon4~58625d3~14.04, 0.0+git20140910.0316+neon4~58625d3~14.04), project-neon5-kcompletion:amd64 (0.0+git20140909.0311+neon4~5c674c7~14.04, 0.0+git20140910.0311+neon4~5c674c7~14.04), project-neon5-libnm-qt:amd64 (0.0+git20140909.0313+neon4~c71bc0c~14.04, 0.0+git20140910.0313+neon4~c71bc0c~14.04), project-neon5-kwin:amd64 (0.0+git20140909.0311+neon4~1b091a0~14.04, 0.0+git20140910.0311+neon4~1b091a0~14.04), project-neon5-kdesu:amd64 (0.0+git20140909.0310+neon4~cbc2861~14.04, 0.0+git20140910.0310+neon4~cbc2861~14.04), project-neon5-kwrited:amd64 (0.0+git20140909.0309+neon4~0e0548a~14.04, 0.0+git20140910.0309+neon4~0e0548a~14.04), project-neon5-polkit-qt-1:amd64 (0.0+git20140909.0313+neon4~3882e11~14.04, 0.0+git20140910.0313+neon4~3882e11~14.04), project-neon5-frameworkintegration:amd64 (0.0+git20140909.0314+neon4~47082c0~14.04, 0.0+git20140910.0314+neon4~47082c0~14.04), project-neon5-knotifications:amd64 (0.0+git20140909.0315+neon4~1717ec3~14.04, 0.0+git20140910.0315+neon4~81310e2~14.04), project-neon5-kdelibs4support:amd64 (0.0+git20140909.0315+neon4~f40788e~14.04, 0.0+git20140910.0315+neon4~f40788e~14.04), project-neon5-plasma-desktop:amd64 (0.0+git20140909.0314+neon4~c41fd1d~14.04, 0.0+git20140910.0314+neon4~3aa8a23~14.04), project-neon5-powerdevil:amd64 (0.0+git20140909.0309+neon4~9c8e8e2~14.04, 0.0+git20140910.0308+neon4~9c8e8e2~14.04), project-neon5-kwidgetsaddons:amd64 (0.0+git20140909.0310+neon4~114c59e~14.04, 0.0+git20140910.0310+neon4~114c59e~14.04), project-neon5-kio:amd64 (0.0+git20140909.0316+neon4~26a1467~14.04, 0.0+git20140910.0316+neon4~ae87a7d~14.04), project-neon5-karchive:amd64 (0.0+git20140909.0314+neon4~af143e5~14.04, 0.0+git20140910.0314+neon4~af143e5~14.04), project-neon5-ksysguard:amd64 (0.0+git20140909.0309+neon4~b3a1953~14.04, 0.0+git20140910.0309+neon4~b3a1953~14.04), project-neon5-kjs:amd64 (0.0+git20140909.0312+neon4~d496f1b~14.04, 0.0+git20140910.0312+neon4~d496f1b~14.04), project-neon5-kbookmarks:amd64 (0.0+git20140909.0316+neon4~319c443~14.04, 0.0+git20140910.0316+neon4~319c443~14.04), project-neon5-libkscreen:amd64 (0.0+git20140909.0313+neon4~ed8cfb2~14.04, 0.0+git20140910.0313+neon4~ed8cfb2~14.04), project-neon5-ktexteditor:amd64 (0.0+git20140909.0311+neon4~30adecd~14.04, 0.0+git20140910.0311+neon4~ae919e2~14.04), project-neon5-kactivities:amd64 (0.0+git20140909.0310+neon4~5cd28b6~14.04, 0.0+git20140910.0309+neon4~5cd28b6~14.04), project-neon5-knotifyconfig:amd64 (0.0+git20140909.0312+neon4~6ba6128~14.04, 0.0+git20140910.0312+neon4~6ba6128~14.04), project-neon5-kunitconversion:amd64 (0.0+git20140909.0310+neon4~4c7468e~14.04, 0.0+git20140910.0310+neon4~4c7468e~14.04), project-neon5-kauth:amd64 (0.0+git20140909.0308+neon4~ed92b31~14.04, 0.0+git20140910.0308+neon4~ed92b31~14.04), project-neon5-kio-extras:amd64 (0.0+git20140909.0311+neon4~c494702~14.04, 0.0+git20140910.0311+neon4~c494702~14.04), project-neon5-kjobwidgets:amd64 (0.0+git20140909.0312+neon4~bfd3b50~14.04, 0.0+git20140910.0312+neon4~bfd3b50~14.04), project-neon5-kcmutils:amd64 (0.0+git20140909.0312+neon4~3c2488f~14.04, 0.0+git20140910.0312+neon4~3c2488f~14.04), project-neon5-milou:amd64 (0.0+git20140909.0313+neon4~4fc9b7e~14.04, 0.0+git20140910.0313+neon4~4fc9b7e~14.04), project-neon5-kdewebkit:amd64 (0.0+git20140909.0312+neon4~192df06~14.04, 0.0+git20140910.0312+neon4~192df06~14.04), project-neon5-kcoreaddons:amd64 (0.0+git20140909.0310+neon4~4d9bc0b~14.04, 0.0+git20140910.0310+neon4~4ac34f2~14.04), project-neon5-baloo:amd64 (0.0+git20140909.0314+neon4~6335bfc~14.04, 0.0+git20140910.0314+neon4~6335bfc~14.04), project-neon5-kwallet:amd64 (0.0+git20140909.0310+neon4~0aa4c66~14.04, 0.0+git20140910.0310+neon4~0aa4c66~14.04), project-neon5-kinit:amd64 (0.0+git20140909.0313+neon4~2603d14~14.04, 0.0+git20140910.0313+neon4~2603d14~14.04), project-neon5-khtml:amd64 (0.0+git20140909.0309+neon4~3c5acb4~14.04, 0.0+git20140910.0309+neon4~3c5acb4~14.04), project-neon5-kparts:amd64 (0.0+git20140909.0309+neon4~ed41879~14.04, 0.0+git20140910.0309+neon4~ed41879~14.04), project-neon5-
                          kitemviews:amd64 (0.0+git20140909.0309+neon4~5d83932~14.04, 0.0+git20140910.0309+neon4~5d83932~14.04), project-neon5-kfilemetadata:amd64 (0.0+git20140909.0316+neon4~5d1c60d~14.04, 0.0+git20140910.0316+neon4~5d1c60d~14.04), project-neon5-solid:amd64 (0.0+git20140909.0311+neon4~3fbf4f7~14.04, 0.0+git20140910.0311+neon4~3fbf4f7~14.04), project-neon5-oxygen:amd64 (0.0+git20140909.0313+neon4~8a084e8~14.04, 0.0+git20140910.0313+neon4~55204d6~14.04), project-neon5-sonnet:amd64 (0.0+git20140909.0316+neon4~6fb6f39~14.04, 0.0+git20140910.0316+neon4~6fb6f39~14.04), project-neon5-kwindowsystem:amd64 (0.0+git20140909.0308+neon4~051720d~14.04, 0.0+git20140910.0308+neon4~051720d~14.04), project-neon5-kmenuedit:amd64 (0.0+git20140909.0310+neon4~1c9f7cd~14.04, 0.0+git20140910.0310+neon4~1c9f7cd~14.04), project-neon5-khotkeys:amd64 (0.0+git20140909.0314+neon4~649c690~14.04, 0.0+git20140910.0314+neon4~649c690~14.04), project-neon5-ki18n:amd64 (0.0+git20140909.0316+neon4~3940e74~14.04, 0.0+git20140910.0316+neon4~3940e74~14.04), project-neon5-knewstuff:amd64 (0.0+git20140909.0309+neon4~0b09528~14.04, 0.0+git20140910.0309+neon4~0b09528~14.04), project-neon5-kplotting:amd64 (0.0+git20140909.0313+neon4~2ca2748~14.04, 0.0+git20140910.0313+neon4~2ca2748~14.04), project-neon5-kconfigwidgets:amd64 (0.0+git20140909.0316+neon4~7f9bdbf~14.04, 0.0+git20140910.0316+neon4~7f9bdbf~14.04), project-neon5-kdoctools:amd64 (0.0+git20140909.0316+neon4~30a4ccc~14.04, 0.0+git20140910.0316+neon4~30a4ccc~14.04), project-neon5-kiconthemes:amd64 (0.0+git20140909.0312+neon4~a5c11ab~14.04, 0.0+git20140910.0312+neon4~a5c11ab~14.04), project-neon5-kcrash:amd64 (0.0+git20140909.0315+neon4~638a164~14.04, 0.0+git20140910.0315+neon4~638a164~14.04), project-neon5-krunner:amd64 (0.0+git20140909.0312+neon4~e9ace33~14.04, 0.0+git20140910.0312+neon4~e9ace33~14.04), project-neon5-kpty:amd64 (0.0+git20140909.0312+neon4~c272564~14.04, 0.0+git20140910.0312+neon4~c272564~14.04), project-neon5-kemoticons:amd64 (0.0+git20140909.0314+neon4~c4d8410~14.04, 0.0+git20140910.0314+neon4~c4d8410~14.04), project-neon5-plasma-nm:amd64 (0.0+git20140909.0314+neon4~0bd1ca5~14.04, 0.0+git20140910.0313+neon4~0c72d2f~14.04), project-neon5-kxmlgui:amd64 (0.0+git20140909.0314+neon4~ece9daf~14.04, 0.0+git20140910.0314+neon4~ece9daf~14.04), project-neon5-kidletime:amd64 (0.0+git20140909.0309+neon4~5ee015b~14.04, 0.0+git20140910.0309+neon4~5ee015b~14.04), project-neon5-systemsettings:amd64 (0.0+git20140909.0316+neon4~b3d272c~14.04, 0.0+git20140910.0316+neon4~b3d272c~14.04), project-neon5-kdnssd:amd64 (0.0+git20140909.0316+neon4~7704029~14.04, 0.0+git20140910.0316+neon4~7704029~14.04), project-neon5-kconfig:amd64 (0.0+git20140909.0309+neon4~26e7a3f~14.04, 0.0+git20140910.0308+neon4~26e7a3f~14.04), project-neon5-kded:amd64 (0.0+git20140909.0313+neon4~614afbe~14.04, 0.0+git20140910.0313+neon4~614afbe~14.04), project-neon5-khelpcenter:amd64 (0.0+git20140909.0313+neon4~238f26d~14.04, 0.0+git20140910.0313+neon4~238f26d~14.04), project-neon5-kdbusaddons:amd64 (0.0+git20140909.0313+neon4~6a45399~14.04, 0.0+git20140910.0312+neon4~6a45399~14.04), project-neon5-plasma-framework:amd64 (0.0+git20140909.0310+neon4~9b6205c~14.04, 0.0+git20140910.0310+neon4~1279b3d~14.04), project-neon5-kinfocenter:amd64 (0.0+git20140909.0316+neon4~fab69c9~14.04, 0.0+git20140910.0316+neon4~fab69c9~14.04), project-neon5-kglobalaccel:amd64 (0.0+git20140909.0311+neon4~80c01e7~14.04, 0.0+git20140910.0311+neon4~80c01e7~14.04), project-neon5-libksysguard:amd64 (0.0+git20140909.0311+neon4~a2b6a1f~14.04, 0.0+git20140910.0311+neon4~a2b6a1f~14.04), project-neon5-kservice:amd64 (0.0+git20140909.0310+neon4~bb04741~14.04, 0.0+git20140910.0309+neon4~bb04741~14.04), project-neon5-kjsembed:amd64 (0.0+git20140909.0308+neon4~fe28370~14.04, 0.0+git20140910.0308+neon4~fe28370~14.04), project-neon5-kitemmodels:amd64 (0.0+git20140909.0309+neon4~45b16f7~14.04, 0.0+git20140910.0309+neon4~45b16f7~14.04), project-neon5-plasma-workspace:amd64 (0.0+git20140909.0315+neon4~8331d00~14.04, 0.0+git20140910.0315+neon4~eeed831~14.04), project-neon5-threadweaver:amd64 (0.
                          0+git20140909.0308+neon4~f972881~14.04, 0.0+git20140910.0308+neon4~f972881~14.04), project-neon5-kdesignerplugin:amd64 (0.0+git20140909.0311+neon4~80eed7a~14.04, 0.0+git20140910.0311+neon4~80eed7a~14.04), project-neon5-ktextwidgets:amd64 (0.0+git20140909.0314+neon4~c8faf51~14.04, 0.0+git20140910.0314+neon4~c8faf51~14.04), project-neon5-kdeclarative:amd64 (0.0+git20140909.0314+neon4~eb58a1e~14.04, 0.0+git20140910.0314+neon4~efc2b05~14.04), project-neon5-kde-cli-tools:amd64 (0.0+git20140909.0315+neon4~d615bac~14.04, 0.0+git20140910.0314+neon4~d615bac~14.04), project-neon5-kguiaddons:amd64 (0.0+git20140909.0315+neon4~3d0636b~14.04, 0.0+git20140910.0315+neon4~3d0636b~14.04)
                          End-Date: 2014-09-10 21:06:16
                            https://launchpad.net/~neon
                            If you look at the different PPAs listed, you will see the the only one that has seen any sort-of recent updates is the daily-unstable ppa, and that was 4 days ago.
                            Now, these PPAs are using automated builds, so new stuff is built as it is pushed out to the KDE git repos by the KDE coders.
                            So, if there is nothing new to build, there will be no updates, or there is a problem or dep problem that is breaking something temporarily.
                            A LOT of KDE folks, including a number of Kubuntu peeps are in Brno for Akademy so it is possible some development work has been slowed down for a short spell
                              Hi VINNY, Looks like I was a bit hasty as I now have updates being installed. I will have to wait for the sun to rise in Europe before updates are likely. A sample of the ones being installed is:
                              78 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
                              Need to get 89.4 MB of archives.
                              After this operation, 8,192 B of additional disk space will be used.
                              Do you want to continue? [Y/n] y
                              Get:1 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kcoreaddons amd64 0.0+git20140911.0311+neon4~98826d1~14.04 [240 kB]
                              Get:2 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-polkit-qt-1 amd64 0.0+git20140911.0314+neon4~3882e11~14.04 [95.1 kB]
                              Get:3 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kauth amd64 0.0+git20140911.0308+neon4~ed92b31~14.04 [95.5 kB]
                              Get:4 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kconfig amd64 0.0+git20140911.0308+neon4~26e7a3f~14.04 [262 kB]
                              Get:5 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kcodecs amd64 0.0+git20140911.0318+neon4~58625d3~14.04 [97.5 kB]
                              Get:6 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kguiaddons amd64 0.0+git20140911.0316+neon4~3d0636b~14.04 [69.6 kB]
                              Get:7 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-ki18n amd64 0.0+git20140911.0318+neon4~3940e74~14.04 [123 kB]
                              Get:8 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kwidgetsaddons amd64 0.0+git20140911.0310+neon4~114c59e~14.04 [1,155 kB]
                              Get:9 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kconfigwidgets amd64 0.0+git20140911.0317+neon4~7f9bdbf~14.04 [154 kB]
                              Get:10 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kwindowsystem amd64 0.0+git20140911.0308+neon4~051720d~14.04 [155 kB]
                              Get:11 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kcrash amd64 0.0+git20140911.0317+neon4~638a164~14.04 [36.2 kB]
                              Get:12 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kdbusaddons amd64 0.0+git20140911.0313+neon4~6a45399~14.04 [57.0 kB]
                              Get:13 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kcompletion amd64 0.0+git20140911.0311+neon4~5c674c7~14.04 [109 kB]
                              Get:14 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kglobalaccel amd64 0.0+git20140911.0312+neon4~80c01e7~14.04 [65.4 kB]
                              Get:15 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kitemviews amd64 0.0+git20140911.0309+neon4~5d83932~14.04 [99.9 kB]
                              Get:16 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kiconthemes amd64 0.0+git20140911.0313+neon4~a5c11ab~14.04 [108 kB]
                              Get:17 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-karchive amd64 0.0+git20140911.0315+neon4~af143e5~14.04 [105 kB]
                              Get:18 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kservice amd64 0.0+git20140911.0310+neon4~bb04741~14.04 [263 kB]
                              Get:19 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-sonnet amd64 0.0+git20140911.0317+neon4~6fb6f39~14.04 [199 kB]
                              Get:20 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-ktextwidgets amd64 0.0+git20140911.0315+neon4~c8faf51~14.04 [106 kB]
                              Get:21 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kxmlgui amd64 0.0+git20140911.0315+neon4~ece9daf~14.04 [366 kB]
                              Get:22 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kbookmarks amd64 0.0+git20140911.0317+neon4~319c443~14.04 [108 kB]
                              Get:23 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kjobwidgets amd64 0.0+git20140911.0312+neon4~bfd3b50~14.04 [72.0 kB]
                              Get:24 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-knotifications amd64 0.0+git20140911.0317+neon4~81310e2~14.04 [119 kB]
                              Get:25 http://ppa.launchpad.net/neon/kf5/ubuntu/ trusty/main project-neon5-kwallet amd64 0.0+git20140911.0311+neon4~0aa4c66~14.04 [191 kB]
                              Also, being in the land down under, our days are different and these updates are for 20140911, whereas yours were for 20140910. Hope you can wait for these to come tomorrow your time.
                                Ok, I lied, musta clicked the same link twice, or it looks like updates are rolling now
                                I did note a few failed-to-build packages earlier, don't see them now
