[SOLVED]Material Help[SOLVED]
    Ok guys, I need help finding a material that can withstand tens or hundreds of pounds of pressure, is light, thin, and easy to craft with. Any good ideas?
    Motherboard:ASUS P5Q SE PLUS<br />Videocard:EVGA GeForce 9800 GTX+ 512MB<br />Ram:G.SKILL 4GB (2 x 2GB)<br />Processor:Intel Core 2 Quad Q6600 Kentsfield 2.4GHz
    Re: Material Help
    Wood is good, although I'm not sure how thin you need it.
    Plastic is pretty much crap no matter how fancy they make it.
    Welcome newbies!
    Verify the ISO
    Kubuntu's documentation
      Re: Material Help
      Titanium? Scandium?
      You didn't say anything about cost in your post.
      Home: Kubuntu 12.04-amd64; Intel i7-860 on Intel DH55PJ; Nvidia 9500GT; 6GB RAM
      Network Slave: Xubuntu 11.10-x86; Intel P4-Prescott on MSI; 2GB RAM; Nvidia FX5200
      Portable: Xubuntu 11.10-amd64; Asus EeePC 1015PEM
        Re: Material Help
        The whole industrial world is looking for that material.
          Re: Material Help
          Apologies for the curt answer. Seriously, sheet metal comes to mind. Aluminum maybe if weight is primary consideration, steel if strength is the most important.
            Re: Material Help
            Aluminium, that is what I shall use, thanks.
